Старый 22.12.2010, 23:45 #1
Авто: E39 3.0d
По умолчанию Помогите обьяснить
КАК именно сделать это?Я непонимаю как через USB можно соеденить два компа если на одном диск отформатирован?
2. Next you need to create a FAT32 partition that is EXACTLY 18.635 GB. This can be done in two ways:
Firstly, you can use a Win98 boot CD and the fdisk function to create it as per Morroman’s guide; however I find the next method to be LOADS MORE RELIABLE:
My method: Hook your hard drive onto your laptop via USB (there are cables out there that allow you to turn the hard drive into an external hdd) running windows XP or Vista (I’ve not tried it on another operating system)
Right Click on “My Computer Icon” and go into “Manage”
This will bring up a “Computer Management Screen” – click on Disk Management on the left side column and go into it – you should see your cleanly wiped hard drive.
Right click on the hard drive and create a partition for 18.635 GB and format it into FAT32.
Once complete, remove your hard drive and put it in your IBM T30
JN.Shadow вне форума
