Подскажите пож. методы лечения
F E H L E R S P E I C H E R L E S E N
Datum: 03.02.2011 13:06:15
ECU: VGSG83
JobStatus: OKAY
Variante: VGSG83
ERGEBNIS: 2 Fehler im Fehlerspeicher !
5462 5462 Ошибка привода или увеличение потребляемой мощности fpr сцепления
Fehlerhдufigkeit: 2
Logistikzдhler : 36
1. Umweltsatz
Kilometerstand 90664 km
Input voltage KL30 12.13 Volt
KL15 State CAN CAN Signal OK -- KL15 off 0-n
KL15 internal KL15 off 0-n
Engine speed CAN Signal OK -- VKM off 0-n
Reset-Source NO RESET 0-n
iSM -40.00 Ampere
BarrierActPosLim 1288.00 Nm
error counter calibration try 0.00 1
BarrierError 0.00 1
BarrierMainState 57.00 1
error counter timeout 0.00 1
2. Umweltsatz
iSM -39.50 Ampere
BarrierActPosLim 1488.00 Nm
BarrierError 0.00 1
Implausible signal or value
Test conditions not yet fulfilled
Error not present now, but already stored
Error would not cause a warning lamp to light up
Fehlercode: 54 62 38 02 24 2C 45 61 E0 B0 A1 00 00 39 00 2C
45 61 E0 B1 BA 00 00 39 00
54C4 54C4 первичная калибровка дефективна
Fehlerhдufigkeit: 5
Logistikzдhler : 39
1. Umweltsatz
Input voltage KL30 12.38 Volt
KL15 State CAN CAN Signal OK -- KL15 on 0-n
KL15 internal KL15 on 0-n
iSM -2.50 Ampere
BarrierActPosLim 0.00 Nm
BarrierError 11.00 1
BarrierMainState 116.00 1
2. Umweltsatz
Input voltage KL30 11.75 Volt
iSM -1.00 Ampere
Test conditions fulfilled
Fehlercode: 54 C4 28 05 27 2C 45 63 E5 FB 00 00 0B 74 00 2C
45 5E E5 FE 00 00 0B 74 00
