Модуль нашел по номеру 63, зовется HU_NBT. Speedlock нашел, оба (min и max) стоят на 03. Исправляю оба на FF, сохраняю, активирую FA, выбираю Code FDL.
В результате ошибка. Циц перезапускается, при повторном обращении к нему параметры снова 3 км/ч оба.
Код ошибки:
Caf's werden gesucht
Tal wird generiert
NCD werden gelesen
FDL CAFD-00000DED-01.13.09 signieren.
Abarbeitung wird gestartet
TAL execution started. [C205]
ExecutionID=2013/02/05-22:16:40.125
[] prepareTALExecution started
[] prepareTALExecution finished
[] prepareVehicleForCoding started
[] prepareVehicleForCoding finished
[HU_NBT - 63] prepareECUforCoding started
[HU_NBT - 63] prepareECUforCoding error
[HU_NBT - 63] finalizeECUCoding started
[HU_NBT - 63] finalizeECUCoding finished
[Exception - HU_NBT - 63] Exception occurred: job failed with negative response error:
code: written data does not match read data
description: no detailed description available; ECU: HU_NBT_63_ETHERNET
severity: ERROR
Timestamp: Tue Feb 05 22:16:45 GST 2013
ErrorCategory: VEHICLE_ERROR ID: 433
Class: com.bmw.psdz.vehicle.connection.util.ResultUtil
ExecutionContext={category=TAL, ecuid=(HU_NBT,0x63), TA_CATEGORY=cdDeploy, PROGRAMMING_STATUS=prepareECUforCoding}
[] finalizeVehicleCoding started
[] finalizeVehicleCoding finished
[] finalizeTALExecution started
[] finalizeTALExecution finished
В чем может быть дело?
Спасибо.
