Старый 28.10.2013, 11:25 #4
Аватар для victor540
Авто: Е39 540
Сообщение от SS26 Посмотреть сообщение
понятие "весь срок службы" - как то регламентируется?
ZF про свои коробки глаголит так:
"Maintenance recommendations ZF automatic transmissions
5-, 6- and 8-speed as well as 4HP20 automatic transmissions:
ZF 5-, 6- and 8-speed as well as the ZF 4HP20 automatic transmissions are filled maintenance-free with specially developed partially
synthetic ATF oils. Maintenance-free fills are intended for normal operating conditions. Especially driving at very high operating
temperatures can result in accelerated aging or increased wear of ATF oils. It is recommended, in the event of severe operating
conditions, such as:
- frequent highway driving in top speed range,
- offensive, sporty driving style,
- frequent trailer operation,
being above average, oil purification (oil change) on automatic transmissions is recommended between 80,000 km and 120,000 km, or
8 years, depending on the load.
In each case, only released ATF oil may be used for oil changes. And oil changes must be performed in accordance with the relevant
specifications."
http://www.thectsc.com/images/pdf/teml11.pdf стр 4
E39 540IA M62B44
Hyundai Accent 1,4 2008г.
Последний раз редактировалось victor540; 28.10.2013 в 11:29.
