Старый 14.02.2013, 20:46 #1
Аватар для viktorrrr
Авто: bmv е38
F0 Undefined System Defect
F1 Fuel Pump Relay (EKP)/TR Signal
F2 Idle Actuator - Closing Winding
F3 Injector Valve(s)
F4 Injector Valve - Cylinder 3
F5 Injector Valve - Cylinder 2
F6 Injector Valve - Output Stage
F8 Malfunction Indicator Lamp (MIL) - USA Models Only
F12 Throttle Potentiometer
F16 Ignition Reference Pulse Generator
F18 Output Stage
F19 Output Stage
F23 Ignition Fault - Cylinder 2
F24 Ignition Fault - Cylinder 3
F25 Ignition Fault - Cylinder 1
F26 Control Unit Supply Voltage B+
F29 Idle Actuator - Opening Winding
F31 Injector Valve - Cylinder 5
F32 Injector Valve(s)
F33 Injector Valve - Cylinder 4
F36 Fuel Evaporation Control Valve (EVAP)
F37 Oxygen Sensor Heater
F41 Air Mass Meter (HLM)
F46 Output Stage
F48 Air-Conditioner Compressor Cut-Out Relay
F50 Ignition Fault - Cylinder 4
F51 Ignition Fault - Cylinder 6
F52 Ignition Fault - Cylinder 5
F54 Control Unit Supply Voltage from Main Relay
F55 Ignition Output Stage
F62 Signal - Electronic Throttle Control (EML)
F63 Torque Converter Lockup Clutch
F64 Ignition Timing Intervention
F67 Crankshaft Pulse Generator
F70 Oxygen Sensor (Lambda Probe)
F73 Vehicle Speed Sensor (VSS)
F76 Idle CO-Potentiometer
F77 Intake Air Temperature Sensor
F78 Coolant Temperature Sensor
F81 Anti-Theft System Signal (DWA)
F82 Engine Drag Torque Control (MSR)
F83 Automatic Stability Control (ASC) Intervention
F85 Air-Conditioner Compressor Relay
F100 Output Amplifier Stage
F200 DME Control Unit
F201 Emission (Lambda) Control
F202 Control unit Fault Memory
F203 Ignition Circuit Monitoring
F204 Stall Protection (Idle Speed Increase)
viktorrrr вне форума
