Старый 22.04.2013, 08:03 #675
Аватар для ambrozi
Авто: e39 520i m52tu МКП 2000
прочитал ошибки СКАНЕР 1.4.0
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY
DME -> 7.500.255 15 E3 3 errors / 9 errors
EWS -> 6.905.668 03 08 1 error
ABS -> 6.756.342 53 03 no errors
A/C -> 6.901.628 03 14 no errors
SRS -> 6.900.727 38 25 2 errors
IKE -> 6.903.794 12 16 1 error
LCM -> 8.386.209 11 41 no errors / no errors
ZKE -> 6.901.226 20 22 no errors / 3 errors
PDC -> 6.904.023 01 13 2 errors
RAD -> 8.377.005 13 90 2 errors
SZM -> 8.373.712 27 F8 no errors / no errors
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME -> 08/F2 - Signal, air-mass flow sensor
1E/A2 - Activation, ignition, cylinder 3
01/A2 - Activation, ignition, cylinder 2
Shadow-memory:
32/14 - Activation, solenoid valve, fuel-circuit changeover
85/08 - Signal, CAN ASC 3
23/12 - Activation, relay, secondary-air pump
3E/12 - Activation, solenoid valve, secondary air
7E/12 - Activation, solenoid valve, tank-leak diagnosis pump
7F/02 - Activation, solenoid valve, suction-jet pump
EWS -> 0F/21 - Power on reset
SRS -> F0/80 - Internal control unit fault
11/A0 - Power supply
IKE -> CE/81 - Outside-temperature sensor
ZKE -> Shadow-memory:
86/01 - DWA-Alarm: door contact, rear, passenger's side
89/21 - DWA-Alarm: hood/bonnet contact
93/21 - Power up from the GM III
PDC -> 11/CF - Converter, rear right
12/C6 - Converter, rear centre left
RAD -> 00/00 - Energy saving mode active
02/00 - Error power-supply for antenna
# SCAN END
стер ошибки...остались такие
# ERRORS IN UNITS
DME -> 7.500.255 15 E3 no errors / 5 errors
EWS -> 6.905.668 03 08 no errors
IKE -> 6.903.794 12 16 no errors
ZKE -> 6.901.226 20 22 no errors / no errors
PDC -> 6.904.023 01 13 no errors
DME -> Shadow-memory:
# SCAN END
помогите разобраться с ошибками в модуле DME...
Последний раз редактировалось ambrozi; 22.04.2013 в 08:04.
