ошибка DIS, контакт 15.
Старый 10.08.2011, 02:35 #31
Аватар для Алексей33
Сказал спасибо: 19
Авто: Е70
Hi there, let’s start with what you have to do to completely use INPA, DIS and SSS
1. Install the drivers for the blue cable, they are on the small disc and GO TO:
Control panel –> System –> Hardware –> Device Manager –> Ports –> Right click on your USB Serial Port and select Properties, follow the steps you see in the pictures:
2. You need to install Vmware 7 that you have on the DVD, the instructions for it’s installaion are in this document „Vmware Installation.doc”
3. Install INPA 5.0.2 that you have on the DVD, the instructions for it’s installation are in „INPA_5.0.2_Install.pdf”, if you want to have latest NCS Expert version, copy the content of the folder „NCSEXPER” from DVD and paste it into the same folder from C:\NCSEXPER
4. You will have to replace the files „Ediabas.ini” and „OBD.ini” from C:\EDIABAS\Bin with the files „Ediabas.ini” and „OBD.ini” that you have on the DVD
5. You will need to copy the files „OBD.ini” also in the C:\WINDOWS\system32
6. Place a shortcut on your desktop with the file „ifhsrv32.exe” that is located in C:\EDIABAS\Bin , you will just need to go in C:\EDIABAS\Bin right click on the file „ifhsrv32.exe” and select Create Shortcut.
7. You need copy „DiagHead.exe” on your desktop
8. After you click Poweron button in VmMware and DIS starts you must click on the Shortcut of ifhsrv32.exe that you placed it on the desktop in Step 6.
9. Last step is to open the „DiagHead.exe” that is place on your desktop and click on Run, you need to have the same 3 windows running in taskbar like in picture bellow:
10.
11. If in DIS you don’t see 2 signal antenas in the up right corner that look the same and they look like in the picture bellow:
you must go in Administration -> Connection Setup and click on Connecting
12. That is all, enjoy!
(if you get an error 200.159 when you try to Diagnose a car it means you have a problem with the antivirus or the Firewall that is blocking the communication between the VMware LAN adapters, try do disable the Antivirus or Firewall and if persists you can uninstall and give it a try) пункт 5
Последний раз редактировалось Алексей33; 10.08.2011 в 02:36.
Алексей33 вне форума   Ответить с цитированием
Старый 10.08.2011, 23:37 #32
Вроде все установил, файлы заменил, запустил. Все равно пишет нет связи с блоком. Inpa работает нормально
остап вне форума   Ответить с цитированием
Старый 13.08.2011, 09:55 #33
Может, кто подскажет, в чем проблема
Старый 13.08.2011, 16:02 #34
Авто: bmw e90
Сообщение от остап Посмотреть сообщение
Вообщем народ, спасибо всем за советы :))) проблема была идиотская - я просто забыл поставить в настройках com где раздел Дополнительно (где можно порт поменять) время кажется отклика или обновления, что то в этом роде, по умолчанию стоит 16 а надо 1.
Так что всем спасибо.
kinderus вне форума   Ответить с цитированием
Старый 17.08.2011, 01:41 #35
Аватар для Emin-BMW
Авто: БМВ528i
добрый вечер!у меня такая проблемма пару дней назад установил дис вроде продиагностировал все ок,сегодня опять захожу
система управлением двигателя
блок управления двигателя,smg,акпп
система отопления -конд.
мех. неисправность ход.части
рулевое управление
редуктор заднего моста
система устойчивости
на инпе проверял пару из этих блоков вроде пишет джоб окей)))
что посоветуете сделать???дис глючит?или просто совпадение)))
да и еще незнаю самовнушение или так на самом деле двиг какойто горячий.из под капота жар дует как надо!помогите пожалуйста.юатарею тоже отключил,опять тоже самое
Emin-BMW вне форума   Ответить с цитированием
BMW F20 Ошибка привода. Полная мощность привода больше не доступна. Следуйте на СТОА. vantager Ремонт и эксплуатация BMW 98 06.05.2019 21:06
e90 2005 ошибка лямбда Desperado Диагностика BMW | кодирование | программирование 18 25.07.2012 14:29
Проверка катушки зажигания (первичная обмотка) (М43, М44) Tyler 12 Электрооборудование двиг-ля 0 03.06.2009 10:21
Часовой пояс GMT +3, время: 08:57.
