| | #1 | |
| Новичок Регистрация: 08.06.2009
Но от всех модулей IFH-0009. Вот лог идентификации через ИНПУ. I D E N T I F I C A T I O N R E A D --------------------------------------- Datum : 15.11.2009 10:20:44 Baureihe : E53 ------------------------------------------------------------- Control unit : Dynamic stability control 4 wheel system ECU : D_ABSKWP JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Transfer gear box Control unit ECU : D_VGSG JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Dynamic stability control ECU : D_0056 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Gear box ecu GS19 ECU : D_EGS JobStatus : OKAY BMW part number : 7544720 Hardware number : 72 Software number : _?_ Supplier : Bosch Supplier-No : 8 Coding index : 0 Diagnostic index : 513 Bus index : _?_ Date of manufacture Week/Year : _?_/2005 ------------------------------------------------------------- Control unit : Motor ECU : D_0012 JobStatus : OKAY BMW part number : 7556340 Hardware number : 00 Software number : _?_ Supplier : Bosch Supplier-No : 8 Coding index : 17 Diagnostic index : 32 Bus index : _?_ Date of manufacture Week/Year : _?_/2005 ------------------------------------------------------------- Control unit : Steering angle sensor ECU : D_0057 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Air suspension ECU : D_00AC JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Tyre pressure control ECU : D_0070 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Light check modul ECU : D_00D0 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Active Light Control E46 ECU : D_0066 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Headlight vertical aim control ECU : D_009A JobStatus : SYS-0012: IDENTIFICATION ERROR ------------------------------------------------------------- Control unit : Rain- light sensor ECU : D_00E8 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Multidrive Sunroof ECU : D_0008 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Electronic vehicle immobilization III ECU : D_0044 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Central information system ECU : D_00C0 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Central body electronics 1 PM Passenger ECU : D_ZKE3BT JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Central body electronics 1 PM Driver ECU : D_ZKE3FT JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Central body electronics 1 or 3 Basic modul ECU : D_ZKE_GM JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Central body electronics 1 PM Lifting moving roof ECU : D_ZKE3SD JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Middle console center switch ECU : D_SZM JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Airbag Control unit ECU : D_00A4 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Instrument cluster ECU : D_0080 JobStatus : SYS-0012: IDENTIFICATION ERROR ------------------------------------------------------------- Control unit : Multi functional steering wheel ECU : D_0050 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Speech input system ECU : D_00B0 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Air conditioning panel ECU : D_005B JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Additional heater ECU : D_ZUHEIZ JobStatus : IFH-0006: COMMAND NOT ACCEPTED ------------------------------------------------------------- Control unit : All radio type except MOST-vehicles ECU : D_0068 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : CD-Changer I-Bus ECU : D_0076 JobStatus : SYS-0008: JOB NOT FOUND ------------------------------------------------------------- Control unit : Digital Sound Processor ECU : D_006A JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Japan Bit ECU : D_0048 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Telefon or Universel loading- and handsfree set ECU : D_00C8 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Bordmonitor ECU : D_00F0 JobStatus : SYS-0012: IDENTIFICATION ERROR ------------------------------------------------------------- Control unit : Videomodul ECU : D_00ED JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Basis-Interface Telefon 2 ECU : D_0048 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : navigation computer ECU : D_007F JobStatus : SYS-0012: IDENTIFICATION ERROR ------------------------------------------------------------- Control unit : Navigationssystem Japan ECU : D_00BB JobStatus : SYS-0012: IDENTIFICATION ERROR ------------------------------------------------------------- Control unit : Activ seat Passenger ECU : D_SITZ_B JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Activ seat Driver ECU : D_SITZ_F JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ------------------------------------------------------------- Control unit : Seat modul ECU : D_0072 JobStatus : IFH-0009: NO RESPONSE FROM CONTROLUNIT ================================================== =============== | |
| | #2 |
Разобрался! Не была припаяна 8-я нога. Соединил с 7-й ногой - все заработало на Висте, включая DIS через INPA. Так что не надо про Висту - все на ней работает, если запускать Инпу в режиме совместимости XP.
| Сказал Спасибо maximus6 за это сообщение: | NURGAZY (26.02.2012) |
| | #3 |
| Новичок Регистрация: 12.08.2009
Здраствуите!огромное спасибо за информацию. помогите с блоком (ABS DSC) присутствует ошибка (SN control) блок уже ковыряли в коком направлении искатью |
| Метки |
| bmw inpa |
| Ликвидация новых запчастей по закупке | АндрейСергеевич | Продажа запчастей BMW | 2 | 02.07.2024 16:26 |
| Все опции БМВ на русском языке | Tyler | Выбираем БМВ | 21 | 19.06.2014 12:09 |
| Модельный ряд BMW пополнил автомобиль BMW 740d | Tyler | Новости BMW | 3 | 30.07.2009 19:24 |
| BMW 5 серии Gran Turismo на Женевском автосалоне 2009 | Tyler | Новости BMW | 0 | 26.02.2009 18:00 |
