| | #21 |
Откуда: Москва Авто: BMW e39 528 Есть клубные рамки |
P1623 Pedal Position Sensor Potentiometer Supply (***(May not be applicable for Honda / Acura)***) P1624 Pedal Position Sensor Potentiometer Supply Channel 1 Electrical (***(May not be applicable for Honda / Acura)***) P1624 Customer Snapshot Requested - Data Available (***(May not be applicable for Honda / Acura)***) P1625 Pedal Position Sensor Potentiometer Supply Channel 2 Electrical (***(May not be applicable for Honda / Acura)***) P1626 Theft Deterrent System - Fuel Enable Circuit P1626 Implausible Signal From Transmission Control Module (***(May not be applicable for Honda / Acura)***) P1630 Theft Deterrent - PCM in Learn Mode P1631 Theft Deterrent - Password Incorrect P1631 Throttle Position Sensor Signal Too High (***(May not be applicable for Honda / Acura)***) P1632 Theft Deterrent - Fuel Disabled P1632 Throttle Valve Adaptation; Adaptation Condition Not Met (***(May not be applicable for Honda / Acura)***) P1632 Traction Control System Malfunction (***(May not be applicable for Honda / Acura)***) P1632 Throttle Position Sensor Supply Voltage (***(May not be applicable for Honda / Acura)***) P1633 Ignition Supplement Power Circuit Low Voltage P1633 Throttle Valve Adaptation; Limp Home Position (***(May not be applicable for Honda / Acura)***) P1633 Keep Alive Power Voltage Too Low (***(May not be applicable for Honda / Acura)***) P1634 Ignition 1 Power Circuit Low Voltage P1634 Throttle Valve Adaptation; Spring Test Failed (***(May not be applicable for Honda / Acura)***) P1635 Throttle Valve Adaptation; Lower Mechanical Stop Not Adapted (***(May not be applicable for Honda / Acura)***) P1635 5 Volt Reference Circuit (***(May not be applicable for Honda / Acura)***) P1635 Tire/Axle Out Of Acceptable Range (***(May not be applicable for Honda / Acura)***) P1636 Throttle Valve Control Circuit (***(May not be applicable for Honda / Acura)***) P1636 Inductive Signiture Chip Communication Error (***(May not be applicable for Honda / Acura)***) P1637 Throttle Valve Position Control; Control Deviation (***(May not be applicable for Honda / Acura)***) P1638 Throttle Valve Position Control; Throttle Stuck Temporarily (***(May not be applicable for Honda / Acura)***) P1639 Throttle Valve Position Control; Throttle Stuck Permanently (***(May not be applicable for Honda / Acura)***) P1639 5 Volt Reference 2 Circuit (***(May not be applicable for Honda / Acura)***) P1639 Vehicle ID Block Not Programmed Or Corrupt (***(May not be applicable for Honda / Acura)***) P1639 Throttle Position Sensor Implausible Signal (***(May not be applicable for Honda / Acura)***) P1640 Internal Control Module (ROM/RAM) Error (***(May not be applicable for Honda / Acura)***) P1640 DTC's Available In Another Module (***(May not be applicable for Honda / Acura)***) P1640 Driver 1 - Input High Voltage P1640 Engine Control Module Inoperative (***(May not be applicable for Honda / Acura)***) P1641 Malfunction Indicator Lamp (MIL) Control Circuit P1642 Vehicle Speed Output Circuit P1644 Delivered Torque Output Circuit P1645 EVAP Solenoid Output Circuit P1646 EVAP Vent Valve Output Circuit P1648 CAN-Bus System Component Failure (***(May not be applicable for Honda / Acura)***) P1649 Implausible Signal From ABS Control Module (***(May not be applicable for Honda / Acura)***) P1650 Driver 2 - Input High Voltage P1650 Power Steering Pressure Switch Malfunction (***(May not be applicable for Honda / Acura)***) P1650 Power Steering Pressure Switch Out Of Range (***(May not be applicable for Honda / Acura)***) P1651 Power Steering Pressure Switch Input Malfunction (***(May not be applicable for Honda / Acura)***) P1651 Power Steering Pressure Switch Signal Malfunction (***(May not be applicable for Honda / Acura)***) P1652 Lift/Dive Circuit P1654 Cruise Disable Output Circuit P1656 Automatic Transaxle P1660 Cooling Fan Control Circuits P1660 A/T FI Data Line Failure P1670 ODM has Detected a Voltage greater than 33 volts (***(May not be applicable for Honda / Acura)***) P1676 FPTDR Signal Failure P1678 FPTDR Signal Line Failure P1680 Clutch Released Switch Circuit (***(May not be applicable for Honda / Acura)***) P1681 No I/P Cluster CCD/J1850 Messages Received (***(May not be applicable for Honda / Acura)***) P1681 A/T FI Signal A Low Input P1682 A/T FI Signal A High Input P1682 Charging System Voltage Too Low (***(May not be applicable for Honda / Acura)***) P1683 Speed Control Power Relay or S/C 12V Driver Circuit (***(May not be applicable for Honda / Acura)***) P1684 Battery Disconnected Within Last 50 Starts (***(May not be applicable for Honda / Acura)***) P1685 Skim Invalid Key (***(May not be applicable for Honda / Acura)***) P1686 No SKIM Bus Message Received (***(May not be applicable for Honda / Acura)***) P1686 A/T FI Signal B Low Input P1687 A/T FI Signal B High Input P1687 No Cluster Bus Message (***(May not be applicable for Honda / Acura)***) P1689 Traction Control Delivered Torque Output Circuit (***(May not be applicable for Honda / Acura)***) P1690 Malfunction Indicator Lamp (MIL) Electrical (***(May not be applicable for Honda / Acura)***) P1693 DTC Detected In Companion Mode (***(May not be applicable for Honda / Acura)***) P1694 Fault In Companion Mode (***(May not be applicable for Honda / Acura)***) P1695 No CCD/J185O Message From BCM (***(May not be applicable for Honda / Acura)***) P1696 PCM Failure EEPROM Write Denied (***(May not be applicable for Honda / Acura)***) P1697 PCM Failure SRI Mile Not Stored (***(May not be applicable for Honda / Acura)***) P1698 No Bus Message From TCM (***(May not be applicable for Honda / Acura)***) P1698 Engine Torque Control Cut Signal Circuit Low Input (***(May not be applicable for Honda / Acura)***) P1699 Engine Torque Control Cut Signal Circuit High Input (***(May not be applicable for Honda / Acura)***) P1700 TPS Circuit Malfunction For AT (***(May not be applicable for Honda / Acura)***) P1701 Transmission Solenoid Malfunction (***(May not be applicable for Honda / Acura)***) P1701 Cruise Control Set Signal Circuit Malfunction For AT (***(May not be applicable for Honda / Acura)***) P1703 Brake On/Off Switch (***(May not be applicable for Honda / Acura)***) P1703 Brake On/Off Switch Out Of Range (***(May not be applicable for Honda / Acura)***) P1703 Low Clutch Timing Control Solenoid Circuit Malfunction (***(May not be applicable for Honda / Acura)***) P1705 Automatic Transaxle P1705 Transmisson Range Sensor Out Of Range (***(May not be applicable for Honda / Acura)***) P1705 Transmisson Range Sensor (***(May not be applicable for Honda / Acura)***) P1705 Throttle Position Sensor ((***(May not be applicable for Honda / Acura)***)) P1706 Automatic Transaxle P1706 Park/Neutral Position (PNP) Switch (***(May not be applicable for Honda / Acura)***) P1709 Automatic Transaxle P1709 Park/Neutral Position Switch Out Of Range (***(May not be applicable for Honda / Acura)***) P1710 Automatic Transaxle P1711 Transmission Fluid Temperature Sensor (***(May not be applicable for Honda / Acura)***) P1711 Engine Torque Control Signal 1 Circuit Malfunction (***(May not be applicable for Honda / Acura)***) P1712 Engine Torque Control Signal 2 Circuit Malfunction (***(May not be applicable for Honda / Acura)***) P1713 Automatic Transaxle P1719 Skip Shift Solenoid Circuit (***(May not be applicable for Honda / Acura)***) P1729 4x4 Low Switch Malfunction (***(May not be applicable for Honda / Acura)***) P1734 Pressure Control Solenoid "B" Electrical (***(May not be applicable for Honda / Acura)***) P1738 Automatic Transaxle P1738 Pressure Control Solenoid "C" Electrical (***(May not be applicable for Honda / Acura)***) P1739 Automatic Transaxle P1740 Automatic Transaxle P1743 Pressure Control Solenoid "E" Electrical (***(May not be applicable for Honda / Acura)***) P1744 Pressure Control Solenoid "A" Electrical (***(May not be applicable for Honda / Acura)***) P1746 EPC Solenoid Failed Low (***(May not be applicable for Honda / Acura)***) P1746 Transmission Control Module Output Stage (***(May not be applicable for Honda / Acura)***) P1747 CAN Bus Monitoring (***(May not be applicable for Honda / Acura)***) P1747 EPC Solenoid Short Circuit (***(May not be applicable for Honda / Acura)***) P1748 Transmission Control Module Self Test (***(May not be applicable for Honda / Acura)***) P1749 Secondary Pressure Solenoid Communication Error (***(May not be applicable for Honda / Acura)***) P1749 EPC Solenoid Open Circuit (***(May not be applicable for Honda / Acura)***) P1750 Secondary Pressure Solenoid Circuit Range/Performance (***(May not be applicable for Honda / Acura)***) P1751 Secondary Pressure Solenoid Open Circuit (***(May not be applicable for Honda / Acura)***) P1751 Shift Solenoid #1 (SS1) (***(May not be applicable for Honda / Acura)***) P1751 A/T Control Relay Malfunction (***(May not be applicable for Honda / Acura)***) P1753 Automatic Transaxle P1754 Coast Clutch Solenoid (***(May not be applicable for Honda / Acura)***) P1756 GOV Press Not Equal To Target @ 15-20 PSI (***(May not be applicable for Honda / Acura)***) P1756 Shift Solenoid #2 (SS2) (***(May not be applicable for Honda / Acura)***) P1757 GOV Press Not Equal To Target @ 15-20 PSI (***(May not be applicable for Honda / Acura)***) P1758 Automatic Transaxle P1760 Overrun Clutch Solenoid Valve (***(May not be applicable for Honda / Acura)***) |
| | #22 |
P1761 Shift Solenoid Malfunction (***(May not be applicable for Honda / Acura)***) P1761 Shift Solenoid #3 (SS3) (***(May not be applicable for Honda / Acura)***) P1762 Gov Press Sen Offset Volts Too Low or high(***(May not be applicable for Honda / Acura)***)P1763 Governor Pressure Sensor Volts Too High (***(May not be applicable for Honda / Acura)***) P1764 Governor Pressure Sensor Volts Too Low (***(May not be applicable for Honda / Acura)***) P1765 CAN Throttle Valve (***(May not be applicable for Honda / Acura)***) P1765 Trans 12 Volt Supply Relay CTRL Circuit (***(May not be applicable for Honda / Acura)***) P1768 Automatic Transaxle P1770 CAN Torque Interface (***(May not be applicable for Honda / Acura)***) P1773 Automatic Transaxle P1778 Automatic Transaxle P1780 CAN Torque Reduction (***(May not be applicable for Honda / Acura)***) P1780 Transmission Control Switch (***(May not be applicable for Honda / Acura)***) P1780 Transmission Control Switch Out Of Range(***(May not be applicable for Honda / Acura)***) P1780 Park/Neutral Position Switch Malfunction (Only For A/T) (***(May not be applicable for Honda / Acura)***) P1781 4x4 Switch Out Of Range (***(May not be applicable for Honda / Acura)***) P1783 Transmission Over Temperature Condition (***(May not be applicable for Honda / Acura)***) P1786 Automatic Transaxle P1790 Automatic Transaxle P1791 Automatic Transaxle P1792 Automatic Transaxle P1794 Automatic Transaxle P1810 TFP Valve Position Switch Circuit (***(May not be applicable for Honda / Acura)***) P1811 Maximum Adapt and Long Shift (***(May not be applicable for Honda / Acura)***) P1819 Internal Mode Switch - No Start/Wrong Range (***(May not be applicable for Honda / Acura)***) P1820 Internal Mode Switch Circuit A Low (***(May not be applicable for Honda / Acura)***) P1822 Internal Mode Switch Circuit B High (***(May not be applicable for Honda / Acura)***) P1823 Internal Mode Switch Circuit P Low (***(May not be applicable for Honda / Acura)***) P1825 Internal Mode Switch - Invalid Range (***(May not be applicable for Honda / Acura)***) P1826 Internal Mode Switch Circuit C High (***(May not be applicable for Honda / Acura)***) P1851 Implausible Signal From ABS Control Module (***(May not be applicable for Honda / Acura)***) P1854 Drive Train CAN-Bus Inoperative (***(May not be applicable for Honda / Acura)***) P1860 TCC PWM Solenoid Circuit Electrical (***(May not be applicable for Honda / Acura)***) P1887 TCC Release Switch Circuit (***(May not be applicable for Honda / Acura)***) P1899 Park/Neutral Position Switch Stuck In Park or In Gear (***(May not be applicable for Honda / Acura)***) P1900 Output Shaft Speed Sensor Circuit Failure (***(May not be applicable for Honda / Acura)***) P2008 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit P2009 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit Low Voltage P2010 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit High Voltage P2066 Fuel Level Sensor 2 Performance P2067 Fuel Level Sensor 2 Circuit Low Voltage P2068 Fuel Level Sensor 2 Circuit High Voltage P2096 or P2098 Post Catalyst Fuel Trim System Low Limit P2097 or P2099 Post Catalyst Fuel Trim System High Limit P2100 Throttle Actuator Control (TAC) Motor Control Circuit P2101 Control Module Throttle Actuator Position Performance P2105 Throttle Actuator Control (TAC) System - Forced Engine Shutdown P2107 Throttle Actuator Control (TAC) Module Internal Circuit P2119 Throttle Closed Position Performance P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage P2135 Throttle Position (TP) Sensor 1-2 Correlation P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation P2176 Minimum Throttle Position Not Learned P2500 Generator L-Terminal Circuit Low Voltage P2501 Generator L-Terminal Circuit High Voltage ВСЁ!!!!!!!!! |
| | #23 |
И вот, кстати, сайт по теме: |
| Сказал Спасибо Tyler за это сообщение: | evgenij2001 (12.10.2009) |
| | #28 |
Откуда: Москва Авто: BMW e39 528 Есть клубные рамки | если она и осталась у кого-то, так это только у самого akm2008. Да и скорее всего, там ничего умного не написали
| | #30 |
Откуда: Москва Авто: BMW e39 528 Есть клубные рамки | geheim, а что? пришли на почту, плз. Адрес прислал в личку. На самом деле в форум встроил функцию - при написании сообщения нажимаем на "Расширенный режим" и там на выбор есть много файловых хостингов - выкладываем сразу туда, не выходя из форума и оставляем тут ссылку...эх никак руки не доходят инструкцию написать Надеюсь, к следующей неделе осилю
| Опции темы | |
| Опции просмотра | |
| Ликвидация новых запчастей по закупке | АндрейСергеевич | Продажа запчастей BMW | 2 | 02.07.2024 16:26 |
| Все опции БМВ на русском языке | Tyler | Выбираем БМВ | 21 | 19.06.2014 12:09 |
| Модельный ряд BMW пополнил автомобиль BMW 740d | Tyler | Новости BMW | 3 | 30.07.2009 19:24 |
| BMW 5 серии Gran Turismo на Женевском автосалоне 2009 | Tyler | Новости BMW | 0 | 26.02.2009 18:00 |
