-   BMW EWS, CAS (https://bmwpost.ru/forum/bmw-ews-cas-156/)
-   -   2006 BMW E90 не запускается (https://bmwpost.ru/forum/bmw-ews-cas-156/2006-bmw-e90-ne-zapuskaetsya-28720/)
hackbest 04.02.2014 19:27
ok I'll remove the ecu to read car
Do you know where this car is located in
hackbest 04.02.2014 23:21
Вложений: 1
and have removed this isn the eeprom 95640
Well here reading the eeprom of ecu
Please help I'm desperate
visht 05.02.2014 17:00
Вложений: 1
you are scary man.
With dumps that do, then read half, then with the Board ISN ... who do not understand its rules, like machine "went around the circle." ISN ECU coincides with your previous dump, restore them in the second dump, try. But after such bullying difficult to restore the chronology of events, take and read the error diagnostics, and her sync variable part, if the edited version of the dump will not work.
hackbest 05.02.2014 22:22
do not quite understand that I do burn this file you send me:confused::confused::confused:
hackbest 06.02.2014 03:18
Вложений: 1
visht here have a good read like a cas mia wing can be modified for my car
visht 06.02.2014 14:39
Simply replace your eeprom if you trust your programmer.
Comparing Flash I would not trust.
hackbest 06.02.2014 15:10
Just burn eeprom not need to edit anything
visht 06.02.2014 19:04
To communicate with the ECU need ISN and Rolling code (synchronized with diagnosis).
For the correctness of the dump Vin mileage and encoding.
To work them keys acc data.
That this should be replaced, as far as I understand you menyaetet iron, then the rest is all correspondence.
Часовой пояс GMT +3, время: 15:23.
