Тема: BMW e30
Старый 04.11.2008, 23:29 #2
  • BMW E30, схемы электрические для машин 1983-1992 годов .pdf Язык английский. Electrical troubleshooting manuals (ETM) для автомобилей BMW третьей серии в корпусе E30. Скачать тут.
  • 1990 BMW 325iX Electrical Troubleshooting Manual. Электросхемы (ETM) для 1990 BMW 325iX. Harness and Schematics. 12,9Мб.
This manual is divided into following sections: Index, How to Use This Manual, Wire Size Conversion Chart, Wiring Diagram and Electrical Parts Symbols, Systematic Troubleshooting, Connector Views, Power Distribution Box, Fuse Data, Component Location Chart, Component Location View, and Splice Locations Views.
This manual also covers topics on: Power Distribution System, Charging and Starting System, Electronics Injection System, Supplemental Restraint System, Brake Warning System, Antilock Braking System, Power Mirror, Central Locking, Power Windows, Seats, Sunroof, Body Electrical System, Wiper and Washer, Instrument Cluster, Active Check Control, Light Switch Details, Headlight, Turn and Hazard Lights, Heating and Air Conditioning, Radio, Antenna and Power Antenna, etc. Here is a quotation from the voltage drop testing section.
“Wires, connectors and switches are designed to conduct current with a minimum loss of voltage. A voltage drop of more than one volt indicates a problem. To test a voltage drop, connect the voltmeter leads to connectors at either end of circuit’s suspected problem area. The positive lead should be connected to the connector closest to the power source. The voltmeter will show the voltage drop between these two points.”
Cкачать тут.
Электросхемы ETM онлайн для BMW 3 e30: Схема BMW 3 E30 1983 | Схема BMW 3 E30 1986 | Схема BMW 3 E30 1992 | Схема BMW 3 E30 ix 1989 | Схема BMW 3 E30 M3 1991
Эти 2 пользователя(ей) сказали Спасибо Tyler за сообщение:
brazdol (26.02.2011), Slavan11 (29.12.2014)
