Старый 11.09.2010, 21:04 #1
Авто: BMW 530TD
E R R O R M E M O R Y R E P O R T -------------------------------------
Date: 09/11/10 16:36:36 ECU: DDE40KW0 JobStatus: OKAY Variant: DDE40KW0-------------------------------------------------------------
RESULT: 1 errors in error memory !-------------------------------------------------------------
4496 Rail-pressure plausibility
Error frequency : 1 Logistic counter: 37
Engine speed 3271.73 1/min
fuel pre-supply pressure 3.70 bar
Einspritzmenge 61.96 mm^3
RPC rail pressure 975.90 bar
Fehler aufgetreten bei 248060.00 km
Error not present Control deviation over engine speed too great
Errorcode: 11 90 25 01 70 20 83 E7 79 A2 60 E6 00 00 00 00 00 00 00 00 00 00 00 00 00 ================================================== ===========
замена клапана на тнвд и замена датчика на топливной рейке резулььтатов не дало
Последний раз редактировалось erasun; 11.09.2010 в 21:05.
erasun вне форума
