Старый 14.10.2016, 12:22 #2
Аватар для Антихрист
Сказал спасибо: 11
Авто: БМВ 530iA
Сообщение от Alex15BV Посмотреть сообщение
Доброго времени суток Всем.
Вопрос такой:
Е39 БЕЗ видео-модуля. Для дооснащения камерой заднего вида нужно два комплекта: непосредственно комплект камеры 0 303 079 (для подключения к видео-модулю,
и "экстендет кит" 0 303 083 (для подключения без видео-модуля):
Не проще и дешевле купить у Чинайцев модный аппарат с камерой и видеорегистратором, и мильёном прибамбасов?
BMW 5 Series E39 1996 to 2001 with Old 17-Pin connector
BMW 5 Series E39 2002 to 2003 with New 40-Pin connector
BMW X5 E53 2000 to 2001 with Old 17-Pin connector
BMW X5 E53 2002 to 2007 with New 40-Pin connector
BMW M5 1996 to 2003 with Old 17-Pin or New 40-Pin connector
BMW 7 Series E38 1995 to 2001 with Old 17-Pin connector
Note: This unit has front panel size 285mm(Top width)*120mm(High)*285mm(Bottom width), please check your dashboard size before bid to avoid mistake!
- Google Android 4.2.2 Operation System, 7" Capacitive Touch Screen
- Dual-Core 1.6GHz CPU, 1GB RAM, 0.98GB ROM, 5.6GB Internal Memory
- Support extended Media Card/GPS Card/2 USB Stick up to 4*32GB
- DIY Main Menu Display: You can drag Search Bar, Weather Forecast widgets, Music/Radio/BT-Stereo Player,Apps or other
Bookmarks on main menu to display
- Built-In Clock and Calendar, it has a Real Clock to show time, Clock/Date/Week adjustable
- Multi-Languages Menu: it has more than 60 languages to select, just check it in our pictures
- 8 Panel Backlight colors, and you can setup hundreds of colors via RGB Combination
- 8 live wallpapers, 21 wallpapers, support DIY wallpaper from Gallery Pictures
- Built-in WiFi Modem, support 802.11b/g/n WLAN Standard, High Performance, Low Power Consumption
- Support 3G Internet, support extral USB Dongle: WCDMA,EVDO,TD-SCDMA
- Support Google Maps online Navigating, you can use GPS Navigating if you in Internet
- Support Android Maps Navigation, Free 4GB TF Card included
- Support Dual Zone function, while Navigating you can listen music
- Support Android Multimedia Player, it can play Music/Movie/Photo from local Disc or connected TF Card
- Online Entertainment, support online video, TV, movie, music, radio, Youtube, Yahoo, MSN
- Online Communication, keep connected through WeChat, Twitter, Facebook, Gtalk, Gmail and other services
- Support read and edit Official Software, WORD/EXCEL/POWERPOINT/PDF/TXT
- Support Google Play Store, you can download thousands of Apps from here and you can download many popular games like Fruit Ninja, Feed the Candy, Angry Birds, Fieldrunner, speed forge 3D...
- Support Torque Pro (OBD2 & Car), you can connect a ES350 Bluetooth OBD2 Scanner Tool to use this function
- Support 3D Games, HD Video, 1080P, H.264, DIVX Live images Formats
- Support HD Videos up to 1920*1080 pixels, Photo up to 4096*4096 pixels
- 4 x 50w Surround Stereo, Subwoofer Output
- Support Bluetooth hands-free function, built-in microphone and external microphone Jack
- Support A2DP Bluetooth, can play stereo music through Bluetooth from your Phone
- Download phone book function, you can download contact information from your phone to this unit
- Support the newest Phone Book Search, you can search&find a contact member in downloaded phone book,just input the first letter of name, you will find some associated names, then you can choose the right one
- Radio Tuner with RDS, 30 Preset Radio Stations (FM: 3*6, AM: 2*6)
- USB Port and Micro SD Slot, Support USB Stick and Memory Card up to 32GB
- Built-in Car DVR System, just connect with a USB Camera to use Car Record function. the records will be saved in GPS card
automatically, and you can play saved record on this unit directly.
- Support DVB-T/ATSC Box input, Touch Control and Power supply
- Support Rear View Camera input and reverse trigger Control
- Support Steering Wheel Control, special CanBus Decoder incl
- Hand Brake Control, electronic Anti-Shock, Last Position Memory
General
-Power Supply: DC 12V (allowable range: 10.8-14.5)
-Max Current: 10A
-Screen Size: 7"
-Package Size: 330mm*260mm*180mm
-Gross Weight: 3.5kg
-Net Weight: 3.2kg
System
-Operation System: Google Android 4.2.2
-CPU: Dual Core ARMv7 1608mHz
-ROM: 0.98GB
-RAM: 1GB
-Internal SD Card: 5.6GB
-External SD Card: Support TF Card up to 32GB
Display
-Screen type: 7 inch Capacitive touch screen
-Resolution: 800 * RGB * 480
-Built-in Calendar and Clock: Yes, it has a real clock to show time
-DIY Main Menu Display: You can drag Search Bar,Music/Radio/BT-Stereo Player,Apps or other Bookmarks to main menu
-One Button for Black Screen: yes, you can shut off display and enjoy music
-Change Icon Position: Yes
-Display Weather Forecast: Yes
3G/WiFi
-Connector: On the Back
-WiFi: Built in WiFi Modem, support 802.11 b/g/n
-3G: Support WCDMA,EVDO,TD-SCDMA format, 3G Dongle not included
Internet
-Explorer: Opera, UCWeb, SkyFile, Dolphin and more Exploer for your selection
-Online Entertainment: Online video, TV, Movie, Music, Radio, Video chat
-Online Navigation: Online Google Maps Navigating
-Office Software: WORD, EXCEL, POWERPOINT, PDF, TXT
-Game: Built-in SD accelerated, perfectly support 3D game
-Expansion Card: Could download more than 20,000 excellent software via Android E-market
Audio
-Format: MP3, WMA, MP2.OGG.AAC.M4A.MA4.FLAC.APE.3GP.WAV etc. can play from song list directly
-Record: Format: MP3.WMA
-Other: LRC synchronized display; ID3 search; Search by files; Album pictures; User-defined audio effect
-Audio IC: Top Global Cirrus IC, independent audio decoding
-SNR: Noise ration: ≥90dB
Video
-Format:SupportAVI(H.264.DIVX.DIVX.XVID).rm.rmvb.MK V(H.264.DIVX.DIVX.XVID).WMV.MOV.MP4
(H.264.MPEG.DIVX.XVID).DAT(VCD format).VOB(DVDformat).PMP.MPEG..MPG..FLV(H.263.H. 264).
ASF.TS.TP.3GP.MPG etc, ≥30 formats, playing internet video directly (while downloading)
-Play: Up to 1920*1080 pixels. 30Mb. Fluent play without light spot
-Video output: HDMI 720P to 1080P, full HD output and common video output (AV)
GPS
-Operation System: Android 4.2.2
-Supported Maps: Sygic, I-GO map for Android 4.2.2
-Free 4GB SD Card included: yes
-Voice guidance: Yes
-Support 2D/3D Map Views: Yes
-Dual Zone Function: Yes
-Online Navi: yes, support google map online navigating
DVD
-Decode IC: 8202VGQ
-Compatible Format: MP4, AVI, DIVX, DVD, VCD, MP3, CD, WMA, JPEG
-OSD/Audio/Subtitle Language: English/Italian/French/Spanish/Portuguese/German/Russian
-Auto-Save Function: Yes, expediently watch all kinds of disc continuously
Bluetooth
-Dialout: yes
-A2DP (Bluetooth Stereo Music): Yes, can play stereo music through Bluetooth
-Bluetooth Music Control: yes,play/pause/previous/next
-Phone Book Download: Yes, can download Phonebook from mobile to this unit
-Phone Book Search: yes,just input the first letter of name, you will find some associated names
-Call Records: Dialed Call, Received Call, Missed Call
-Setup: auto-answer.auto-connect
-Built-in microphone: Yes
-External Microphone Jack: yes, on the back
Radio
-AM Frequency Range: 522-1620KHz
-AM Increment: 9KHz(EU)/10KHz(US)
-FM Tuning Range: 87.5-108MHz
-FM Increment: 0.05MHz(EU)/0.1MHz(US)
-FM Area: Europe/USA1/USA2/Russia/Japan
-RDS: Yes
-Preset Stations: 30 (FM 3*6, AM 2*6)
USB
-Position: on the back, USB or 3G Modem Port optional
-Capacity: 32GB
-Support MP5 Video: Yes, support 1080P RMVB Video
-Touch Music title to play directly : Yes
SD
-Position : On the front Panel, Media or GPS Card Slot optional
-Capacity : 32GB Micro SD/TF Card
Car DVR
-Built-in Car Recorder Function: yes, the Recorder is built in already, you just need to connect one USB Camera to use this function
-Support HD CCD Camera: Yes
-Play Recorded Video Directly: Yes
-Show Recorded Video List: Yes, show the time longitude, latitude and Speed
-Storage Position: GPS Card
TV Box IN
-Built in TV Tuner: No
-External Port for TV Box: yes, support DVB-T/ATSC/ISDB Box
-Power connected TV Box: yes, no other power cable needed for the TV Box
-Touch control via DVD'Screen: yes
Additional
-Textbook: Could change font, Font color, Background color, bookmark, Reading E-Book while listening music
-Photo View: Support JPS. BMP. PNG. GIF etc. format. play by revolve. powerpoint Support 4096*4096 pixels
-Wallpapers: 8 live wallpapers,21 wallpapers, support DIY wallpapers from Gallery Pictures
-APK Installer: Support Android Package installer
-Support Torque Pro(OBD2&Car): yes, you can connect a ES350 Bluetooth OBD2 Scanner Tool to use this function
-Music/Radio Player on main menu: yes, display a real player on main menu, can be controlled
Setup
-WiFi/GPS/Steering Wheel Control: yes
-Languages&Input: 60 Languages and Input
-Storage/Security/Backup&Reset: yes
-Add Account/Accessibility: yes
-Date/Time: Setting Date/Time by yourself or choose GPS automatically update time
-Driving Safety/Screen Hot Setting: yes
-Display: Brightness/Wallpaper/Wireless Display
-Sound: Key Tone & Volume
-Amplifier: PoP/Jazz/Class/Flat/Rock/Voice/Custom
-APPS: Running APPS display/force stop/uninstall
-Element: 8 Panel Backlight Color, also you can set Hundreds of Color VIA RGB
-Factory Setup: Code 126,Choose Radio Band
-About Device: Display Parameter Info.
Input
-AUX Video In: One
-Camera Video In : One
-iPod In: One
-AUX Audio In: R/L
-DTV Box input: One
-DVR Input: One
-Radio Antenna Input: One
-GPS Antenna Input: One
Output
-Video Out: Two
-Audio Out: FR/FL/RR/RL
-Surround Stereo Output: 4 x 50w
-Subwoofer Out: One
Accessories
-User's Manual in English: One
-BMW 40 PIN Power Cable: One
-BMW 17 PIN Power Cable: One
-Can-bus Decoder: One
-USB OTG Cable: One
-RCA Cable: One
-GPS Antenna: One
-Free 4GB SD Card as gift: One
-Install Fittings : One
Последний раз редактировалось Антихрист; 14.10.2016 в 12:24.
