Старый 15.10.2008, 11:39 #15
P1086 Fuel Control Mixture Rich (Bank 2 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1087 O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1088 O2 Sensor Circuit Slow Response in Rich Control Range (Bank 1 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1089 O2 Sensor Circuit Slow Response in Lean Control Range (Bank 1 Sensor 2) (***(May not be applicable for Honda / Acura)***)
P1090 Pre-Catalyst Fuel Trim Too Lean Bank 1 (***(May not be applicable for Honda / Acura)***)
P1091 Pre-Catalyst Fuel Trim Too Rich Bank 1 (***(May not be applicable for Honda / Acura)***)
P1092 Pre-Catalyst Fuel Trim Too Lean Bank 2 (***(May not be applicable for Honda / Acura)***)
P1093 Pre-Catalyst Fuel Trim Too Rich Bank 2 (***(May not be applicable for Honda / Acura)***)
P1094 O2 Sensor Circuit Slow Response in Rich Control Range (Bank 2 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1095 O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 1 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1096 O2 Sensor Circuit Slow Switching From Lean to Rich (Bank 2 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1097 O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 1 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1098 O2 Sensor Circuit Slow Response after Coast Down Fuel Cutoff (Bank 2 Sensor 2) (***(May not be applicable for Honda / Acura)***)
P1100 MAF Intermittant (***(May not be applicable for Honda / Acura)***)
P1100 Manifold Absolute Pressure (MAP) Sensor Malfunction (Open/Short) (***(May not be applicable for Honda / Acura)***)
P1101 MAF Out Of Range (***(May not be applicable for Honda / Acura)***)
P1102 Manifold Absolute Pressure (MAP) Sensor Malfunction - Low Voltage (***(May not be applicable for Honda / Acura)***)
P1103 Manifold Absolute Pressure (MAP) Sensor Malfunction - High Voltage (***(May not be applicable for Honda / Acura)***)
P1105 MAP/BARO Switch Solenoid Valve (***(May not be applicable for Honda / Acura)***)
P1106 Manifold Absolute Pressure (MAP) sensor circuit intermittent high voltage
P1106 Barometric pressure circuit problem
P1107 Manifold Absolute Pressure (MAP) sensor circuit intermittent low voltage
P1107 Barometric pressure circuit low input
P1108 BARO to MAP signal circuit comparison too high
P1108 Barometric pressure circuit high input
P1110 Intake Valve Timing Control (Left Bank) (***(May not be applicable for Honda / Acura)***)
P1110 Atmospheric Pressure Sensor Low Input (***(May not be applicable for Honda / Acura)***)
P1111 Intake Air Temperature (IAT) sensor intermittent high voltage
P1111 Engine Coolant Temperature Radiator Outlet Sensor Low Input (***(May not be applicable for Honda / Acura)***)
P1111 Atmospheric Pressure Sensor High Input (***(May not be applicable for Honda / Acura)***)
P1112 Intake Air Temperature (IAT) sensor intermittent low voltage
P1112 Engine Coolant Temperature Radiator Outlet Sensor High Input (***(May not be applicable for Honda / Acura)***)
P1112 Atmospheric Pressure Sensor Range/Performance Problem (***(May not be applicable for Honda / Acura)***)
P1114 Engine Coolant Temperature (ECT) sensor circuit intermittent low voltage
P1114 Intake Air Temperature 2 Circuit Low Input (***(May not be applicable for Honda / Acura)***)
P1115 Engine Coolant Temperature (ECT) sensor circuit intermittent high voltage
P1115 Coolant Temperature Sensor Plausibility (***(May not be applicable for Honda / Acura)***)
P1115 Intake Air Temperature 2 Circuit High Input (***(May not be applicable for Honda / Acura)***)
P1116 Mass Or Volume Air Flow Circuit Range/Performance Problem (Bank 2) (***(May not be applicable for Honda / Acura)***)
P1116 ECT Sensor Out Of Range (***(May not be applicable for Honda / Acura)***)
P1117 Mass Or Volume Air Flow Circuit Low Input (Bank 2) (***(May not be applicable for Honda / Acura)***)
P1117 ECT Intermittent (***(May not be applicable for Honda / Acura)***)
P1118 Mass Or Volume Air Flow Circuit High Input (Bank 2) (***(May not be applicable for Honda / Acura)***)
P1120 Pedal Position Sensor Circuit (***(May not be applicable for Honda / Acura)***)
P1120 TPS Out Of Range Low (***(May not be applicable for Honda / Acura)***)
P1120 Secondary Throttle Position Sensor (Stps) (***(May not be applicable for Honda / Acura)***)
P1121 Throttle Position (TP) Sensor Inconsistent With MAF Sensor High Voltage
P1121 Pedal Position 1 Range/Performance Problem (***(May not be applicable for Honda / Acura)***)
P1122 Throttle Position (TP) Sensor Inconsistent With MAF Sensor Low Voltage
P1122 Pedal Position 1 Low Input (***(May not be applicable for Honda / Acura)***)
P1123 Pedal Position 1 High Input (***(May not be applicable for Honda / Acura)***)
P1124 TPS Out Of Self Test Range (***(May not be applicable for Honda / Acura)***)
P1125 TPS Intermittant (***(May not be applicable for Honda / Acura)***)
P1125 Tandem Throttle Position Sensor(***(May not be applicable for Honda / Acura)***)
P1126 Thermostat Function (***(May not be applicable for Honda / Acura)***)
P1127 Exhaust Not Warm Enough, Downstream Sensor Not Tested (***(May not be applicable for Honda / Acura)***)
P1128 MAP Lower Than Expected
P1129 MAP Higher Than Expected
P1129 Upstream O2 Sensors Swapped Bank To Bank (HO2S-11-21) (***(May not be applicable for Honda / Acura)***)
P1129 Downstream O2 Sensors Swapped Bank To Bank (HO2S-12-22) (***(May not be applicable for Honda / Acura)***)
P1130 Lack Of HO2S-11, Fuel Trim At Limit (***(May not be applicable for Honda / Acura)***)
P1130 Heated O2 Sensor (HO2S) 11 At Adaptive Limit (***(May not be applicable for Honda / Acura)***)
P1130 Swirl Control SOL/V (***(May not be applicable for Honda / Acura)***)
P1130 Front Right Oxygen Sensor Circuit Open (***(May not be applicable for Honda / Acura)***)
P1130 A/F Sensor Circuit Range/Performance (Bank 1 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1131 HO2S 11 Indicates Lean (***(May not be applicable for Honda / Acura)***)
P1131 Front Right Oxygen Sensor Circuit Shorted (***(May not be applicable for Honda / Acura)***)
P1132 O2 Sensor Heater Control Circuit (Bank 1 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1132 HO2S 11 Indicates Rich (***(May not be applicable for Honda / Acura)***)
P1133 Heated Oxygen Sensor (HO2S) insufficient switching bank 1 sensor 1 (Rear Bank)
P1133 O2 Sensor Heater Control Circuit (Bank 2 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1133 A/F Sensor Circuit Response (Bank 1 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1134 Heated Oxygen Sensor (HO2S) transition time ratio bank 1 sensor 1 (Rear Bank)
P1134 O2 Sensor Heater Circuit Signal Intermittent (Bank 1 Sensor 2) (***(May not be applicable for Honda / Acura)***)
P1134 Front Oxygen (A/F) Sensor Micro-Computer Problem (***(May not be applicable for Honda / Acura)***)
P1135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1135 Intake Valve Timing Control (Right Bank) (***(May not be applicable for Honda / Acura)***)
P1135 Front Left Oxygen Sensor Circuit Open (***(May not be applicable for Honda / Acura)***)
P1135 A/F Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1136 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1) (***(May not be applicable for Honda / Acura)***)
P1136 Front Left Oxygen Sensor Curcuit Shorted (***(May not be applicable for Honda / Acura)***)
P1137 O2 Sensor Heater Circuit Signal Intermittant (Bank 1 Sensor 2) (***(May not be applicable for Honda / Acura)***)
P1137 Lack Of HO2S-12 Switch Indicates Lean (***(May not be applicable for Honda / Acura)***)
P1138 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) (***(May not be applicable for Honda / Acura)***)
P1138 Lack Of HO2S-12 Switch Indicates Rich (***(May not be applicable for Honda / Acura)***)
P1139 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2) (***(May not be applicable for Honda / Acura)***)
P1139 Front Right Oxygen Sensor Heater Circuit Range (***(May not be applicable for Honda / Acura)***)
P1140 Mass or Volume Air Flow Circuit Range/Performance Problem (***(May not be applicable for Honda / Acura)***)
P1140 Intake Valve Timing Control Position Sensor (Left Bank) (***(May not be applicable for Honda / Acura)***)
P1140 Front Left Oxygen Sensor Heater Circuit Range (***(May not be applicable for Honda / Acura)***)
