Тема: BMW Inpa/Ediabas
Старый 22.05.2013, 23:27 #1283
Аватар для Витюха
Сказал спасибо: 100
Авто: трактор
Solo606,
SYS-0002: ECU OBJECT FILE NOT
FOUND
EDIABAS_SYS_0002
Meaning: The ECU variant description file couldn't be found.
Causes: Either the description file does not exist in the EDIABS
search path or the search path is wrong.
EDIABAS search path:
The EDIABAS configuration element EcuPath describes
the EDIABAS search path. When the configuration
setting does not exist, the current directory is used by
EDIABAS as the search path.
Error correction: Description file does not exist:
Copy the requested description file in the EDIABAS
search path.
Search path is wrong:
Terminate the application program, and assign the
correct path to configuration element EcuPath.
In case the configuration changes, terminate EDIABAS,
and re-start.:
WIN32: EDIABAS is automatically closed
with the application (automatic
restart)
WIN16: Close EDIABASW.EXE via system
menu
(automatic re-start)
SCO: Call shell script apiclose
Call shell script apiboot
QNX: Call shell script apiclose
Re-start the application program.
Target system: WIN SCO QNX
