| | #10 |
Поблагодарили 10,622 раз(а) в 1,958 сообщениях
Откуда: Москва Авто: BMW e39 528 Есть клубные рамки |
welcome light on when unlocking the car WL_RL_BL Adaptive Headlight Error CHECK_SMC_ERROR Alarm beep on lock QUIT_AKUST_SCHAERF Alarm beep on unlock QUIT_AKUST_ENTSCH All High Beams PWM_WERT2_FL_BIXENON Angel Eyes Error: need to code all the following FEHLERMELDUNG_CC_SL_V_L Angel Eyes Error: need to code all the following FEHLERMELDUNG_CC_SL_V_R Angel Eyes Error: need to code all the following KALTUEBERWACHUNG_SL_V_L Angel Eyes Error: need to code all the following KALTUEBERWACHUNG_SL_V_R Angel Eyes Error: need to code all the following WARMUEBERWACHUNG_SL_V_L Angel Eyes Error: need to code all the following WARMUEBERWACHUNG_SL_V_R Angel Eyes on when unlocking the car WL_SL_1 Audio System Audio System Auto Dim Mirrors SPIEGEL_ELEKTROCHROM Auto Headlight Sensitivity adjustement from BC Button LICHT_AUT_WERT_1, LICHT_AUT_WERT_2, LICHT_AUT_WERT_3 Auto Light Sensitivity Control in Idrive (Multiple Changes required, see Description) RAIN_LIGHT_SENSOR BFD with Regular Brake Light BREMSL_FKT_MIT_BFD Bulb Testing Warning KALTUEBERWACHUNG_AL Bulb Testing Warning KALTUEBERWACHUNG_BL_MI Bulb Testing Warning KALTUEBERWACHUNG_BLK_HI Bulb Testing Warning KALTUEBERWACHUNG_BLK_VO Bulb Testing Warning KALTUEBERWACHUNG_FL Bulb Testing Warning KALTUEBERWACHUNG_KZL Bulb Testing Warning KALTUEBERWACHUNG_KZL_LI Bulb Testing Warning KALTUEBERWACHUNG_NSW Bulb Testing Warning KALTUEBERWACHUNG_RL Bulb Testing Warning WARMUEBERWACHUNG_AL Bulb Testing Warning WARMUEBERWACHUNG_AL_L Bulb Testing Warning WARMUEBERWACHUNG_BL_MI Bulb Testing Warning WARMUEBERWACHUNG_BLK_HI Bulb Testing Warning WARMUEBERWACHUNG_BLK_VO Bulb Testing Warning WARMUEBERWACHUNG_FL Bulb Testing Warning WARMUEBERWACHUNG_KZL_LI Central Locking with Key Only ENTSICHERN_CENTERLOCK Climate don't turn ON in Auto mode KLIMA_MIT_AUTO_0 Climate don't turn ON in Auto mode KLIMA_MIT_AUTO_1 Climate don't turn ON in Auto mode KLIMA_MIT_AUTO_10/15 Climate don't turn ON in Auto mode KLIMA_MIT_AUTO_2 Close Windows/Roof KOMFORTSCHLIESSUNG_FB Close Windows/Roof KOMFORTSCHLIESSUNG_PA Corner Delete Mod PO_RL_FKT_MIT_SL_V Corner Delete Mod PWM_SL_V_BEI_AKTIVEN_AL Corner Delete Mod SIDEMARKER_US Corner Delete Mod SIDEMARKER_US_MIT_FRA_V Corner Delete Mod SIDEMARKER_US_NFRM Corner LED Delete Mod PWM_FL_ALS_CORNERLIGHT Corner LED Delete Mod PWM_POL_BEI_AKTIVEN_AL Corner LED Delete Mod PWM_POL_BEI_AKTIVEN_FL Corner LED Delete Mod SL_FKT_MIT_POL Corner LED Delete Mod E92 PO_RL_FKT_MIT_SL_V Corner LED Delete Mod E92 PWM_SL_V_BEI_AKTIVEN_AL Corner LED Delete Mod E92 PWM_SL_V_BEI_AKTIVEN_FL Corner LED Delete Mod E92 sl_bl_ers_def_rl_bl_1 Corner LED Delete Mod E92 SL_V_PO_RL_FKT Corner LED Delete Mod E92 WL_POL Instant MPG DIGITAL_KVA Digital Speed BC_DIGITAL_V Disable iDrive Disclaimer LEGAL_DISCL Disable iDrive Disclaimer LEGAL_DISCLAIMER_TIME Disable windows safety feature FH_TUERAUF_STOP_MAUT_3R Disable windows safety feature TUERAUF_STOP_MAUT Display and Gong when Key in ignition ZUENDSCHLUESSEL_WARNUNG Door Dong CC_ZUENDSCHLUESSEL Double Blink Hazards in crash DOPPELBLINKIMPULS_CRASH Double Blink Hazards when button is pressed DOPPELBLINKIMPULS_WARNBLK DRL High Beam Delete DRL_V_GEDIMMT DRL High Beam TAGFAHRLICHT_ECE_1 DRL option in iDrive DAY_RUN_LIGHT_CCC DRL option in iDrive DAYDRIVING_LIGHT DRL Taillight Delete DRL_TFL_MIT_RL_BL_2 DRL Taillight Delete DRL_TFL_MIT_SL_2 DRL Taillight Delete RL_BL_2_MIT_TFL DVD Playback VIDEO_NUR_MIT_HANDBREMSE DVD-In Motion VIDEO_DENY_C0B Eject Key Fob with Engine Off KOMFORT_EJECT Digital Speed Value V_DIGITAL_KORRECTOR Enable DRL TAGFAHRLICHT_ECE_1 Enable DRL VERHALTEN_DRL_TFL Enable Shift Suggestion in 6MT SP_ANZEIGE, SCHALT_PKT_BC, SCHALT_PKT_DAUERHAFT Engine Start ANLASSSPERRE_BLS Fog Lights + Flash LH_UND_NSW_NICHT_GLEICHZ Fog Lights + Flash LH_UND_NSW_NICHT_GLEICHZ Fog Lights + High Beam FL_UND_NSW_NICHT_GLEICHZ Fog Lights + High Beam FL_UND_NSW_NICHT_GLEICHZ Fold Mirror ASP_KOMFORT_EINKLAPP Fold Mirror SPIEGEL_KOMFORT_EINKLAPP Front corner LED lights on when unlocking the car WL_POL_3R Front fog lights on when unlocking the car WL_NSW Front Parking lights on when unlocking the car WL_SL_2 Front turn signals on when unlocking the car WL_BLK_V Fuel Stop Suggestion in Route Guidance NAVI_FUELSTOP_PROPOSAL Headlight Washers Disabled SCHEINWERFERREININUNG High beams on when unlocking the car WL_FL iDrive Default Screen Communication VA_FB_COMMUNICATION iDrive Default Screen Entertainment VA_FB_ENTERTAINMENT iDrive Default Screen Navigation VA_FB_NAVIGATION iDrive Display Modes NAVI_MAPMODE_AUTOMATIC LED Tail Light Retrofit CC_MELD_BFD_BL LED Tail Light Retrofit FEHLERMELDUNG_CC_BFD_L & R Length of time that Welcome Lights Stay on WL_DAUER Lock/unlock beep option in iDrive (part 1) ACOUSTIC: aktiv Lock/unlock beep option in iDrive (part 2) C941C_QUITT_AKUST_KLAPPE: fkt_frei Lock/unlock beep option in iDrive (part 3) K9416_QUITT_AKUST_ENTSCH: fkt_frei Lock/unlock beep option in iDrive (part 4) C9413_QUITT_AKUST_SCHAERF: fkt_frei Low beams on when unlocking the car WL_AL Panic Mode Rain Close from full open REGENSCHLIESSEN Rain Close Sunroof from Tilt REGENSCHLIESSENTILT Rear fog lights on when unlocking the car WL_NSL Rear license plate on when unlocking the car WL_KZL Rear turn signals on when unlocking the car WL_BLK_H REST feature enable on cars with an ALL button REST_TASTE_VERBAUT Right Parking lamp malfunction error message FEHLERMELDUNG_CC_SL_V_R Seat Belt Chime SBR_BEIFAHRER_1 Seat Belt Chime SBR_BEIFAHRER_2_CD Seat Belt Chime SBR_FAHRER_1 Sound alarm chirp level BUZZER_HIGH_LEVEL TPMS Disable $2vb Unlock Doors ER_KEYOUT_AUTOVR Wiper wipes to End position after turning engine off ZYCLUS_VOLLEND_KLR_AUS Xenon Headlight Retrofit (from Halogen to OEM Xenon) 522 Подробности в файле.
| Метки |
| bmw inpa |
| Ликвидация новых запчастей по закупке | АндрейСергеевич | Продажа запчастей BMW | 2 | 02.07.2024 16:26 |
| Все опции БМВ на русском языке | Tyler | Выбираем БМВ | 21 | 19.06.2014 12:09 |
| Модельный ряд BMW пополнил автомобиль BMW 740d | Tyler | Новости BMW | 3 | 30.07.2009 19:24 |
| BMW 5 серии Gran Turismo на Женевском автосалоне 2009 | Tyler | Новости BMW | 0 | 26.02.2009 18:00 |
