0x00 00 ECU_DOWNLOAD_IN_PROGRESS
0x01 01 ECU_DONE
0x02 02 ECU_TO_BE_UPDATED
0xAD 173 ECU_ERROR_GET_CODING
0xAE 174 ECU_ERROR_OUT_OF_RANGE
0xAF 175 ECU_ERROR_FRAGMENT_SCRIPT
0xB0 176 ECU_ERROR_FRAGMENT_UNKNOWN
0xB1 177 ECU_ERROR_FRAGMENT_STATUS
0xB2 178 ECU_ERROR_STORE_FRAGMENT
0xB3 179 ECU_ERROR_STEP_NOT_FOUND
0xB4 180 ECU_ERROR_EMPTY_LL
0xB5 181 ECU_ERROR_END_OF_LL
0xB6 182 ECU_ERROR_FRAGMENT_SCRIPT_READ
0xB7 183 ECU_ERROR_FRAG_IMAGE_WRITE
0xB8 184 ECU_ERROR_INFOLOG_WRITE
0xB9 185 ECU_ERROR_GET_FS_FILE
0xBA 186 ECU_ERROR_FRAGMENT_UNKNOWN_IDSEL
0xBB 187 ECU_ERROR_FRAGMENT_READING
0xBC 188 ECU_WARNING_FRAGMENT_EOL
0xBD 189 ECU_ERROR_FRAGMENT_INSTALL
0xBE 190 ECU_ERROR_FRAGMENT_SIZE
0xBF 191 ECU_ERROR_FRAGMENT_HEADER_SIZE
0xC0 192 ECU_ERROR_SOURCE_PARSING
0xC1 193 ECU_ERROR_SCRIPT_PARSING
0xC2 194 ECU_ERROR_DISPLAY_SCREEN
0xC3 195 ECU_WARNING_DVD_REGISTRATION
0xC4 196 ECU_ERROR_USER_CANCELLATION
0xC5 197 ECU_WARNING_NO_USER_INPUT
0xC6 198 ECU_ERROR_NO_USER_INPUT
0xC7 199 ECU_ERROR_WDOG_FAILED
0xC8 200 ECU_ERROR_EXIT_CALLED
0xC9 201 ECU_ERROR_SPAWNING_TASK
0xCA 202 ECU_ERROR_MODULE_LOADING
0xCB 203 ECU_ERROR_SYNC_SAVE
0xCC 204 ECU_ERROR_LOADING_ERROR
0xCD 205 ECU_ERROR_SIGCHECK_FAILURE
0xCE 206 ECU_ERROR_INFOLOG_SECTION_DELETE
0xCF 207 ECU_ERROR_PAF_DAF_MISMATCH
0xD0 208 ECU_ERROR_PRG_REF_FAILURE
0xD1 209 ECU_ERROR_PRGREF_HWREF_MISMATCH
0xD2 210 ECU_ERROR_HWREF_INVALID
0xD3 211 ECU_ERROR_PAF_SIG_CHECK_FAILURE
0xD4 212 ECU_ERROR_UPDATE_UNKNOWN_ERROR
0xD5 213 ECU_WARN_PAF_DAF_MISMATCH
0xD6 214 ECU_ERROR_TFFS_EXTRACTION
0xD7 215 ECU_ERROR_TFFS_CREATION
0xD8 216 ECU_ERROR_RAMDISK_CREATION
0xD9 217 ECU_ERROR_UNKNOWN_OVERALL_STATUS
0xDA 218 ECU_ERROR_CD_VERSION_TOO_BIG
0xDB 219 ECU_ERROR_VERSION_CHECKSUM_MISMATCH
0xDC 220 ECU_ERROR_NO_PROJMAPPING
0xDD 221 ECU_ERROR_NO_HWMAPPING
0xDE 222 ECU_ERROR_INVALID_FAST_IMAGE
0xDF 223 ECU_ERROR_NO_ECU_RESPONSE
0xE0 224 ECU_ERROR_ILLEGAL_PROG_TYPE
0xE1 225 ECU_ERROR_READING_HIP_VERS
0xE2 226 ECU_ERROR_CHECKSUM_MISMATCH
0xE3 227 ECU_ERROR_INVALID_IMAGE_HEADER
0xE4 228 ECU_ERROR_PROCESSING_VERSION_FILE
0xE5 229 ECU_WARNING_LINE_NOT_OF_INTEREST
0xE6 230 ECU_WARNING_COULD_NOT_UPDATE_AIF
0xE7 231 ECU_ERROR_NO_ECUS
0xE8 232 ECU_ERROR_DISC_CHANGE
0xE9 233 ECU_ERROR_LABEL_NOT_FOUND
0xEA 234 ECU_ERROR_SECTION_DATA
0xEB 235 ECU_ERROR_SECTION_PROG
0xEC 236 ECU_ERROR_CANT_OPEN_FILE
0xED 237 ECU_ERROR_IMAGEIO
0xEE 238 ECU_ERROR_WRONG_SOURCE
0xEF 239 ECU_ERROR_WRITING_FILE
0xF0 240 ECU_ERROR_READING_FILE
0xF1 241 ECU_WARNING_UNKNOWN_COMMAND
0xF2 242 ECU_ERROR_UNKNOWN_SCRIPT
0xF3 243 ECU_ERROR_READING_KWP
0xF4 244 ECU_ERROR_SRIPT_PARSING
0xF5 245 ECU_ERROR_INFOLOG_READ
0xF6 246 ECU_ERROR_UNKNOWN_BOOTMODE
0xF7 247 ECU_ERROR_FILESIZE_MISMATCH
0xF8 248 ECU_ERROR_TOO_MANY_ECUS
0xF9 249 ECU_ERROR_DISC_INSERTED
0xFA 250 ECU_ERROR_DISC_EJECTED
0xFB 251 ECU_ERROR_PROCESSING_SCRIPT
0xFC 252 ECU_ERROR_NOT_ENOUGH_MEMORY
0xFD 253 ECU_ERROR_IMAGE_NOT_FOUND
0xFE 254 ECU_ERROR_SCRIPT_NOT_FOUND
0xff 255 unknown status
