Старый 26.10.2015, 00:48 #4
Аватар для Юра 535
Сказал спасибо: 30
Поблагодарили 335 раз(а) в 174 сообщениях
Sys E-Sys Comfort Mode => FSC=> "Upgrade FSC" is used to write and Activate FSC Code
- Or -
In E-Sys Expert Mode => FSC Extended:
Select StoreFSCCert and CheckFSCCert and then Start
Either method requires the correct Paramters and a legitimate FSC Code (Base64 Decoded), and in the case of Comfort Mode, the FA (VO) must be specified.
Parameters (Example using 9C BMW Apps FSC Code):
Diagnostic Address (hex) = 63 (for HU_CIC)
Application Number (dec) = 156 (9C in Hex - In FSC File Name)
Base Variant = HU_CIC (CIC module name, e.g. HU_ENTRY; HU_CIC, HU_NBT, etc.)
Upgrade Index = 1 (In FSC File Name)
Исполняю желания !
не дорого
