Старый 14.06.2013, 16:49 #8
Вот что нашёл в сети:
"On vehicles without EWS (electronic immobilizer), the immobilization and starter interlock functions are carried out by the general module when the vehicle is arrested.
The immobilization function is provided by a line from the general module to the DME control unit. The DME is partly deactivated when the vehicle is arrested.
A second line leads from the general module to a starter interlock relay. This relay switches terminal 50 from the ignition lock to the starter. The engine can only be started when the vehicle is released and disarmed and terminal 15 is switched on.
As of 1/95, the EWS system undertakes these functions.
Похоже действительно сига у меня находится в блоке zke
BMW 325i купе, 1994г. АКПП
Последний раз редактировалось muzzle; 14.06.2013 в 16:50.
muzzle вне форума   Ответить с цитированием
