Старый 07.04.2014, 12:45 #22
Аватар для victor540
Авто: Е39 540
Для общего развития:
5 and 6-speed as well as 4HP20 automatic transmissions:
ZF 5 and 6-speed as well as the ZF 4HP20 automatic transmissions are filled maintenance-free with specially developed partiallysynthetic ATF oils. Maintenance-free fills are intended for normal operating conditions. Especially driving at very high operatingtemperatures can result in accelerated aging or increased wear of ATF oils. In the event of operating conditions, such as:- highway driving in top speed range,- offensive, sporty driving style,- frequent trailer operation,being above average, oil purification (oil change) on automatic transmissions is recommended between 80,000 km and 120,000 km, or 8 years, depending on the load.In each case, only released ATF oil may be used for oil changes. And oil changes must be performed in accordance with the relevantspecifications.
The ZF automatic transmissions 5HP18 and 5HP30 are exceptions and must be filled differently depending on the version.
The oils released in each case are specified in the ZF Lubricants List TE-ML 11.
E39 540IA M62B44
Hyundai Accent 1,4 2008г.
Сказал Спасибо victor540 за это сообщение:
