Старый 06.08.2010, 22:25 #11
Аватар для Loginov
Авто: E46 , Lincoln Conti 73
Или другой вариант :
After New Year and cold head was found the way to combine DIS5x with DIS44. Procedure is following:
1) Install DIS5x base
2) Prepare "special" DIS5x Progman (using rar and ultraiso) :
2.1. remove from original dis5x progman iso
- packages\data\progmcfg.tar
- packages\scripts\i95progm
2.2. add from dis 44 progman to "special" dis5x progman iso
- packages\data\sgc_ecu.tar
- packages\data\sgcupdat.tar
- packages\scripts\i95sgcup
- DAT.XX\sgc
3) Mount "Special" DIS5x pogman to VMWare CD and start DIS
4) Go to Administration->activate CD->DIS install (note not update - only install), enter password, installation must start.
5) After installation enjoy the DIS5X diagnostic capabilities with DIS44 coding/programming.
Note: During playing with looking-for above procedure i found that in original DIS44 there are no files what needed for programming itself (like xx.0pa xx.0da etc). May ba i just not found it
The coding in DIS44 (i suppose it sgc dir in /home) - is more new than sgc from SSS27.2 it mean that for full combination DIS and SSS we need - above procedure, than install CIP for DIS and than integrate to CIP files from last SSS.
To open Rolls Royce
log as a root
/home/bin/brand.sh
Последний раз редактировалось Loginov; 06.08.2010 в 22:25.
Loginov вне форума   Ответить с цитированием
