Старый 09.12.2013, 17:36 #2
Авто: BMW E60
Ссылка была на **** и похоже не прошла, попробую выложить описание:
BMW USB OBD Diagnostic cable INPA Ediabas Ncs Expert DIS v57 SSS v32 GT1 Progman
Supports all models up to march 2007:
BMW 1 Series E87
BMW 3 Series E46 E83 E90
BMW 5 Series E39 E60 E61
BMW 6 Series E63 E64
BMW 7 Series E38 E65 E66
BMW X Series E53
BMW Z Series E85 E52
Mini R50, R52, R53, R55, R56
Rolls Royce
Features:
Read fault codes
Erase fault codes
Service intervals reset
Real-time diagnostic live status view
EWS / CAS synchronization
Adaptations
Enabling hidden features
Code modules
Retrofitting
Code ECU (daytime running light, seat memory to key, beep after locking)
Specific part tests (like a lambda or mass air flow sensor
And more...
Functions
Connects to USB (1.5 m cable, creates virtual COM port)
Supports Double K-Line
Detects battery voltage through control line
Detects contact via control line
Works on USB port, USB RS-232 adapter not needed
Applications:
Works with INPA Ediabas, NCSExpert, Carsoft, DIS, SSS (Progman) and others
The package will include:
- 2 x DVD's with DIS v57 & TIS, SSS v32, INPA Ediabas, NCSExpert 4.0.1, Carsoft 6.1, NavCoder
- 1 x USB interface (the color of cable can be blue or black)
- software is protected with hardware id and the registration will be generated for free
Your PC requirements:
- works on Win XP, Vista & Win7 both 32bits and 64bits
- USB port
- at least 35Gb free hdd space, 1Gb Ram, 1.5Ghz CPU
- just copy and run DIS & SSS without wasting time installing from scratch
- for other questions feel free to ask
Romashkaz вне форума   Ответить с цитированием
