| BMW EWS, CAS Обсуждаем работу со штатными иммобилайзерами BMW (EWS 1,2,3,3+4; CAS 1,2,3,3+,4). Синхронизация, корректировка пробега, работа с ключами и т.п. |
| | #11 | |
| Новичок Регистрация: 06.10.2009
Откуда: Минск city Авто: e39/wranglerTJ/w126/e38 | Цитата:
If programmer connects to PC via USB port ,usually an external power supply is not needed, but be sure that USB can supply enough power. infa so stranichki razrabotchika ( Po povodu identichnosti kachestvennogo progera iz China i originala - polnost'yu identichni kak pravilo. Hvataet pitaniya ili net - razbirat'sya s portami i kabelyami (usb) kak pravilo. Vsegda pod rukoy EWS3 (ochen' udobno v kachestve indikatora). Obichno kogda R260 oblamivaetsya...polozhenie spasaet xprog-m ili etl...kak ni stranno. Ideal'nogo progera sredi vishe perechislennih net. No xprog-m eto kombik s vozmozhnostyami v 3-x raza bol'she chem stoit. A vot eto iz manuala na ETL912... Note: Use On-Board programming interface only if target MCU secured. Extra care must be taken when working with FL ASH Option/Security byte in ICP interface. If U not erased (all EEPROM and FLASH bytes not equal to $FF) and FLASH Security byte not equal to XXXXXX10B, further access to MCU will be blocked after next reset. To grant access to MCU device must be mounted on corresponding adaptor and On-Board programming interface must be used. In all other respects EEPROM/FLASH programming technique similar to MC68HC912 devices. A shishki polyubomu pridetsya nabivat'. Последний раз редактировалось badik; 28.01.2013 в 12:57. | |
| Сказал Спасибо badik за это сообщение: | bmwdoctor (28.01.2013) |
