BMW Inpa/Ediabas
Like Tree71Likes
Старый 31.10.2008, 23:39 #9
Информация по кодированию BMW e70:
Disable Sidemarker
FRM Module
SIDEMARKER_US
nicht_aktiv
Double Blink Hazards (some thing cool looking)
FRM Module
DOPPELBLINKIMPULS_WARNBLK
aktiv
Key fob remote mirror close (this has a dependency with remote window close, for this to work i thing remote window close should be coded as well)
FRM Module
ASP_KOMFORT_EINKLAPP (MY09-11)
aktiv
SPIEGEL_KOMFORT_EINKLAPP (MY07-08)
aktiv
Fog lights with Highbeam on
FRM Module
FL_UND_NSW_NICHT_GLEICHZ
nicht_aktiv
Fog lights with Highbeam Flash
LH_UND_NSW_NICHT_GLEICHZ
nicht_aktiv
Key fob Windows UP when press and hold the lock button
CAS Module
KOMFORTSCHLIESSUNG_FB (window up through key fob)
aktiv
KOMFORTSCHLIESSUNG_PA (window up through comfort access)
aktiv
Eject Keyfob with engine off - you have to HOLD the start/stop button. This in conjunction with the nest feature as well
Press and hold the start/stop button 1 second. Key will be released.
CAS
KOMFORT_EJECT
nicht_aktiv -> aktiv
at the same time it will Unlock doors when engine off/key ejected - as above, HOLD the start/stop button. I don't even press the park button. I come to a complete stop, then hold the start/stop button. It puts the car in park, ejects key (if its in there, i have CA), and unlocks door (no more 2-pull to open doors)
CAS
ER_KEYOUT_AUTOVR
Remote trunk close (closing tailgate with key fob and button inside cabin)
HKL Module
SCH_FBD
aktiv
SCH_TOEHKI
aktiv
TASTER_FBD
aktiv
(I have not done it yet, it is on my list)
enable DVD in motion For CIC
frist you need to modify the CIC.xxx on line 17 and 18 from [03] to [FF] using data2txt and then code the following
CIC Module
VIDEO_NUR_MIT_HANDBREMSE
nicht_aktiv
SPEEDLOCK_X_KMH_MAX_C0E
3_kmh
SPEEDLOCK_X_KMH_MIN_C0E
3_kmh
V=Digital Speed (you will have to reset the time after)
KOMBI Module
BC_DIGITAL_V
aktiv
There is one more feature that i can not confirm but others report that the following arameter show the actual speed on the V= instead the same as the speed shows on the cluster
BC_DIGITAL_V_KORREKTUR (i did not do this one i only did BC digital_V)
aktiv
Instant MPG (Value is Not in 2011 E70, may be in other/older models this value is present)
KOMBI module
DIGITAL_KVA
aktiv
Disable iDrive Disclaimer
CIC Module
LEGAL_DISCLAIMER_TIME
kein_ld
Remove IDrive warning when starting the car. (I think this is for CCC units)
CAPPL
LEGAL_DISCL
aktiv -> nicht_aktiv
DVD in motion (I think this is for CCC units)
CAPPL
VIDEO_DENY_C0B
deny_stop_break -> deny_never
Successful:
CIC
(Disable Backup Camera Disclaimer)
MACRO_CAM_LEGAL_DISCLAIMER
kein_ld
(Disable iDrive Disclaimer)
kein_ld
Successful:
KOMBI
(Enable Digital Speed)
BC_DIGITAL_V
aktiv
______________________
FRM Module
aktiv
FRM Module
aktiv
aktiv
FRM Module
nicht_aktiv
nicht_aktiv
CAS Modul
aktiv
aktiv
Eject Keyfob with engine off - If you don’t have comfort access.
CAS
KOMFORT_EJECT
CAS
ER_KEYOUT_AUTOVR
HKL Module
SCH_FBD
aktiv
SCH_TOEHKI
aktiv
TASTER_FBD
aktiv
enable DVD in motion For CIC Only
Exclusive DVD in Motion activation for CIC by BMWCODING v3.pdf‎
KOMBI Module
BC_DIGITAL_V
aktiv
Disable iDrive Disclaimer - For CIC
CIC Module
kein_ld
Remove IDrive warning when starting the car. for cars with CCC
CAPPL
LEGAL_DISCL
2007 X5 with drive, no navi:
- Double blink hazards (FRM -> DOPPELBLINKIMPULS_WARNBLK)
- Key fob remote mirror close (FRM -> SPIEGEL_KOMFORT_EINKLAPP)
- Digital speedo (KOMBI -> BC_DIGITAL_V)
- Key fob windows up (CAS -> KOMFORTSCHLIESSUNG_FB )
- Unlock door after engine off (CAS -> ER_KEYOUT_AUTOVR)
- Seat belt chime (ABG -> SBR_FAHRER_1)
- Wiper cycle finish after eng off (JBBF -> ZYCLUS_VOLLEND_KLR_AUS)
- Low beams on unlock (FRM -> WL_AL)
Seat Belt Chime
Module: ABG
Function: SBR_FAHRER_1, CC_GURTWARNUNG_1
Change to value: Set both to nicht_aktiv
Note: There's a changing VO method too which many here prefer
Key Fob Windows Up
Module: CAS
Function: KOMFORTSCHLIESSUNG_FB
Change to value: aktiv
Unlock Doors when Engine
Module: CAS
Function: ER_KEYOUT_AUTOVR
Key Fob Ejected from Socket upon Engine Stop
Module: CAS
Function: KOMFORT_EJECT
Auto Dim Mirror Delete
Module: FRM
Function: SPIEGEL_ELEKTROCHROM
Change to value: nicht_aktiv
Disable Fog Lights For Low Speed Cornering
Module: FRM
Functions: ABBIEGELICHT_CKM_0, ABBIEGELICHT_CKM_1 , ABBIEGELICHT_CKM_2, ABBIEGELICHT_CKM_3
Change to value: Set all to nicht_aktiv
Amber Delete
Module: FRM
Function: SIDEMARKER_US
Change value to: nicht_aktiv
Double Blink Euro Hazards
Module: FRM
Function: DOPPELBLINKIMPULS_WARNBLK
Change value to: aktiv
Mirrors Fold with Keyfob
Module: FRM
Function: SPIEGEL_KOMFORT_EINKLAPP
Note: This is dependent on windows up with key fob
Low beams on when unlocking the car
Module: FRM
Function: WL_AL
Change value to: soft_einschalten
Increase Angel Eyes Brightness
Module: FRM
Function: PWM_RL_BL_1_FKT_SL
Change value to: wert_01
Wiper End cycle after eng off
Module: JBBF
Function: ZYCLUS_VOLLEND_KLR_AUS
Digital speedo
Module: KOMBI
Function: BC_DIGITAL_V
Key in inition door dong
Module: KOMBI
Function: CC_ZUENDSCHLUESSEL
Instrument Cluster Lighting Always On
Module: KOMBI
Function: M_TAG_SKALENBELEUCHTUNG
Эти 4 пользователя(ей) сказали Спасибо Tyler за сообщение:
absentos (19.02.2017), eric (21.03.2013), GMPROF (07.03.2013), sashapavluchkov (26.12.2013)
Метки
bmw inpa
Часовой пояс GMT +3, время: 19:24.
