Старый 02.06.2010, 00:12 #10
  • Мануал (а точнее просто User Release Notes) ISTA Workshop System. ISTA Version 2.19. Январь 2010. Формат PDF. 11 страниц.
Содержание:
1. IMPROVEMENTS .................................................. .................................................. ....................... 4
1.1 SYNCHRONISATION OF PROCEDURES CREATED OFFLINE .................................................. ............ 4
1.2 PROVISION OF NEW DIAGNOSTIC AND REPAIR CONTENT .................................................. .............. 4
1.3 IDENTIFICATION OF OLD SERIES (E.G. E32, E34) IS ONCE AGAIN POSSIBLE .................................... 4
1.4 EVALUATION OF SPECIAL EQUIPMENT ITEMS .................................................. .............................. 4
1.5 VEHICLE TEST: SYSTEM MESSAGE: UNKNOWN CONTROL UNIT VERSION ......................................... 4
1.6 MATCH-UP BETWEEN CONTROL UNIT TREE AND LIST .................................................. ................... 4
1.7 FREE TEXT SEARCH .................................................. .................................................. ................ 5
1.9 FREE MEASUREMENT TECHNOLOGY .................................................. .......................................... 5
1.10 INSPECTION PLAN CALCULATION....................................... .................................................. ......... 5
1.11 MISSING NOTE TEXTS IN REPAIR MANUALS .................................................. ................................. 5
1.12 IMPROVEMENTS IN THE PROCESS REPORT .................................................. ................................. 5
2. INNOVATIONS .................................................. .................................................. ........................... 6
2.1 DISPLAY TYPE APPROVAL NUMBER .................................................. ............................................ 6
3. RESTRICTIONS .................................................. .................................................. .......................... 7
3.1 WORKFLOWS ON HIDDEN NODES APPEAR IN THE HITLIST .................................................. ............ 7
3.2 QUICK DELETE: INCOMPLETE DELETION OF ALL FAULT MEMORIES.......................................... ........ 7
3.3 EVALUATION OF VALIDITIES ON IDES WORKFLOWS (OLD SERIES)........................................... ....... 8
3.4 FREE TEXT SEARCH .................................................. .................................................. ................ 8
3.5 FILTERING BY CHANGE DATE DOES NOT FUNCTION .................................................. ..................... 8
3.6 STATUS OF WORKFLOWS ALREADY PERFORMED IS NOT DISPLAYED CORRECTLY ............................ 9
3.7 ERROR IN DISPLAY OF PROCESS REPORT............................................ ......................................... 9
3.8 INTERRUPT / TERMINATE PROCEDURE .................................................. ....................................... 9
3.9 OFFSET SHIFT IN OSCILLOSCOPE .................................................. ............................................ 10
3.10 MISSING VEHICLE TEST AFTER OPENING OF A WORKFLOW BY SELECTION OF BASIC FEATURES
OR INPUT OF CHASSIS NUMBER .................................................. ............................................... 10
3.11 CONNECTION FAILURES WITH ICOM D .................................................. .................................... 11
Тип файла: pdf www.bmwpost.ru_2.19_release-notes.pdf (59.6 Кб, 637 просмотров)
Эти 5 пользователя(ей) сказали Спасибо Tyler за сообщение:
cantool (09.08.2011), dOrOdO (01.06.2014), Morauder (03.04.2011), stylusE70 (16.10.2012), zalimhan74 (11.04.2015)
