Тема: BMW Inpa/Ediabas
Старый 31.10.2008, 23:36 #11
  • Мануал WinKFPT 5.1 User's Guide. Формат PDF. 190 страниц. Язык - английский.
Содержание:
1 FOREWORD.......................................... .................................................. ............................. 9
1.1 Using this User's Guide and the Online Help .................................................. ............................. 9
1.2 About This User's Guide............................................. .................................................. ...... 10
1.3 Conventions Used.............................................. .................................................. .............. 11
2 INTRODUCTION...................................... .................................................. .................. 12
2.1 About WinKFPT .................................................. .................................................. .............. 12
2.2 Possibilities in WinKFPT .................................................. .................................................. .. 12
2.2.1 Multiple Instancing Capability .................................................. ....................................... 12
2.2.2 Operating Modes .................................................. .................................................. ..... 13
2.2.3 Programming of ECUs in Dialog Mode .................................................. ........................... 14
2.2.4 Programming of ECUs in Batch Mode .................................................. ............................ 14
2.3 Architecture of WinKFPT........................................... .................................................. .......... 15
3 FIRST STEPS .................................................. .................................................. .............. 16
3.1 System Requirements of WinKFPT .................................................. .................................... 16
3.2 Installing WinKFPT........................................... .................................................. ................ 16
3.3 Directory Structure of WinKFPT........................................... ................................................ 17
3.3.1 Configuration of the basic directory for the working directories of WinKFPT.................... 22
3.4 Configuring WinKFPT .................................................. .................................................. ....... 23
3.4.1 Configuration in COAPI.INI .................................................. ........................................... 23
3.4.2 Configuration in WINKFPT.INI .................................................. ...................................... 26
3.4.3 Configuration for Expert Mode .................................................. ...................................... 32
3.4.4 Configuration in EDIABAS.INI....................................... ................................................. 37
3.5 Reference Configuration of WinKFPT........................................... .......................................... 38
4 STARTING WINKFPT........................................... .................................................. .............. 40
4.1 Calling Parameters of WinKFPT .................................................. ....................................... 40
4.1.1 Type Description of the Calling Parameters of WinKFPT........................................... ......... 42
4.2 Status Displays of WinKFPT........................................... .............................................. 43
4.3 Starting WinKFPT in Compile Mode.............................................. ............................................. 46
4.4 Starting WinKFPT in Batch Mode.............................................. .............................................. 48
4.4.1 Control File for Batch Mode in Comfort Mode.............................................. ........................ 51
4.4.2 Control File for Batch Mode in Expert Mode .................................................. ...................... 53
4.4.3 Starting a Programming Job in Batch Mode .................................................. ...................... 55
4.4.4 Switching HW Interface and Diagnosis Protocol in Batch Mode ......................................... 57
4.4.5 Starting Several Instances in Batch Mode.............................................. ............................. 58
4.5 Starting WinKFPT in Dialog Mode.............................................. ....................................... 59
4.5.1 Starting Several Instances in Dialog Mode.............................................. ............................ 59
5 WINKFPT'S MAIN MENU.............................................. ..............................
Menu.............................................. .................................................. ......................... 61
5.1.1 Display CABI.ERR.......................................... .................................................. ............. 62
5.1.2 Display ERROR.LOG .................................................. .................................................. .. 62
5.1.3 Display PABD Parameters .................................................. ............................................ 62
5.1.4 Display HW History .................................................. .................................................. ..... 62
5.1.5 Display ZB History........................................... .................................................. .............. 62
5.1.6 Display ZB Rules............................................. .................................................. .............. 62
5.1.7 Display API Trace File.............................................. .................................................. ..... 63
5.1.8 Display IFH Trace File.............................................. .................................................. ..... 63
5.1.9 Display Batch Mode.............................................. .................................................. ......... 63
5.2 Import/Export Menu.............................................. .................................................. .......... 64
5.2.1 Import Submenu .................................................. .................................................. ........ 64
5.2.2 Export Submenu .................................................. .................................................. ........ 82
5.2.3 Deleting Assembly Line Data.............................................. .............................................. 93
5.3 Communication Menu .................................................. ................................................ 96
5.3.1 Selecting (Choosing) a HW Interface .................................................. ............................. 97
5.3.2 Selecting (Choosing) a Diagnosis Protocol .................................................. .................... 99
5.4 Configuration Menu.............................................. .................................................. ..... 100
5.5 Help Menu.............................................. .................................................. ........ 103
5.5.1 Contents - Calling the Online Help.............................................. ....................................... 103
5.5.2 Info - Version Information of WinKFPT........................................... ................................... 104
5.6 End Menu.............................................. .................................................. 106
5.6.1 Exit 106
6 FUNCTIONS OF WINKFPT .................................................. .............................................. 107
6.1 Function Start Menu: Operating Modes of WinKFPT........................................... ...................... 110
6.1.1 Comfort Mode .................................................. .................................................. 112
6.1.2 Expert Mode.............................................. .................................................. ......... 116
7 FUNCTION PHASES IN COMFORT MODE .................................................. ...................... 119
7.1 Functions of the Programming Settings Phase in Comfort Mode .............................................. 120
7.1.1 Function: Entering a ZUSB Number .................................................. .............................. 121
7.1.2 Function: Selecting a ZUSB number............................................ .................................... 124
7.1.3 Function: Updating an Assembly Identification.................................... .............................. 125
7.1.4 Function: Entering a Vehicle Identification Number............................................ ............... 127
7.1.5 Function: Done (Comfort Mode) .................................................. ...................................... 129
7.2 Functions of the Programming Execution Phase in Comfort Mode............................................ 130
7.2.1 Function: Flash Programming....................................... .................................................. . 131
7.2.2 Function: Programming Update............................................ .......................................... 134
8 FUNCTION PHASES IN EXPERT MODE.............................................. ................................. 137
8.1 Functions of Programming Settings Phase Level 1 in Expert Mode .......................................... 138
8.1.1 Function: Loading a PABD.............................................. ................................................. 139
8.1.2 Function: Loading a P-SGBD.............................................. ............................................... 141
8.2 Functions of Programming Settings Phase Level 2 in Expert Mode .......................................... 143
8.2.1 Function: Loading an ECU address........................................... ........................................ 144
8.2.2 Function: Loading a Data Set – NAAB File.............................................. .......................... 145
8.2.3 Function: Loading a Data Set – Program File.............................................. ...................... 147
8.2.4 Function: Loading a Data Set – Data File.............................................. ............................ 150
8.2.5 Function: Done (Expert Mode) .................................................. ....................................... 153
8.3 Functions of the Programming Execution Phase in Expert Mode .............................................. 154
8.3.1 Function: Programming a NAAB Data Set............................................... .......................... 155
8.3.2 Function: Programming a Program Data Set............................................... ...................... 157
8.3.3 Function: Programming a Data Data Set .................................................. ......................... 159
9 GENERAL FUNCTIONS .................................................. .................................................. .... 161
9.1 Special Functions......................................... .................................................. .............. 162
9.1.1 Function: Reading the UIF............................................... ............................................ 163
9.1.2 Function: Reading the ECU Baudrates......................................... ............................... 165
9.1.3 Function: Reading and Writing the Calibration Values ................................................. 167
9.1.4 Function: VS20/DS2 Mode .................................................. ........................................ 168
9.1.5 Function: EWS Alignment......................................... .................................................. .. 169
9.1.6 Function: Done .................................................. .................................................. ......... 169
9.2 Diagnosis Functions......................................... .................................................. ............ 170
9.2.1 Function: Displaying the ECU Status............................................ ............................ 171
9.2.2 Function: Reading the ECU Identification.................................... .................................... 173
9.2.3 Function: Reading the ECU Internal Temperature....................................... .................... 174
9.2.4 Function: Done .................................................. ................................................ 175
10 ERROR HANDLING IN WINKFPT .................................................. ....................................... 176
10.1 Displaying Errors .................................................. .................................................. ... 177
10.2 Description and Elimination of Frequently Occurring Errors............................................ ........ 178
10.2.1 Errors When Starting WinKFPT........................................... ........................................... 178
10.2.2 Errors When Importing Assembly Line Data.............................................. ..................... 179
10.2.3 Errors When Entering Flash Data.............................................. ..................................... 180
10.2.4 Errors During Data Programming....................................... ............................................. 185
Тип файла: pdf www.bmwpost.ru_Handb-winkfpt32_5.1__v1.9_eng[1].pdf (3.53 Мб, 2501 просмотров)
Эти 13 пользователя(ей) сказали Спасибо Tyler за сообщение:
DG0884 (11.05.2011), GMPROF (07.03.2013), keyway (11.09.2011), kroxx (09.08.2020), Oleg Ilin (11.08.2021), skipex (02.06.2011), tercy (17.06.2015), Valeriy_x3 (24.08.2010), zalimhan74 (08.12.2014), Zeke (20.03.2013), Zexerlt (24.06.2014), Владимир38 (22.01.2014), юран1954 (01.08.2010)
