25.09.2013, 12:46
#1 |
Сказал спасибо: 1,546
Поблагодарили 10,579 раз(а) в 1,957 сообщениях
Откуда: Москва Авто: BMW e39 528 Есть клубные рамки | BMW M4 и M3 - технические характеристики
BMW M4 и M3 - технические характеристики - официально. Двигатель- Рядный 6-цилиндровый с 2 турбинами
- Прямой впрыск
- VALVETRONIC
- Двойной VANOS
- closed-decked crankcase
- twin-wire arc-spray coating (instead of liners) in cylinder bores reduce engine weight
- 430 л.с. (примерно)
- "far beyond" 369+ LB-FT (500 Nm)
- Отсечка на 7500
Турбины- Две турбины
- Impulse charging for optimized responsiveness
- Flow-enhanced manifolds
- Electric wastegate actuator
Охлаждение- Double-flow oil recirculation pumps
- Turbocharger suction system
- Main radiator plus additional radiators for the high- and low-temperature circuits, turbocharger and transmission,
- Large indirect intercooler
- Low-weight magnesium oil sump
- Temperature-stabilizing electric water pump
Вес - 1500кг
- this figure is without driver and with 90% fuel
- BMW clarifies that "the new model is now around 80 kilograms lighter than a comparably equipped predecessor model" [80kg = 176 lbs]
- compare to E46 M3 at ~3,400 lb curb weight
- compare to E92 M3 at ~3,600 lb curb weight
- compare to C63 AMG at ~3,900 lb curb weight
- compare to RS5 at ~4,000 lb curb weight
- ~ 7.68 lb/hp power to weight
- compare to E92 M3 at 8.7
- compare to C63 AMG at 8.7
- compare to RS5 at 9.0
- compare to E46 M3 at 10.25
- Потребление бензина и вредные выбросы снижены на 25%
Карбоновые детали - CFRP drive shaft
- 40% weight savings over previous M3
- increased stiffness
- reduced rotating mass for better acceleration and throttle response
- Карбоновая крыша для M3 и M4
- -5кг веса на M3
- -6кг веса на M4
- CFRP roof bow
- Карбоновая крышка багажника на M4 (-5кг веса)
- CFRP front strut brace standard (weighs just 3.3 pounds (1.5 kg))
КПП - 6-ступенчатая КПП
- automatic throttle blips on downshift
- more compact and quieter than predecessor E90/E92 M3 6 speed
- 26.4 pounds (12kg) lighter
- carbon fiber friction linings in synchroniser rings
- dry sump lubrication
- Опционально - 7 ступенчатая M DCT (с двойным сцеплением) с launch control
- Активный M-дифференциал (с блокировками как на M5/M6)
- Forged crankshaft
Рулевое управление- Электроусилитель руля, специально настроенный для M3/M4
- Servotronic function electronically adjusts the level of steering assistance
- Три режима: Comfort, Sport, Sport+
Подвеска- Опционально - адаптивная M-подвеска (режимы: Comfort, Sport, Sport+)
- Double-joint spring strut front axle (saves 11 pounds)
- New five-link rear axle made from forged aluminum (saves 6.6 pounds)
- Алюминиевая подвеска
- Aluminium stiffening plate
- Rear axle subframe fixed directly to body (bolted joints between the axle subframe and the body sills, without use of elastic rubber elements).
Колеса / тормоза - Легкосплавные диски
- Staggered tire sizes
- M compound brakes standard (синий цвет)
- M-carbon керамические тормоза - опционально (золотой цвет)
Выхлоп- Exhaust features electrically controlled flaps just before rear silencer to minimize exhaust back-pressure as well as giving precise feedback on engine load.
Аэродинамика- 50:50 развесовка по осям
- Air Curtain
- M gills with integrated Air Breather behind front wheels
Разное- M3 и M4 будут представлены на автошоу в Детройте в январе 2014
- M3 и M4 разработаны при участии пилотов БМВ Bruno Spengler и Timo Glock.
Чат по кодированию, программированию, дооснащению BMW в Telegram: https://t.me/+QiJ7fqL4KrYcxPrx BMW INPA | BMW ICOM | BMW Scanner | Ключи BMW | BMW CAN filter (cic retrofit adapter) | Отключение BMW EGR / DPF | Ноутбуки для диагностики Автосканеры, автодиагностика Сканеры для диагностики BMW Инструкции, мануалы к БМВ бесплатно BMW & MINI: TIS, ЕТК, ЕТМ, KSD, WDS, DIS, EBA и другие полезные программы |
