Старый 04.10.2013, 23:30 #65
Аватар для Азиат
Сказал спасибо: 36
Авто: BMW E39,528iA
Если кому интересно - коды диагностики АКПП "Джатко":
1.Jecs 5-speed trans.\n A5S 300J(Jatco RLA):
0x02060001 1 solenoid check
0x02060002 2 solenoid valve compressor
0x02060004 4 voltage supply
0x02060006 6 solenoid valve A
0x02060007 7 solenoid valve B
0x0206000a 10 engine intervention
0x02060014 20 program buttom
0x02060017 23 voltage supply
0x02060018 24 speed signal n-mod
0x02060019 25 speed signal n-ab
0x0206001b 27 speed-A signal
0x0206001d 29 solenoid valve WK
0x02060021 33 ATF temp sensor
0x02060022 34 throttle signal(DKT)
0x02060029 41 kickdown switch
0x0206002b 43 slip solenoid valve
0x0206002c 44 R shift solenoid fuse
0x0206002e 46 solenoid valve c
0x0206002f 47 P/N shift lock
0x02060032 50 WK slip test
0x02060033 51 shift test
0x02060034 52 engine overrev
0x02060035 53 A/D converter
0x020600c8 200 no kickdown shifts
0x020600c9 201 no S-program
0x020600ca 202 no *-program
0x020600cb 203 no program switchover
0x020600cc 204 no engine intervention
0x020600cd 205 defective brake-light switch
0x020600ce 206 incorrect fault display
EGS 8.70 M52:
0x022C0001 1 Pressure actuator 2
0x022C0002 2 P/N shift-lock
0x022C0003 3 solenoid valve 5
0x022C0004 4 torque converter clutch solenoid valve
0x022C0005 5 Pressure regulator
0x022C0006 8 Selector pos. L2
0x022C0009 9 Selector pos. L4
0x022C000C 12 Program button
0x022C0010 16 Turbocharger, speed sensor
0x022C0012 18 Kickdown switch
0x022C0013 19 ASC interface
0x022C001A 26 Battery voltage
0x022C001D 29 Pressure actuator 3
0x022C001E 30 Solenoid valve 1
0x022C001F 31 Solenoid valve 4
0x022C0020 32 Solenoid valve 3
0x022C0021 33 Solenoid valve 2
0x022C0023 35 Throttle signal (DKT)
0x022C0024 36 Selector pos. L1
0x022C0025 37 Selector pos. L3
0x022C0026 38 Front-left wheel rpm
0x022C0027 39 Front-right wheel rpm
0x022C0028 40 Rear-left wheel rpm
0x022C0029 41 Rear-right wheel rpm
0x022C002A 42 Speed signal n-out
0x022C002B 43 Speed signal n-Mot
0x022C002E 46 Step-shift system
0x022C0033 51 pressure actuator 5
0x022C0035 53 Voltage supply solenoid valve
0x022C0036 54 Voltage supply
0x022C0064 100 Gear monitoring
0x022C0065 101 EPROM checksum
0x022C0066 102 Program checksum
0x022C0067 103 Transmission relay
0x022C0068 104 Temp. information (DKT-signal)
0x022C0069 105 Engine overrun interlock
0x022C006A 106 Stall monitoring
0x022C006B 107 Wheel speed
0x022C006C 108 Control unit program
0x022C006F 111 Converter lookup clutch slippery
0x022C007B 123 Gear monitoring, 2nd/3rd gear
0x022C007C 124 Gear monitoring, 3rd/4th gear
0x022C0082 130 Gear monitoring 1M
0x022C0083 131 Gear monitoring 1
0x022C0084 132 Gear monitoring 2
0x022C0085 133 Gear monitoring 3
0x022C0086 134 Gear monitoring 4
0x022C0087 135 Gear monitoring 5
0x022C0096 150 CAN bus monitoring
0x022C0097 151 Faulty CAN status
0x022C0098 152 CAN: engine intervention
0x022C0099 153 CAN: DME load signal
0x022C009A 154 CAN: throttle valve position
0x022C009B 155 CAN: DME engine temp.
0x022C009C 156 CAN: timeout (ign. on)
0x022C009D 157 CAN: timeout (operate)
0x022C009E 158 CAN: throttle-valve and load signals
0x022C009F 159 CAN: ABS/DSC wheel speed signal
0x022C00A0 160 CAN: ABS/DSC wheel speed signal
0x022C00C8 200 No kickdown shifts
0x022C00C9 201 No s-program
0x022C00CA 202 no M-program
0x022C00CC 203 no program switchover
0x022C00CD 204 no engine intervention
0x022C00CE 205 defective brake-light switch
0x022C00CF 206 incorrect fault display
Ещё бы узнать,что они конкретно означают
Азиат вне форума   Ответить с цитированием
