Старый 30.06.2013, 01:24 #12
Аватар для Витюха
Сказал спасибо: 100
Авто: трактор
SYS-0005: OBJECT FILE NOT FOUND EDIABAS_SYS_0005
Meaning: The ECU description file couldn't be found.
Causes: Either the description file does not exist in the EDIABAS
search path or the search path is wrong.
EDIABAS search path:
The EDIABAS configuration elementEcuPath describes
the EDIABAS search path. If a configuration setting
does not exist, the currentdirectory is used by
EDIABAS as the search path.
Error correction: Description file does not exist:
Copy the required description file in the EDIABAS
search path.
Such path is wrong:
Terminate the application program, and assign the
correct path to configuration element EcuPath.
In case the configuration changed, terminate EDIABAS,
and re-start.:
WIN32: EDIABAS is automatically closed
with the application (automatic
restart)
WIN16: Close EDIABASW.EXE via system
menu
(automatic re-start)
SCO: Call shell script apiclose
Call shell script apiboot
QNX: Call shell script apiclose
Re-start the application program.
Target system: WIN SCO QNX
44
...значит точно не хватает prg....
