Сообщение от Tyler Если не ошибся:
4262 glow plug zylinder 6, control
4212 Glow plug cylinder 1
LVDS = Low Voltage Differential Signal
If there is a fault entry related to the LVDS (FC# A468), the function of the CCC/M-ASK and the cable from the CCC/M-ASK to the CID should be checked first.
The LVDS driver in the CCC/M-ASK receives the digital RGB signals from the graphic processor, converts the RGB signals and sends them via the LVDS cable to the Central Information Display. |
Спасибо за ответ. А эту ошибку не знаете 4587 ???
А где можно скачать список ошибок для ИНПЫ?
