Старый 19.01.2016, 00:28 #26
Аватар для YayDoGeN
Сказал спасибо: 10
Поблагодарили 37 раз(а) в 26 сообщениях
Авто: BMW 320i E90
Ещё левый передний добавился
Вот тебе список всех ошибок:
0x04 wheel sensor rear left
0x05 wheel sensor rear right
0x06 wheel sensor front right
0x07 wheel sensor front left
0x0E valve-relay Error
0x0F pump Error
0x15 control unit Error
0x17 ASC variant coding
0x18 wrong gear at one wheel
0x19 stop light switch cabel
0x1E wheel sensor rear left
0x1F wheel sensor rear right
0x20 wheel sensor front right
0x21 wheel sensor front left
0x22 ASC change over valve
0x2F ABS valve outlet rear left or rear axle
0x30 ABS valve outlet rear right
0x31 ABS valve outlet front right
0x32 ABS valve outlet front left
0x33 ABS valve inlet rear left or rear axle
0x34 ABS valve inlet rear right
0x35 ABS valve inlet front right
0x36 ABS valve inlet front left
0x37 ASC cut-off valve
0x38 generel CAN error
0x3A CAN messageerror EGS1
0x3B CAN messageerror DMER1
0x3F V-comparison
0x40 continuous control
0x42 power supply engine speed sensor, control unit error
0x43 eletromagnetic field susceptibility
0x44 ASR passive
0x4B CAN NMOT Error
0x4C CAN DDE messageerror
0x6F CAN messageerror acknowledge ASC
0x70 CAN instrument cluster
YayDoGeN вне форума   Ответить с цитированием
