| | #9 |
Откуда: Москва Авто: BMW e39 528 Есть клубные рамки |
Также по ошибкам можно почитать в этом мануале: . IFH, Interface Handler: IFH-0000: INTERNAL ERROR IFH-0001: UART ERROR IFH-0002: NO RESPONSE FROM INTERFACE IFH-0003: DATATRANSMISSION TO INTERFACE DISTURBED IFH-0004: ERROR IN INTERFACE COMMAND IFH-0005: INTERNAL INTERFACE ERROR IFH-0006: COMMAND NOT ACCEPTED IFH-0007: WRONG UBATT IFH-0008: CONTROLUNIT CONNECTION ERROR IFH-0009: NO RESPONSE FROM CONTROLUNIT IFH-0010: DATATRANSMISSION TO CONTROLUNIT DISTURBED IFH-0011: UNKNOWN INTERFACE IFH-0012: BUFFER OVERFLOW IFH-0013: COMMAND NOT IMPLEMENTED IFH-0014: CONCEPT NOT IMPLEMENTED IFH-0015: UBATT ON/OFF ERROR IFH-0016: IGNITION ON/OFF ERROR IFH-0017: INTERFACE DEADLOCK ERROR IFH-0018: INITIALIZATION ERROR IFH-0019: DEVICE ACCESS ERROR IFH-0020: DRIVER ERROR IFH-0021: ILLEGAL PORT IFH-0022: DRIVER STATUS ERROR IFH-0023: INTERFACE STATUS ERROR IFH-0024: CANCEL FAILED IFH-0025: INTERFACE APPLICATION ERROR IFH-0026: SIMULATION ERROR IFH-0027: IFH NOT FOUND IFH-0028: ILLEGAL IFH VERSION IFH-0029: ACCESS DENIED IFH-0030: TASK COMMUNICATION ERROR IFH-0031: DATA OVERFLOW IFH-0032: IGNITION IS OFF IFH-0034: CONFIGURATION FILE NOT FOUND IFH-0035: CONFIGURATION ERROR IFH-0036: LOAD ERROR IFH-0037: LOW UBATT IFH-0038: INTERFACE COMMAND NOT IMPLEMENTED IFH-0039: EDIC USER INTERFACE NOT FOUND IFH-0040: ILLEGAL EDIC USER INTERFACE VERSION IFH-0041: ILLEGAL PARAMETERS IFH-0042: CARD INSTALLATION ERROR IFH-0043: COMMUNICATION TRACE ERROR IFH-0044: FLASH ERROR IFH-0045: RUNBOARD ERROR IFH-0046: EDIC API ACCESS ERROR IFH-0047: PLUGIN ERROR IFH-0048: PLUGIN FUNCTION ERROR IFH-0049: CSS DEVICE DETECTION ERROR IFH-0050: ENTRY IN DYNAMIC CONFIGURATION NOT FOUND IFH-0051: INTERNAL DYNAMIC PROTOCOL ERROR IFH-0052: CONCEPT NOT AVALIABLE IFH-0053: ILLEGAL CONCEPT ID IFH-0054: ILLEGAL FUNCTION PARAMETER IFH-0055: CANNOT LOAD PROTOCOL TABLES IFH-0056: ILLEGAL CHANNEL IFH-0057: ERROR READ DIGITAL INPUTS IFH-0058: ERROR SET DIGITAL OUTPUTS IFH-0059: ERROR READ ANALOG INPUTS BIP, BEST Interpreter: BIP-0000: INTERNAL ERROR BIP-0001: OUT OF RANGE BIP-0002: IFH FUNCTION ERROR BIP-0003: OBJECT FILE ERROR BIP-0004: ILLEGAL OPCODE BIP-0005: STACK OVERFLOW BIP-0006: BEST FILE ERROR BIP-0007: DIVISION BY ZERO BIP-0008: BEST BREAK BIP-0009: BEST VERSION ERROR BIP-0010: CONSTANT DATA ACCESS ERROR BIP-0011: REAL ERROR BIP-0012: PLUG IN NOT FOUND BIP-0013: PLUG IN ERROR BIP-0014: PLUG IN VERSION ERROR BIP-0015: PLUG IN STACK ERROR BIP-0016: PLUG IN FUNCTION NOT FOUND SYS, sequence control: SYS-0000: INTERNAL ERROR SYS-0001: ILLEGAL FUNCTION SYS-0002: ECU OBJECT FILE NOT FOUND SYS-0003: ECU OBJECT FILE ERROR SYS-0004: ILLEGAL FORMAT OF ECU OBJECT FILE SYS-0005: OBJECT FILE NOT FOUND SYS-0006: GROUP OBJECT FILE ERROR SYS-0007: ILLEGAL FORMAT OF GROUP OBJECT FILE SYS-0008: JOB NOT FOUND SYS-0009: NO INITIALIZATION JOB SYS-0010: INITIALIZATION ERROR SYS-0011: NO IDENTIFICATION JOB SYS-0012: IDENTIFICATION ERROR SYS-0013: UNEXPECTED RESULT SYS-0014: ILLEGAL FORMAT SYS-0015: TASK COMMUNICATION ERROR SYS-0016: ILLEGAL CONFIGURATION SYS-0018: END JOB ERROR SYS-0019: TIMER ERROR SYS-0020: BASE OBJECT FILE NOT FOUND SYS-0021: BASE OBJECT FILE ERROR SYS-0022: ILLEGAL FORMAT OF BASE OBJECT FILE SYS-0023: PASSWORD ERROR SYS-0024: ILLEGAL PASSWORD API, Application Programming Interface: API-0000: INTERNAL ERROR API-0001: USER BREAK API-0002: MEMORY ALLOCATION ERROR API-0003: RESULT SETS OVERFLOW API-0004: RESULTS OVERFLOW API-0005: ILLEGAL RESULT FORMAT API-0006: ACCESS DENIED API-0007: INCORRECT CONFIGURATION FILE API-0008: TASK COMMUNICATION ERROR API-0009: EDIABAS NOT FOUND API-0010: ILLEGAL EDIABAS VERSION API-0011: ILLEGAL ECU PATH API-0012: SIGNAL SERVER NOT FOUND API-0013: INITIALIZATION ERROR API-0014: RESULT NOT FOUND API-0015: HOST COMMUNICATION ERROR Network: NET-0000: INTERNAL ERROR NET-0001: UNKNOWN ERROR NET-0002: ILLEGAL VERSION NET-0003: INITIALIZATION ERROR NET-0004: ILLEGAL CALL NET-0005: NO SUPPORT NET-0006: ACCESS DENIED NET-0007:SYSTEM ERROR NET-0008: NETWORK ERROR NET-0009: TIMEOUT NET-0010: BUFFER OVERFLOW NET-0011: ALREADY CONNECTED NET-0012: NO CONNECTION NET-0013: CONNECTION DISTURBED NET-0014: CONNECTION ABORTED NET-0015: HOST NOT FOUND NET-0016: HOST ERROR NET-0017: PROTOCOL NOT AVAILABLE NET-0018: UNKNOWN PROTOCOL NET-0019: UNKNOWN SERVICE NET-0020: UNKNOWN HOST NET-0021: SERVER NOT FOUND NET-0022: SECURITY ERROR Applikation: RUN-0000 RUN-0099 Содержание: 1. Revision history........................................... ..........................................3 2. Introduction...................................... .................................................. ....4 2.1. About this manual............................................ ........................4 2.2. Notational conventions....................................... .....................4 2.3. Special features, terms, acronyms.......................................... 5 3. General Information....................................... ........................................6 3.1. Error symbol and error code.............................................. ......6 3.2. Message and output of an error............................................. .6 3.3. How errors affect program execution......................................7 4. List of errors............................................ ...............................................8 4.1. IFH, Interface Handler........................................... ..................9 4.2. Runtime system............................................ ...................................34 4.2.1. BIP, BEST Interpreter....................................... ....................34 4.2.2. SYS, sequence control........................................... ..............41 4.3. API, Application Programming Interface......................................... 55 4.4. Network........................................... ........................................64 4.5. Applikation....................................... ........................................72 A. References........................................ .................................................. ....73 Пароль на открытие:
| Метки |
| bmw inpa |
| Ликвидация новых запчастей по закупке | АндрейСергеевич | Продажа запчастей BMW | 2 | 02.07.2024 16:26 |
| Все опции БМВ на русском языке | Tyler | Выбираем БМВ | 21 | 19.06.2014 12:09 |
| Модельный ряд BMW пополнил автомобиль BMW 740d | Tyler | Новости BMW | 3 | 30.07.2009 19:24 |
| BMW 5 серии Gran Turismo на Женевском автосалоне 2009 | Tyler | Новости BMW | 0 | 26.02.2009 18:00 |
