Язык и PRG
Старый 03.10.2012, 11:58 #18
Поблагодарили 8 раз(а) в 4 сообщениях
Сообщение от Argos Посмотреть сообщение
XBD-Generator_2.3.3.part4 архив косячный,перезалей плиз)
перезалил
возможно это тоже пригодится (пункт 3.2 = распаковка prg) и еще в гугле наберите "real time data logging" без кавычек = первая найденная ссылка тоже познавательная.
цитата:
Basically, all you need to do is read the file inpa_english.pdf in the folder \EC-APPS\INPA\DOKU
It contains a complete explanation of how the entire system works and is what I used to get my simple SMG data logging up and running.
As a primer though, I'll run through the basic concepts:
1. IPS file - you create an IPS file which contains descriptions of the screens and menus you want, written in INPA's high-level programming language. It has some VERY rudimentary programming functions available, one of which is fileopen(filename, mode) which creates or opens a file and filewrite(string) which will append the string to the file that has been opened.
2. Once written, you compile your IPS file using INPACOMP.EXE which produces an IPO file and an INI file. These are the files that INPA actually runs - when you use INPA "normally" all it is doing is running a standard set of IPO files from BMW.
3. When writing a screen definition, the structure you follow is broadly:
i. Send a job request to the OBD
ii. Wait for the OBD to report that the job is complete
iii. Read the results of the request that you are interested in to variables
iv. Display them on-screen or write them to your log file
For part (i) above, you need to know both the module to interrogate and the job name that you want it to run. For part (iii) you need to know the result name that you're interested in. This is the time-consuming bit, as everything is in German:
•3.1 Work out which ECU you want to interrogate. The available ECUs are listed in the folder C:\EDIABAS\ECU\
Each .PRG file is an ECU descriptor containing the job names and result values for that ECU. Because I wanted to interrogate the SMG ECU, I worked out pretty quickly that the file I was interested in was SMG2.PRG
•3.2 Use the program C:\EDIABAS\BIN\XTRACT.EXE to list the contents of your chosen PRG file. Eg. for my SMG job, the command I needed was:
XTRACT C:\EDIABAS\ECU\SMG2.PRG -F
The -F on the end causes it to dump the results to a file (SMG2.PRV) rather than the screen
•3.3 Open the file created in Notepad. The file lists all the jobs and results in German. For example, part of the SMG2 results are:
JOBNAME:INITIALISIERUNG
JOBCOMMENT:Init-Job fuer EGS
This is saying that there is a job available called "INITIALISIERUNG" and the brief description is "Init job for EGS". Beneath each job, all the possible results are listed, e.g.:
RESULT: DONE
RESULTTYPE:int
RESULTCOMMENT:1 wenn OKAY
This is saying that the first result value returned is called "DONE", it is a number (int) and it's value is "1" when the job is complete. Note that not all results are necessarily described in the file, sometimes you just have to read the result and try to make sense of it yourself!
So, in our IPS file if we wanted to run that job and read that result, the commands would be:
INPAapiJob("smg2", "INITIALISIERUNG");
to run the job, then once the "OKAY" result is returned, we can read the other results. For the result called "DONE" we could use:
INPAapiResultInt( my_result_variable, "DONE");
This would put the value of the result called "DONE" into the variable my_result_variable
For my project, I found Google Translate a total Godsend - simply copy and paste the XTRACT results in and look for jobs that seem interesting!
4. When displaying screens, INPA continuously cycles through the definition, constantly running the job, reading the results and displaying them, until you press a key to change the view. To display the results, you just pass the variables containing the results to one of INPAs predefined functions - you'll notice there are only a few "widgets" in INPA for displaying info, some are bar graphs, others are dots, etc. Each widget is simply an INPA function. For data logging, you don't even need to know about these functions though, you just pass your variables to filewrite() to dump them in the file.
5. Details of data logging: The filewrite() function simply writes a string to the currently open file and adds a linefeed to the end. Therefore to get a useful file you need to join all the job results together into one string, separated by commas, and write that string to the file. Excel will then recognise the file as a CSV file and load it up into columns of results. To create your string of comma-separated values, use strcat().
Тип файла: rar XBD-Generator_2.3.3.part4.rar (1.37 Мб, 373 просмотров)
yuri89 вне форума   Ответить с цитированием
Эти 2 пользователя(ей) сказали Спасибо yuri89 за сообщение:
audiserg (24.04.2014), DJenka (29.06.2019)
как перевести на русский язык бортовой компьютер который без навигации е53 ххх5 Ремонт и эксплуатация BMW 9 03.12.2013 15:05
е65 - можно ли прошить на русский язык? Wezdehod Диагностика BMW | кодирование | программирование 10 08.10.2013 20:52
Перепрошивка блока распознания речи на анг язык weary Навигация 0 02.12.2011 13:03
Bluetooth и телефонная книга (русский язык) makhome Ремонт и эксплуатация BMW 5 23.10.2011 10:42
E71 - хочу поставить русский язык и активировать навигацию Serg007 Навигация 17 30.04.2011 04:31
Часовой пояс GMT +3, время: 09:59.
