Тема: BMW Inpa/Ediabas
Старый 31.10.2008, 23:36 #18
Сказал спасибо: 1,546
Поблагодарили 10,579 раз(а) в 1,957 сообщениях
  • Мануал по BMW INPA - часто задаваемые вопросы. Frequently Asked Questions about EDIABAS, INPA and the Tool Set. Формат PDF. 32 страницы.
Также по ошибкам можно почитать в этом мануале: тут.
Содержание:
1 EDIABAS Error Messages .................................................. ............................................ 4
1.1 Driver Error............................................. .................................................. .................... 4
1.2 DirectNt.sys can’t be opened............................................ ............................................ 4
1.3 IFH-0002: Interface isn’t connected or doesn’t respond........................................... ..... 4
1.4 IFH-0003: Data transmission HOST/Interface failed............................................ ......... 4
1.5 IFH-0010: Data transmission to control unit disturbed .................................................. 5
1.6 IFH-0013: Command not implemented....................................... .................................. 5
1.7 Error: EBAS32.EXE not found or illegal version! .................................................. ........ 5
1.8 EDIABAS error: Error (95) SYS-0005: OBJECT FILE NOT FOUND ............................ 6
1.9 Createfile_error: OPEN CONNECTION; IFH 0018- INITIALIZATION ERROR............. 6
1.10 Battery and Ignition not recognised .................................................. ............................ 6
1.11 Warning when starting OBD Setup............................................. .................................. 7
1.12 ERROR C1015: Too Many String Variables in Job............................................... ........ 8
1.13 Failure: EDIABAS Fehler 159, NET-0009: TIMEOUT........................................... ........ 8
1.14 Failure: The name of the file or folder can’t be changed........................................... .... 9
2 Error Message INPA.............................................. .................................................. ...... 10
2.1 APLDLL or API32.DLL can’t be found. .................................................. ..................... 10
2.2 Error Message 0020: Incorrect or Missing Driver. The programme will be aborted!.... 12
2.3 SYS-00002: ECU variation description file not found............................................. ..... 12
2.4 INPA Error: Error at Compiling à Abort! .................................................. .................. 13
2.5 IFH-0018: Inizialisation Error – INPA doesn’t work but Toolset yet ............................. 14
2.6 IFH-0027: IFH not found à The Programm was aborted! .......................................... 14
2.7 INPA Error: Opening Inpa – Transmission error returned a_0x2 ................................ 15
2.8 INPA Error: Only a white screen appears when you run INPALOAD.EXE. ................. 15
2.9 INPA Error: DTM is no longer supported .................................................. .................. 16
2.10 INPA Error: Bridge16.exe can’t be initialised .................................................. ............ 16
2.11 Error when opening the error file à abort:............................................ ...................... 17
2.12 Compiler: File: \INPA\DEUTSCH\***.OUT not found! ................................................. 17
3 Tool Set Error Messages .................................................. ............................................ 18
3.1 EDIABAS error 100: SYS-0010: INITIALIZATION ERROR ........................................ 18
3.2 EDIABAS Error 126 (only up to Ediabas V6.4.x)........................................... .............. 18
3.3 IFH-0006: Command not accepted and IFH-0018: Initialization Error and IFH-0038:
Interface Command not implemented....................................... .................................. 18
3.4 IFH-0006: Command not accepted.......................................... ................................... 19
3.5 IFH-0009: ECU isn’t connected or doesn’t respond........................................... ......... 20
3.6 SYS-0002: ECU OBJECT FILE NOT FOUND............................................. ............... 20
3.7 SYS-0005: Controller description file not found. The programme will be aborted! ...... 20
3.8 ToolSet Error: Runtime error ’372’............................................. ................................. 21
3.9 Tool Set Error: Run-time error ’5’ – Invalid Procedure Call ......................................... 21
3.10 Tool Set Problem: If an SGBD is opened, then only the hourglass appears and the
SGBD is not loaded. .................................................. ................................................. 21
3.11 EDIABAS error 20: IFH-0010: Data transmission to control unit disturbed ................. 21
3.12 EDIABAS Error 134: API-0014: Result not found .................................................. ..... 22
3.13 It takes too long to load an SGBD in the Tool Set .................................................. .... 22
3.14 Black Windows in the Tool Set .................................................. ................................. 22
4 General Questions .................................................. .................................................. .... 23
4.1 Installation of EDIABAS and INPA.............................................. ................................ 23
4.2 xBD-Export of SGBDs, Group SGBDs, INPA scripts and INPA configuration files using
the ECCO Web Client .................................................. .............................................. 23
4.3 How can I find out if the serial interface COM1 has been taken?................................ 25
4.4 How do I start INPA?............................................. .................................................. ... 26
4.5 How can I switch between OBD and ADS interfaces? ................................................ 26
4.6 In which directory structure is OBD.ini saved?............................................ ................ 27
4.7 How can I find out what interface I installed with INPA? ............................................. 27
4.8 How do I find out what EDIABAS package is installed?........................................ ...... 27
4.9 How can I uninstall EDIABAS or INPA?............................................. ......................... 27
4.10 How can tell if the EDIABAS server is running as a 16-bit or a 32-bit application? ..... 27
4.11 What is the difference between \EDIABAS\bin\ToolSet.exe and
\EDIABA\bin\Tool32.exe?........................... .................................................. .............. 28
4.12 What is an SGBD and what is its connection to EDIABAS? ....................................... 28
4.13 Where are the individual SGBD names and their meanings given in plain English?... 28
4.14 What is a Job? .................................................. .................................................. ....... 28
4.15 What do SGBDs with the name _xxx mean?............................................. ................. 29
4.16 What is the group file used for?.............................................. .................................... 29
4.17 Diagnostics Index .................................................. .................................................. ... 29
4.18 Variation Index .................................................. .................................................. ....... 29
4.19 What is the meaning of the file EDIABAS.ini? .................................................. .......... 29
4.20 How is the simulation file connected to the trace file?............................................. .... 31
4.21 Why have an XBD Generator? .................................................. ................................. 31
4.22 What are the prerequisites for remote access via TCP/IP? ........................................ 31
4.23 What is the VC Tool and when is it used? .................................................. ................ 32
4.24 What is the KVP Editor?........................................... .................................................. 32
Тип файла: pdf www.bmwpost.ru_inpa_problems_FAQ.pdf (643.3 Кб, 4666 просмотров)
Эти 24 пользователя(ей) сказали Спасибо Tyler за сообщение:
-bo- (31.05.2011), ATV (13.05.2016), B1MMER (18.03.2013), BAM355 (30.07.2011), Bavarian Aviation (16.11.2017), BMW520i (28.10.2011), Dep (14.08.2010), ericOTT (14.04.2014), Evi (05.07.2012), Hckid90 (27.03.2017), Hook (31.10.2011), igorunia (09.06.2012), keyway (11.09.2011), Manmart (11.09.2011), Morauder (03.04.2011), Nathaniel (21.10.2011), Petrivsky (14.12.2010), Quattrovod (18.04.2012), skipex (02.06.2011), Valeriy_x3 (24.08.2010), VNK57 (08.09.2011), Zexerlt (24.06.2014), Азиат (29.05.2013), Колянн (18.10.2011)
