Колхоз - покраска заднего шильдика в черный цвет
Старый 08.10.2012, 11:38 #1
Поблагодарили 10,608 раз(а) в 1,958 сообщениях
По умолчанию Колхоз - покраска заднего шильдика в черный цвет
Немного для любителей колхоза для BMW - покраска заднего шильдика в черный цвет:
Tools:
  1. Xacto Knife
  2. Dental Floss
  3. Heatgun/Blowdryer
  4. 3M Heavy Duty Double Sided Tape
  5. Coating/Paint of Your Choice
  6. Masking/Painters Tape
Total Cost: Less than $20(depending on what you already have around the house)
Notes:
-I definitely suggest an Xacto(fine point) over any regular razor blade bc if will make cutting thin pieces of the 3M tape MUCH easier when it comes time to apply them to the back of the emblems.
-I got lazy and only taped above and below where the emblems originally were. Im 99% sure my spacing between the emblems is a bit off after I reinstalled them. I would put tape between each emblem prior to removing them to make sure you have the spacing right.
1.) Put the tape on, make sure the lines are straight so your emblems wont come out crooked. I had already removed the "i" before I decided to to the DIY..sorry about that
2.) Use your heatgun or blowdryer to slowly heat up the area around the emblems. Careful not to hold it there too long and damage your paint. I used the lowest setting on my heatgun.
3.) Bust out your floss and start running it behind the emblems. Once the area is heated up the floss should slide through the adhesive pretty easily. Reheat if needed the area if needed.
4.) Clean the remaining adhesive off the back of your emblems and on the trunk of the car the best you can. You probably wont get them off 100% from the back of the emblems but the cleaner you can get them, the better. I used Goo-Gone to get most of the residue off and followed up with brake cleaner to remove that oily surface that Goo-Gone leaves.
5.) Clean and dry then emblems off, and cut the 3M double sided tape into pieces thin enough to apply on the back of the emblems how the OEM adhesive originally was.
6.) Now you can paint them. I chose Plastidip b/c it requires zero prep work aside from cleaning the surface. No sanding required, and 100% reversible. Leaves a matte black finish, looks great with Space Grey or AW, other lighter colors, etc. $6 at local hardware stores. Do 2-3 coats allowing 15 minutes in between each coat, and let the final coat sit for 30 mins or so before handling/reinstalling.
7.) Peel all the red backing off the 3M tape from the back of your emblems. Reinstall using your masking/painters tape gridlines. I prefer to heat the back of the emblems before installing b/c the heat helps the 3M tape stick better. Personal preference/habit, not 100% necessary.
After you've lined up and reinstalled the emblems, you're done. If you're only debadging, you only need to follow steps #2 & #3.
Finished
Tyler вне форума
gelenlynx5264 (12.10.2012)
Старый 08.10.2012, 11:43 #2
Аватар для slava657
Сказал спасибо: 113
Авто: BMW 528 e39
Ну даже не знаю
Старый 12.10.2012, 12:37 #3
Аватар для Fetis
Авто: BMW 730 F01 2009 г.в
А смысл? ))
Fetis вне форума   Ответить с цитированием
Старый 12.10.2012, 12:49 #4
Аватар для slava657
Сказал спасибо: 113
Авто: BMW 528 e39
Сообщение от Fetis Посмотреть сообщение
А смысл? ))
Ну... мож кому нравится. Например на черной машине в черный его покрасить, мож и смотрелось бы Нужно прикидавать, а так ничего не понятно
Старый 12.10.2012, 13:37 #5
Сказал спасибо: 127
Авто: bmw 520i 1998
Не смотрелось бы... смотрится как раз на светлых фонах... контраст понимаешь...
алехандер вне форума   Ответить с цитированием
Старый 12.10.2012, 13:41 #6
Аватар для slava657
Сказал спасибо: 113
Авто: BMW 528 e39
Сообщение от алехандер Посмотреть сообщение
Да я понял Я ж и говорю на любителя да и вживую лучше смотреть У меня на стоянке черная камри стоит (типа в тюнинге), сзади или спереди (не помню) значек тоеты в черный покрашен, дык вроде и ничего Но я бы стал этим заморачиваться в самую последнюю очередь, а скорее всего вообще бы не стал
Старый 14.10.2012, 01:20 #7
Аватар для SEREGA221
Сказал спасибо: 30
Авто: E39 530D
прикольно
SEREGA221 вне форума   Ответить с цитированием
Старый 14.10.2012, 10:30 #8
Гoсть
Сообщений: n/a
Черный он и в Африке ---ЧЕРНЫЙ .
Старый 14.10.2012, 13:55 #9
Аватар для mihhail
Сказал спасибо: 33
Авто: E39, E65
я меня шадоу не прёт..я любитель "циганщины".....хром он и в африке зром......особенно на чёрных тонах..имхо
Старый 14.10.2012, 13:56 #10
Аватар для mihhail
Сказал спасибо: 33
Авто: E39, E65
я меня
Часовой пояс GMT +3, время: 11:19.
