Старый 15.10.2008, 11:40 #19
P1451 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal Low (***(May not be applicable for Honda / Acura)***)
P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1452 Diagnostic Module Tank Leakage (DM-TL) Switching Solenoid Control Circuit Signal High (***(May not be applicable for Honda / Acura)***)
P1453 Secondary Air Injection Pump Relay Control Circuit Electrical (***(May not be applicable for Honda / Acura)***)
P1454 Secondary Air Injection Pump With Series Resistor Control Circuit Electrical (***(May not be applicable for Honda / Acura)***)
P1456 Leak Detected In EVAP Control System
P1456 Heated Catalyst Heater Power Supply Open Circuit (Bank 1) (***(May not be applicable for Honda / Acura)***)
P1457 Leak Detected In EVAP Control System
P1457 Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 1) (***(May not be applicable for Honda / Acura)***)
P1459 Heated Catalyst Heater Power Supply Open Circuit (Bank 2) (***(May not be applicable for Honda / Acura)***)
P1460 Heated Catalyst Heater Power Switch Temperature Sensor Electrical (Bank 2) (***(May not be applicable for Honda / Acura)***)
P1460 WOT A/C Cutoff Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1461 Heated Catalyst Gate Voltage Signal Low (***(May not be applicable for Honda / Acura)***)
P1461 ACP Sensor High Voltage (***(May not be applicable for Honda / Acura)***)
P1462 Heated Catalyst Internal Control Module Checksum/ROM Error (***(May not be applicable for Honda / Acura)***)
P1462 ACP Sensor Low Voltage (***(May not be applicable for Honda / Acura)***)
P1463 Heated Catalyst Battery Temperature Sensor 1 Electrical (***(May not be applicable for Honda / Acura)***)
P1463 ACP Sensor Insufficent Pressure Change (***(May not be applicable for Honda / Acura)***)
P1464 Heated Catalyst Battery Temperature Sensor 2 Electrical (***(May not be applicable for Honda / Acura)***)
P1464 A/C Demand Out Of Range (***(May not be applicable for Honda / Acura)***)
P1464 Fuel Level Sensor Circuit (Ground Signal) (***(May not be applicable for Honda / Acura)***)
P1465 Heated Catalyst Battery Temperature Sensor 1 or 2 Plausibility (***(May not be applicable for Honda / Acura)***)
P1466 Heated Catalyst Power Switch Temperature Sensor Plausibility (***(May not be applicable for Honda / Acura)***)
P1467 Heated Catalyst Comparison Battery Voltages of Power Switches Plausibility (***(May not be applicable for Honda / Acura)***)
P1468 Heated Catalyst Battery Disconnecting Switch Plausibility (***(May not be applicable for Honda / Acura)***)
P1469 Low A/C Cycling Period (***(May not be applicable for Honda / Acura)***)
P1470 Leakage Diagnostic Pump Control Circuit Electrical (***(May not be applicable for Honda / Acura)***)
P1472 Diagnostic Module Tank leakage (DM-TL) Switching Solenoid Control Circuit Electrical (***(May not be applicable for Honda / Acura)***)
P1473 Diagnostic Module Tank leakage (DM-TL) Pump Current Plausibility (***(May not be applicable for Honda / Acura)***)
P1474 HCF Primary Circuit Failure (***(May not be applicable for Honda / Acura)***)
P1474 LFC Primary Circuit Failure (***(May not be applicable for Honda / Acura)***)
P1475 Leakage Diagnostic Pump Reed Switch Did Not Close (***(May not be applicable for Honda / Acura)***)
P1476 Leakage Diagnostic Pump Clamped Tube (***(May not be applicable for Honda / Acura)***)
P1476 Too Little Secondary Air (***(May not be applicable for Honda / Acura)***)
P1477 Leakage Diagnostic Pump Reed Switch Did Not Open (***(May not be applicable for Honda / Acura)***)
P1477 Too Much Secondary Air (***(May not be applicable for Honda / Acura)***)
P1477 MFC Primary Circuit Failure (***(May not be applicable for Honda / Acura)***)
P1478 Battery Temp Sensor Volts Out of Limit (***(May not be applicable for Honda / Acura)***)
P1479 Transmission Fan Relay Circuit (***(May not be applicable for Honda / Acura)***)
P1479 HFC Primary Circuit Failure (***(May not be applicable for Honda / Acura)***)
P1480 PCV Solenoid Valve (***(May not be applicable for Honda / Acura)***)
P1480 Cooling Fan Relay 1 Circuit High Input (***(May not be applicable for Honda / Acura)***)
P1482 Catalyst Temperature Sensor Circuit Shorted Low (***(May not be applicable for Honda / Acura)***)
P1483 Engine Cooling System Performance
P1483 Catalyst Temperature Sensor Circuit Shorted High (***(May not be applicable for Honda / Acura)***)
P1484 Catalytic Converter Overheat Detected (***(May not be applicable for Honda / Acura)***)
P1485 Air Injection Solenoid Circuit (***(May not be applicable for Honda / Acura)***)
P1486 Evap Leak Monitor Pinched Hose (***(May not be applicable for Honda / Acura)***)
P1487 Hi Speed Rad Fan CTRL Relay Circuit (***(May not be applicable for Honda / Acura)***)
P1488 Auxiliary 5 Volt Supply Output Too Low (***(May not be applicable for Honda / Acura)***)
P1489 High Speed Fan CTRL Relay Circuit (***(May not be applicable for Honda / Acura)***)
P1490 Low Speed Fan CTRL Relay Circuit (***(May not be applicable for Honda / Acura)***)
P1490 Vacuum Cut Valve Bypass Valve (Circuit) (***(May not be applicable for Honda / Acura)***)
P1491 Malfunction In EGR System
P1491 Rad Fan Control Relay Circuit (***(May not be applicable for Honda / Acura)***)
P1491 Vacuum Cut Valve Bypass Valve (***(May not be applicable for Honda / Acura)***)
P1492 EVAP Canister Purge Control/Solenoid Valve (Circuit) (***(May not be applicable for Honda / Acura)***)
P1492 Ambient/Batt Temp Sen Volts Too High (***(May not be applicable for Honda / Acura)***)
P1493 Ambient/Batt Temp Sen Volts Too Low (***(May not be applicable for Honda / Acura)***)
P1493 EVAP Canister Purge Control Valve/Solenoid Valve (***(May not be applicable for Honda / Acura)***)
P1494 Leak Detection Pump Switch or Mechanical Fault (***(May not be applicable for Honda / Acura)***)
P1495 Leak Detection Pump Solenoid Circuit (***(May not be applicable for Honda / Acura)***)
P1496 5 Volt Supply Output Too Low (***(May not be applicable for Honda / Acura)***)
P1498 Voltage Problem In EGR Valve Position Sensor Circuit
P1498 High speed Rad Fan Ground CTRL Rly Circuit (***(May not be applicable for Honda / Acura)***)
P1500 Idle Speed Control Valve Stuck Open (***(May not be applicable for Honda / Acura)***)
P1500 Vehicle Speed Sensor (VSS) Intermittant (***(May not be applicable for Honda / Acura)***)
P1500 Generator FR Terminal Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1501 Idle Speed Control Valve Stuck Closed (***(May not be applicable for Honda / Acura)***)
P1501 Vehicle Speed Sensor (VSS) Out Of Range (***(May not be applicable for Honda / Acura)***)
P1502 Idle Speed Control Valve Closing Solenoid Control Circuit Signal High (***(May not be applicable for Honda / Acura)***)
P1502 Vehicle Speed Sensor (VSS) Intermittant (***(May not be applicable for Honda / Acura)***)
P1502 Idle Speed Control Valve Closing Solenoid Control Circuit Signal Low (***(May not be applicable for Honda / Acura)***)
P1503 Idle Speed Control Valve Closing Solenoid Control Circuit Signal Low (***(May not be applicable for Honda / Acura)***)
P1504 Idle Speed Control Valve Closing Solenoid Control Open Circuit (***(May not be applicable for Honda / Acura)***)
P1504 Idle Air Control (IAC) Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1505 Idle Speed Control Valve Closing Solenoid Control Circuit Electrial (***(May not be applicable for Honda / Acura)***)
P1505 Idle Air Control At Adaptive Clip (***(May not be applicable for Honda / Acura)***)
P1506 Idle Speed Control Valve Open Solenoid Control Circuit Signal High (***(May not be applicable for Honda / Acura)***)
P1506 Idle Air Control System Overspeed Error (***(May not be applicable for Honda / Acura)***)
P1507 Idle Speed Control Valve Open Solenoid Control Circuit Signal Low (***(May not be applicable for Honda / Acura)***)
P1507 Idle Air Control System Underspeed Error (***(May not be applicable for Honda / Acura)***)
P1507 Idle Control System Malfunction (Fail-Safe) (***(May not be applicable for Honda / Acura)***)
P1508 Idle Air Control (IAC) System - Low RPM
P1508 Idle Air Control Valve Circuit Failure
P1508 Idle Speed Control Valve Opening Solenoid Control Open Circuit (***(May not be applicable for Honda / Acura)***)
P1509 Idle Speed Control Valve Opening Solenoid Control Circuit Electrial (***(May not be applicable for Honda / Acura)***)
P1510 Idle Speed Control Valve Stuck (***(May not be applicable for Honda / Acura)***)
P1511 DISA Control Circuit Electrical (***(May not be applicable for Honda / Acura)***)
P1512 DISA Control Circuit Signal Low (***(May not be applicable for Honda / Acura)***)
P1513 DISA Control Circuit Signal High (***(May not be applicable for Honda / Acura)***)
P1516 Inlet Manifold Runner Control Input Error (Bank 1) (***(May not be applicable for Honda / Acura)***)
P1517 Inlet Manifold Runner Control Input Error (Bank 2) (***(May not be applicable for Honda / Acura)***)
P1518 Inlet Manifold Runner Control Stuck Open (***(May not be applicable for Honda / Acura)***)
P1518 Starter Switch Circuit Low Input (***(May not be applicable for Honda / Acura)***)
P1519 Malfunction In IAC Valve Circuit
P1519 "A" Camshaft Position Actuator Bank 1 (***(May not be applicable for Honda / Acura)***)
P1519 Inlet Manifold Runner Control Stuck Closed (***(May not be applicable for Honda / Acura)***)
P1520 Intake Manifold Runner Control (IMRC) circuit malfunction
P1520 "B" Camshaft Position Actuator Bank 1 (***(May not be applicable for Honda / Acura)***)
