Старый 09.02.2011, 17:36 #11
  • Официальный мануал по АКПП ZF 6HP26X / 6HP28X. 42 страницы. Техническая информация + каталог деталей. Язык - английский.
Содержание:
6HP26X / 6HP28X
Technical Information
Torque, Gear Ratio & Weight______________________________________2
Oil Capacity__________________________________________ _________2
6HP26X / 6HP28X Lubricants_____________________________________2
6HP26X / 6HP28X Technical Literature______________________________2
6HP26X / 6HP28X General Transmission Oil Filling Procedure___________3-7
How To Use This Catalog_________________________________________8
Type Plate Information_______________________________________ ____9
6HP26X 1068 020 XXX / 6HP28X 1068 050 XXX
Spare Parts
Gearbox Housing Group__________________________________________10
Torque Converter Group_________________________________________11
Oil Supply Group_____________________________________________ __12
Front Planetary Group___________________________________________13
Rear Planetary Group____________________________________________1 4
Coupling A Group_____________________________________________ __15
Coupling B Group_____________________________________________ __16
Coupling C Group_____________________________________________ __17
Coupling D Group_____________________________________________ __18
Coupling E Group_____________________________________________ __19
Output Group_____________________________________________ _____20
Filter Group
Filter General__________________________________________2 1
Filter BMW___________________________________________22
Filter Ford____________________________________________23
Mechatronic Group_____________________________________________ _24
Gear Shift System E-Shift Group___________________________________25
Gear Shift System M-Shift Group
M-Shift BMW__________________________________________26
M-Shift BMW__________________________________________27
M-Shift LAND ROVER__________________________________28
M-Shift Ford__________________________________________29
Parking Lock Group_____________________________________________ 30
Selective Shims, Snap Rings, Steel Plate & Kits Content
Selective Shims_____________________________________________ ___31
Selective Snap Rings____________________________________________3 2-33
Selective Steel Plate_____________________________________________ 34
Kits Content___________________________________________ ________35-40
Тип файла: pdf www.bmwpost.ru_6HP26X-28X.pdf (1.18 Мб, 576 просмотров)
eric (04.11.2012)
