INPA (NCS Expert)- кодирование
Like Tree59Likes
Старый 02.07.2010, 18:55 #11
Аватар для Zeke
Сказал спасибо: 158
Поблагодарили 12 раз(а) в 7 сообщениях
Авто: BMW E70 3.0d LCI
Вот чего сегодня мне дали,может кому пригодится
**** FSW-PSW :action caused by aktiv/nicht aktiv selection ****
ABKLAPPSTELLUNG : wiper arm parked position changes from horizontal to verticle when active
ABSCHALT_KL50 : turn off starter switch when active
ABSCHALTKRITERIUM : enable safety pinch switch for power windows when active
ABSCHALTMELDUNG : shutdown signal?
ABSCHALTUNG_VERBRAUCHER : switch off user?
ABSTAND_KALTPULSE :
ABSTELLPOS_CUSTOM : shut down?
ABSTELLPOS_SMC :
ACC_FLAG : active cruise control indicator
ADRESSE_AUSWERTEN : analyse, evaluate
AIRBAG_BEIFAHRER_1 : passenger airbag
AIRBAG_FAHRER_1 : driver airbag
AIRBAG_TRIGGERED_E-CALL : deployed airbag sends cellular emergency call when active
AKUSTIK_ABBLENDLICHT :low beam alarm
AKUSTIK_BREMSLICHT : brake light alarm
AKUSTIK_DSC_ASC : dsc engaged alarm
AKUSTIK_HECKKLAPPE : trunk open alarm
AKUSTIK_KONZEPT : alarm concept
AKUSTIK_PARKBREMSE : parking brake engaged alarm
AKUSTIK_RDKS : low tire pressure alarm
AKUSTIK_RUECKLICHT : tail light alarm
AKUSTIK_TUEREN : door open alarm
AKUSTIK_WASCHWASSER : low washer fluid level alarm
AL_ALS_DRL : low beam as daytime driving light
ALARM_AKUSTISCH_LANG : long alarm sound
ALARMSCHALTER_SI_FZG : alarm switch ?
ALARMSCHALTER_TAXI :
ALARM_OPT_ABBLENDLICHT : alarm flashes low beam when tripped
ALARM_OPT_WARNBLINKER : " " emergency flashers when tripped
ALARM_OPT_FERNLICHT : " " high beam when tripped
ALC : adaptive headlights
ALC_AUSWERT_GRADIENT :
ALC_AUSWERT_PROP_ABWEICH :
ALC_FAILSAFE_FCT_EIN :
ALC_FAILSAFE_NSW_AUS_OPT1 :
ALC_FAILSAFE_NSW_AUS_OPT2 :
ALC_FAILSAFE_NSW_EIN :
ALC_FAILSAVE_NSW_LOCK :
ALC_FAILSAVE_NSW_NEU :
ALC_GRADIENT_SCHLECHTWEG :
ALC_KLS_ENABLE :
ALC_KLS_DISABLE :
ALC_LED_DEF :
ALC_LWR_VORZEICHEN :
ALC_SAETT_TIMER_SCHLECHTW :
ALC_SCHWENK_LATCH :
ALC_VERBAUT :
ANKUNFTSZEIT_VON_NAVI : time of arrival using navigation
ANHAENGERKUPPLUNG : when trailer attached to wire harness reverse pdc turned off
ANLAUFSTROMBEGRENZ_MEMO :
ANPRESSDRUCKVERSTELLUNG : downforce adjustment?
ANTI_DROEHN_STELLUNG :
ANZEIGE_EML : display electronic motor load
ANZEIGE_ANKUNFTSZEIT : display e.t.a.
ANZEIGE_UHR_IM_DISPLAY :
ASC : automatic stability control
ASC3_AUSWERTUNG : analysis?
ASC_PREDRIVE_UEBER_SG :
ASL :
ASL_DSC_5_7 :
ATEMP_WARNUNG_KALTLAND :
AUFHEIZAUTOMATIK : automatic heater control?
AUSSENGEFUEHRTE_SHDUSSENTEMP_ABH_GEBL_ANH_1
AUSSENTEMPERATUR_KORR :
AUSSENTEMP_WARN_AKUSTIK :
AUSSENTEMP_WARNUNG_GONG : External Low Temp Warning Gong
AUSSTATTUNG_RPA :
AUSSTELLFENSTER :vent window?
AUSTAUSCHPUNKT :replaceable part?
AUSWERT_GRADIENT :
AUSWERT_PROP_ABWEICHUNG :
AUT_SPIEGELVERSTELLUNG : automatic mirror adjustment linked to specific key
AUT_SITZVERSTELLUNG :choose between automatic seat adjustment [nach_fb_entriegeln] when remote signals door open or[nach_entr_u_tuer_oeffnen] when door opened
AUTO_LED_GEBL_MANUELL :
AUTO_LED/SCHRIFTZUG :
AUTO_LWR_ENABLE :automatic headlight leveling system
AUTOMATISCHER_NOTRUF : automatic emergency call
AUTOM_FAHRL_STEUERG :automatic head light control unit [ALS on/off]
AUTO_ZV_DISABLE : disable automatic central locking
BACKUP_ANTENNA :
BACKUP_BATTERY :
BACKUP_BATTERY_ENABLED :
BAUREIHE_A : series
BC_ANFORD_WEGFAHRSICH :immobiliser demand with alarm?
BC_CODE_AKTIV :enables board computer
BC_KL_R : In R position, the BC shows the last function chosen.
BC_V_KORREKTUR :
BEDIENSTELLE_BFT :control section passenger side door
BEIFAHRERBAG_STUFE2_1 :passenger
BEIKLAPPEN_B_KOMFORTSCHL : when active 2 open signals on remote opens door & drivers window
BELUEFTUNGSKLAPPE_OEFF_1 : Ventilation Flap opening
BEWERTUNG_FEHLER :defect evaluation?
BETRMODI_DEAKT_KL15_EIN :
BETR_STD_AUTO_LOESCH :B_SATELLIT_1
BETR_STD_NICHT_LOESCHEN :
BFD_ABS_STUFE3 :
BFD_ASC_REG :
BFD_AX_REF :
BFD_ON :brake force display on
BFD_OPTION :
BFD_SCHWELLE :
BFD_ST3_ON :
BFD_SW1_STUFE :
BFD3_ASC_AKTIV :
BF_UEBERWACHUNG :passenger control
BI_XENON :
BIXENON_EIN_BEI_LICHTHUPE :
BL_ALS_SL_DIMMEN : brake light as parking lights dimmed?
BL_DIMMEN : brake light variable?
BL_DIMMUNGS_OPT_1 :
BLEND_CHECK_IST_WINKEL :
BLEND_CHECK_SOLL_WINKEL :
BL_GEDIMMT_ALS_ERSATZ :brake light &
BL_GED_ALS_ERSATZ_MIT_AH :brake light &
BLK_DIMMUNGS_OPT_1 :turn signal
BLK_H_L_PICT :left rear turn signal in dashboard
BLK-H-R-PICT :right " " " " "
BLK_V_GED_ALS_PARKLICHT : front turn lights & together as parklight
BLK_V_GED_ALS_SIDEMARK : front turn light & together as sidemarker?
BLK_V_GEDIMMT_ALS_ERSATZ :front turn light & together as
BLK_V_L_PICT :left front turn signal in dashboard
BLK_V_R_PICT :right " " " " "
BLS_PRUEFEN :brake light switch
BLST1_BLST3 :
BL_UND_BLK_H_GEM_BLK : brake light & blinking rear turn light together when braking
BL_UND_BLK_H_GEMEINSAM : brake & rear turn light together
BL_UND_BLK_H_GEM_WBL :brake & rear turn light together as hazards
BPLUS_TRENNUNG1_1 : safety battery terminal
BRAKE_FORCE :
BREMSFLUESSIGK_INV : brake fluid ?
BREMSLICHTSCHALTER : brake light switch
BREMSWARNLEUCHTE : brake warning light
B_SATELLIT_1 :
CAN_11H :
CAN_AUSFALL_BEWERTUNG :
CAN_EBV :
CAN_INSTR2_SENDEN :
CAN_OELDRUCK : oil pressure on can bus
CAN_S_GSU : light sensor on can bus
CC_ABBLENDLICHT : low beam
CC_BREMSLICHT_MITTE : stop light
CC_BLINKER_VORN : front turn signal
CC_FERNLICHT : high beam
CC_HECKKLAPPE : tail gate
CC_KENNZEICHENLEUCHTE_LI : number plate light
CC_LAMPEN :
CC_MELDUNG_AL_L : message low beam
CC_NSL_LINKS : rear left fog light
CC_RUECKLICHT :
CC_TUEREN :
CC_WASCHWASSER :
CC_ZUSATZBLINKER :
CENT_LOCK_MGL_VO_TUER_AUF :
COD_IFL :
COD_IFL_AN_PIN48 :
COD_IFL_ASYNC :
CHECK_IGNITIONA :
CHECK_IGNITIONC :
CHECK_IGNITIONK :
CHECK_SMC_ERROR :
CLT_AKTIV_IM_CRASH_MODE :
CORNERING_BREAK_CONTROL :
CRASH_DISABLE_BEWERTUNG_10S :
CRASH_DISABLE_HECKKL_10S :
CRASH_KLEMME_58G_EIN :
CRASH_WARNBLINKEN : turn on hazard lights when car crashed
CUSTOMER_CALLS_OVER_GMIN
CHECK_FGN_SMC_ALC_OFF :
DATENSATZ_1
DAUERFAHRLICHT_EU : enables light control sensor for auto. headlights
DBC_DBS : dynamic brake control-dynamic brake support
DBC_MSB :
DEB_TIME_CS_0 :
DEBUG_SIGNAL :
DEF_PIN_20_DEFEKTBLINKEN :
DEF_PIN_20_VOR :
DEF_PIN_37_DEFEKTBLINKEN :
DEF_PIN_37_VOR :
DELTA_LIMIT_GESETZ :
DIAGNOSE_DELAY_ZEIT :
DIAGNOSE_SCHRITTMOTOR : step motor
DIAGNOSE_ZWP :
DIFFERENZ_ANLAUF_BLOCK :
DISPLAYANZEIGE_HIGH :
DISPLAYANZEIGE_LOW :
DISPLAY_GEBLAESRAHMEN :
DOPPELKLICK_AUF :
DOPPELKLICK_HEBEN :
DOPPELKLICK_ZU :
DRL_BLK_VORN_GEDIMMT :
DROSSEL : restrictor
DSC_DEF_GONG : warning gong when dsc activated
DTC_LAMPE :
DWAH_PIN_C17 : alarm system horn
DWA_BLK_ABSCHALTEN : power to windows shutdown with alarm
DWA :activates alarm when remote used to open or close car doors
DWA-QUITTIERUNG : anti theft system acknowledgement
DWA_NOTENTSCHAERFEN :alarm will not de-activate
DYNAM_LWR_ENABLE :
DYN_BREMS_UNTERSTUETZUNG :
E52_LINKS_LENKER :
E52_RECHTS_LENKER :
E53_FAHRZEUG :
E9X_HIMMEL :
EBV_LAMPE : electronic brake force light
E-CALL_HARDKEY_FITTED : emergency call
EC_LUEFTER :
EEPROM_SHD :
EHC : electronic height control
EINGANG_2 : entry
EINGANG_2_KONTAKT_GESCHL :
EINKLEMMSCH_HINTEN : rear window pinch sensor
EINKLEMMSCH_VORNE : front window pinch sensor
EINSCHALTMELDUNG_BEI_1MA :start?
EINSCHALTMELDUNG_IMMER :power up message always
EINSCHALTVERZOEGERUNG : start delay
EINSPRITZANLAGE_CAN : fuel injection information to can bus
EINSTIEGSHILFE : steering wheel movement with key in 1st position
EINSTIEGSHILFE_HOEHE : steering wheel up & down [height]
EINSTIEGSHILFE_LAENGE : steering wheel in & out [length]
EIS_AUSBLENDEN :
E_LUEFTER :
ENABLE_EURO_NCAP :
ENABLE_US_SBR :
ENTSICHERN_CENTERLOCK :central locking button works when doors locked & key not in ignition when active
ENTFALL_ZV_BEDIENST_HECK :
ENTR_HKL_MGL_WENN_VER :
ENTR_HS_MGL_WENN_VER :
ENTR_KL.R_30S_NACH_SICH :
ERKENNUNG_BREMSLICHT : recognise brake light?
ERKENNUNG_SITZBELEGUNG_1 : Recognition seat allocation (don't switch this off otherwise the airbag system gets up-set)
ERR_LWR_L_IGNORIEREN :
ERR_LWR_R_IGNORIEREN :
ERR_SCHWENK_L_IGNORIEREN :
ERR_SCHWENK_R_IGNORIEREN :
EWS_3_SCHNITTSTELLE : electronic immobiliser interface
FAHRERBAG_STUFE2_1 : driver
FEHLER_ABTAKTEN : fault scanned?
FEHLER_HECKSCHEIBE :rear window fault?
FERNBEDIENUNG : remote control
FERNWIRKEN_GENERELL : telecontrol
FERNWIRKEN_NAVZIELE :
FERNWIRKEN_POSITION :
FERNWIRKEN_STANDHEIZUNG :
FERNWIRKEN_TELEFONLISTEN :
FENSTERHEBER_HINTEN : rear window
FENSTERHEBER_VORNE : front window
FH_ABSENKUNG_SPERREN : window lowering when obstucted
FH_ABSENKEN_VERDECK_VERDECK_OEFF :" " " convertible top
FH_AUF_STUFE2_KLR_AUS :
FH_BEIFAHRERTUER_TIPP_AUF : Passenger Window power down one touch
FH_BEIFAHRERTUER_TIPP_ZU : Passenger Window power up one touch
FH_FAHRERTUER_TIPP_AUF : Driver Window power down one touch
FH_FAHRERTUER_TIPP_ZU : Driver Window power up one touch
FH_INIT_TRANSPORTMODE :
FH_NACH_TUERE_AUF :
FH_TIPP_DISABLE_TUER_AUF :
FH_TUEREN_HINTEN_TIPP_AUF :rear window power down one touch
FH_TUEREN_HINTEN_TIPP_ZU : rear window power up one touch
FH_ZTR_SCHALTER_TIPP_AUF : window switch down one touch
FH_ZTR_SCHALTER_TIPP_ZU : " " up " "
FILTER_DETEKTION_WEIT :
FL_AL_AUS : high beam as low beam
FLC_DIMMER_OPTION :
FLC_LED_EIN ;
FL_KL_50 : high beam when starting
FL_UND_NSW_NICHT_GLEICHZ : high beam & fog lights not used together when active
FONDGEBLAESE : air conditioning to rear seats
FOND_MODUL_1 : rear module
FS_UNLOCK_300MS_P_BUS : crash sensor unlock
Fußraumklappen: floor flaps (IHKA)
FUNK_INNENRAUMSCHUTZ :radio interior space monitoring
FUNKINNENRAUMSCHUTZ_HI :
FUNKTION_DSC :
FUNKTION_DTC :
FUNKTION_RPA :
FUNKTIONTUERSCHLOSS :function Door Lock
FUNKUHR :
FUSSRAUMKLAPPE SCHLIES : floor air Flaps close
GEBL_OFF_MODE :
GEBLAESE_BALKEN : blower bar automatic mode
GEBL AUT B ZUEND EIN : blower automatic at ignition on
GEBLAESEKORREKTUR : blower speed correction
GEBLAESEBALKEN_AUT_MOD_1 :
GED_FL_ALS_DRL : dimmed high beam as daytime running light
GESCHW_PRUEFUNG : speed
GLASDACH : glass sliding sunroof
GURTSCHLOSS_FAHRER_1 :driver seat belt buckle?
GURTSCHLOSS_SPANNUNGSS_1 :
GURTSCHLOSS_STROMSS_1 :
GURTSTRAFFER_BEIFAHRER_1 :passenger seat belt tensioner
GURTSTRAFFER_FAHRER_1 :driver seat belt tensioner
GURTWARNUNG_EURO_NCAP :seat belt warning
GURTWARNUNG_GONG :seat belt warning gong
GURTWARNUNG_TEXT :seat belt warning optical
GPS_UHR :get time from gps for radio clock to function you need the LW-receiver in Germany and UK,
HALLSENSOR_VSW72 :
HALLSENSOR_VSW8 :
HBA_DSC_5_7 :
HEBEN_AUS_GEOEFFNET :
HECKKLAPPE_ENTSICHERN : open trunk lid with remote control
HECKSCHEIBE_ENTRI_INNEN :heated rear window?
HEIMLEUCHTEN : home lights activated by flashing high beam with key off
HEIMLEUCHTEN_ABBRUCH : home light stop
HEIMLEUCHTEN_AL :home lights are low beam
HEIMLEUCHTEN_BL : " " " turn signals
HEIMLEUCHTEN_FL : " " " high beam
HEIMLEUCHTEN_FUNKSCHL :lights on on closing car with remote
HEIMLEUCHTEN_KL58G : home lights are interior backlighting, cluster, ashtray etc.
HEIMLEUCHTEN_KZL : " " " license plate
HEIMLEUCHTEN_NSL : " " " rear foglight
HEIMLEUCHTEN_NSW : " " " front foglight
HEIMLEUCHTEN_RFS : " " " reverse light
HEIMLEUCHTEN_SL_H :" " " rear parking lights
HEIMLEUCHTEN_SL_V :" " " forward parking lights
HEULTON :
HHS_AUTOMATIK : enable automatic rear window defogger
HILLDESC_DSC_5_7 :
HILLDESC_DXC_8 :
HIMMEL_AUTO_AUF :
HIMMEL_AUTO_ZU :
HKL_SPERREN_BEI_ZS :tailgate lift barriers with ZS
HUB_VERZOEGERUNG_FH_VORN :
HWL_1 :
HYDRAUL_HECKKLAPPE : hydraulic trunk opener
HYD_HECKKLAPPE_OHNE_PDC :
IB_EIN_16MIN_WENN_STANDLI :interior lighting control signal
IB_EIN_BEI_HKK/HSK :
IB_BEI_KL.R_AUS :interior light turns on when ignition turned off after driving with headlights
IB_CRASH_ON_0_KMH :
IB_EIN_HK_AUF :
IB_EIN_SCHLOSS_ENTRIEGELN :interior lights on when unlocked by key
IB_POWER_CONF_0 :
IB_SPERRE_BEI_FEHLER :
IK_BUS_TEILNEMER :
IR_FERNBEDIENUNG :infrared remote control
IR_FERNBEDIENUNG_BF :
ITS_FRONTCRASH_1 :inflatable tubular support
ITS_LINKS_1 :
ITS_RECHTS_1 :
INNENLICHT_AN_MEHRFACH_ZV : pressing remote lock button twice turns on Interior Lights
INTERVALLZEIT_GESCHWABH :
KALTUEBERWACHUNG_AL : cold testing bulbs in low beam
KALTUEBERWACHUNG_BLK_HI :" " " " turn signal rear
KALTUEBERWACHUNG_BLK_VO :" " " " turn signal
KALTUEBERWACHUNG_BL_MI : " " " " brake light
KALTUEBERWACHUNG_FL : " " " " high beam
KALTUEBERWACHUNG_KZL : " " " " number plate
KALTUEBERWACHUNG_KZL_LI :" " " "
KALTUEBERWACHUNG_NSW : " " " " foglights
KALTUEBERWACHUNG_RL : " " " " reversing light
K_BUS_FB_SPERREN :
KBUS_FUNKTION :
K_BUS_FREI_OHNE :
K_BUS_FS_UNLOCK_300MS :
KEINE_L_R_SYNCHRONISATION :
KEINE_PARKLICHT_FUNKT :
KENNLINIENFELD2_AKTIV :
KENNLINIE_WAERMETAUSCHER :
KENNFELDKUEHLUNG :
KEY_MEMORY :
KEY_MEMORY_IHK : temperature set point stored from last time car used
KEY_MEMORY_RADIO : stereo/cd/ipod-channel & volume stored from last time car used
KISI_N_DEAKT_IM_CRASH :
KL50_ABSCHALT_AL : when key in start position stop low beams
KL50_ABSCHALT_FL : " " " " " " high beams
KL50_ABSCHALT_NSW : " " " " " " fog lights
KL_50_CAN : key in start position signal on can bus
KL_50_FUNK_AKT : pressing remote lock twice turns on interior lights
KLEMME_15_LIEGT_AM_SG_AN : when ignition switch tuned on
KLEMME_15_NOTWENDIG :
KLEMMENSTATUS :
KLEMME_50_UEBER_CAN :
KLIMABETR BEI ZUEND EIN : airconditioning on when ignition tuned on
KLIMATASTE_SPERREN :
KLAPPEN OEFFNEN : Flaps Opening
KLASSIF_DRIFT_ENA :
KLASSIF_LENKM_ENA :
KLASSIF_UEBERST_ENA :
KLS_BEI_AL_AKTIV :
KOPFBAG_FOND_LINKS_1 :
KOPFBAG_FOND_RECHTS_1 :
KOMFOEFFNEN_SPERRE_KEY_IN :open convertible soft-top by holding key in unlock position in drivers door lock
KOMFORTFUNK_BEREICH_HEB :
KOMFORTOEFFNEN_FB_O_FH_HI :remote opens rear window
KOMFORTOEFFNEN_FB_O_SHD : holding open button on remote opens windows without sun roof
KOMFORTOEFFNUNG : remote Opens doorlocks
KOMFORTOEFFNUNG_FB : convertible top opens by holding the open button on remote..Or opens all windows & sun roof on non convertible
KOMFORTOEFFNUNG_BEREICH :
KOMFORTSCHLIESSEN_VERDECK :
KOMFORT_POS_AUF :
KOMFORT_POS_ZU :
KOMFORTSCHLIE_FB_O_FH_HI : remote closes rear window
KOMFORTSCHLIE_FB_OHNE_SHD : holding close button on remote closes windows without sun roof
KOMFORTSCHLIESSUNG : remote locks doorlocks
KOMFORTSCHLIESSUNG_FB : convertible top closes by holding the close button on remote..Or closes all windows &sun roof on non convertible
KOMPRESSOR_GEREGELT :
KOMPRESSOR_TRANSPORT_SICH :
KUEHLMITTELUEBERTEMP_CAN :
LAMPENCHECK_GESICHERT :
LATENTWAERMESPEICHER :Latent-heat storer
LAUTSTAERKE_HINTEN : Volume in the Back
LDA_BEI_UNTERSPANNUNG : increase idle rpm
LDA_BEI_VERBRAUCHER :
LED_RUECKLICHT_OPTION :
LENKSAEULENMEMORY : steering column position memory
LENKSTOCKSCHALTER_ANALOG :
LEUCHTDICHTE_EXPO :
LEUCHTWEITENREG_AUTOM :
LEUCHTWEITENREG_DYNAM :
LEUCHTWEITENREGELUNG : front light aiming control
LICHTBEDIENEINHEIT :
LICHTWARNUNG : warning light
LINKSVERKEHR :
LOAD_DUMP :
LOGIK_HA_SPERRE :
LOGIK_SWBUNT :
LUFTFEDERUNG :
LWR_AUT_EXTERN :automatic verticle headlight aim control
LWR_TREIBER_BEW :
LWR_TREIBER_ERR :
LWR_VORZEICHEN :
MANUELLE_LWR :
MAX_BREMS_UNTERSTUETZUNG :
MAUT_N_ABBRECH_N_TUER_AUF :
MAUT_ZU_STOP_N_TUER_AUF :
MEMORY_SP_ABKLAPPEN_GM :
MEMORY_SPIEGELABKLAPPEN : folding mirror position memory
MEMORY_TIPP_BETRIEB :
MELDUNG_TASTER : signal sensor
MELDUNG_KATALYSATOR : signal catyltic convertor
MIN_WT_SOLLWERT :
MIT_LIN_SCHALTER :
MIT_SRA_EIN_LENKSTOCK :
MIT_WISCHER_SERVICEPOS : wiper in service position -verticle
MOTORDIAGNOSE :
MOTOR_NOTPROGRAMM_CAN :
MOTOR_OELSTAND_PREDRIVE :
M_TELEGRAM :
NACHREG_DYN_SLOW :
NEIGUGSGEBER : tilt sensor for alarm
NLR_AKTIV :
NON-TELEMATIC_E-CALL :
NOTENTRIEGELN_HKL :
NOTFUNKTION :
NOTLAUF_IMMER :
NOTSTROMSIRENE : Emergency Power Siren
NUR_EIN_TONGEBER :
NUR_KL15_BETRIEB : pdc operation on when key in run position when active
NSL_AH_US_OPTION : rear fog light
NSL_R_NICHT_ANSTEUERN : rear fog light
NSW_KEIN_TASTER : front fog light
NSW_KL_50 : front fog light when starting
N_VER_B_ERN_GESCHW_SCHWEL :
OFFENE_FENSTER :
OEFFNEN_AUS_GEHOBEN :
OEH_POWER_CONF_0 :
OELST_SENS_DEF_WARNUNG :
OELSTAND_MOTOR_CAN :
OHNE_CENTERLOCK_0 :
OHNE_FERNBEDIENUNG_1
OHNE_FERTIGUNGSMODE :
OHNE_FH_BF_HINTEN_0 :
OHNE_FH_BF_VORNE_0 :
OHNE_FH_FA_HINTEN_0 :
OHNE_GIERRATE :
OHNE_IB_0 :
OHNE_INTERVALLBETRIEB :
OHNE_POWERDOWNMODE :
OHNE_SERVICEMODE :
OHNE_SRA_0 :
OHNE_TRANSPORTMODE :
OHNE_VA_ZEITEN_0 :
OHNE_WISCH_BEI_WASCH
OPT_ENTRY_HELP :
OPTIMIERTE_SCHLIESSFKT
PANIC_CLOSE :
PANIC_FREIGABE_CAS :
PANIC_FREIGABE_KL15 :
PANIK_MODUS :
PARK/NEUTRAL_EINGANG :
PASSIVES_DWA_HORN :
PDC_EIN_BEI_KL15 :
PDC_SCHALTER : park distance control switch
PHASE_AUS_GEDIM_LICHT_AUS :
PHYSIOLOGIEANPASSUNG_1 :
PIKTOGRAMM_ERWEITERT : signalling e.g. the status of lights (bulbs)
PIN_5_10_AHM_ERS_FU_GESP :
PIN5_10_BFD :
PIN_20_ALS_FRA_LI_VO_2
PIN_29_30_AHM_ERS_FU_GESP :
PIN29_30_BL_NSL :
PIN_37_ALS_FRA_RE_VO_2 :
PM_SCHALTERBLOCK_FOND :
PM_SCHIEBEHEBEDACH :
PM_SITZMEMORY : driver seat memory
PM_SITZMEMORY_BEIFAHRER : passenger seat memory
PORTABLE_BT :
POTI_DIMMER_INVERS :
POTI_LWR_INVERS :
PREFIT_SIM_ENABLED :
PREDRIVE_RPA :
PRE_MSR :
PRE_VLABS :
PULS_TIME_OPTION
QUIT_AKUST_DAUER_10_MS :
QUIT_AKUST_ENTSCH : alarm beep on unlock (two beeps)
QUIT_AKUST_SCHAERF : alarm beep on lock (one beep)
QUIT_AKUST_SCHAERF_KLAPPE :
QUIT_OPT_ENTSCH : optical Acknowledge remote un-locking (two flashes)
QUIT_OPT_SCHAERF : optical Acknowledge remote locking (one flash)
QUIT_OPT_SCHAERF_KLAPPE :
RCC_UHR :
RCC_WECKZEIT : waking time?
RDC_ALARM_VIA_HFK : tire pressure control alarm
RDC_ALARM_VIA_KBUS :
RDKS : tire pressure monitor system
RECHTSVERKEHR :
REFERENZLAUF_LWR_KL15 :
REGENSCHLIESSEN :rain
REGENSCHLIESSENTILT :
REIFENDRUCKWARNSYSTEM : tire pressure warning
REIFENTOL_ABGLEICH_ASC :
REIFENTOLERANZABGLEICH :
RFS_AH_OPTION : reversing light
RL_INNEN_BLINKT : tail light
RR_SCHALTER :
RUECKFAHRGONG : reverse alarm sound
RUECKLICHT_INNEN_FEHLT :
SAETT_TIMER_SCHLECHTWEG :
SB_ANHEBEN :
SBE1_STATUS_VERZ_1 :
SBR_US : seat belt reminder
SCA_HECKKLAPPE : soft close tail gate
SCHAERFEN/ENTSCHAERFEN : choose between [schloss_und_fernbedienung]key&remote &[nur_mit_fernbedienung]key only
SCHALTER2_BL : switch #2 brake light
SCHALTER_R_GANG :
SCHEIBENABSENK_OHNE_EKS :
SCHEIBENINTENSIVREINIGUNG :
SCHIEBEHEBEDACH_TIPP_AUF : One touch sun-roof open
SCHIEBEHEBEDACH_TIPP_HEB : " " " " raise
SCHIEBEHEBEDACH_TIPP_SENK : " " " " lower
SCHIEBEHEBEDACH_TIPP_ZU : " " " " close
SCHEINWERFERREINIGUNG : wash headlights every 5th time the windscreen gets washed when active
SCHRITTMOTOR_UEBERLAUF : step motor overflow?
SECOND_HARDKEY :
SEL_ZV_SENDER_1 :
SENSOR_REGEN :
SEQ_M_GETRIEBE :
SERVOTRONIK :
SHD_ACTU_ALLOWED : sunroof module
SHD_CFL_ALLOWED :
SHD_CLOUD_ALLOWED :
SHD_RESTARTALLOWED :
SHD_RRD_ALLOWED :
SHD_SKB_OHNE_KL_OE :
SHD_SKB_OHNE_KL_SCH :
SHD_TMON_ALLOWED :
SIA_RESET_KI_TASTE : Coding maintenance interval
SICHERHEITSFAHRZEUG : security vehicle
SICHERHEITS_FZG :
SIDEBAG_FOND_LINKS_1 :
SIDEBAG_FOND_RECHTS_1 :
SIM_IN_TELEMATIK_READER :
SITZMEMORY_VERBAUT : seat memory obstructed
SL_INNEN_ALS_TWL : parking light
SL_VORNE_ALS_ZUSATZ_BLK : front parking light as aditional turn light
SMG_S_ANZEIGE :
SOFT ON/OFF : gradual fade out of the interior lights
SOLLWERT_KORREKTUR_1 :
SONDERFHZG_MIT_WSA :
SOS_ACTU_ALLOWED :
SOS_CFL_ALLOWED :
SOS_CLOUD_ALLOWED :
SOS_RESTARTALLOWED :
SOS_RRD_ALLOWED :
SOS_SKB_OHNE_KL_OE :
SOS_SKB_OHNE_KL_SCH :
SOS_TMON_ALLOWED :
SP_BEWERT_OD_ALC_NSW_AUS :
SPERRDIFFERENZREGELUNG :
SPERR_VENT_TEST :
SPERR_WLM_TEST :
SPERRZEIT_KL_R_AUS_0.2_S :
SPIEGELEINKLAPPEN :
SPIEGELABKLAPPEN : folding mirrors
SPIEGELHEIZUNG : heated mirror
SPIEGELHEIZUNG_VERBAUT : heated mirror obstructed
SPIEGELMEMORY : mirror position memory
SP_MOTOR_BEWERTEN :
SP_MOTOR_F_EINTRAG :
SP_MOTOR_STOP :
SPG_NACHREGELUNG :
SPG_NACHREGELUNG_LANGSAM :
SPG_NACHREGELUNG_ZUSATZ :
SPRACHE : Language selection
SPZ_PROG :
SRA_L322_RELAY :
SRA_MIT_WASCH_WISCH_SW
STANDHEIZUNG : stationary heating[webasto deisel]
STANDHEIZUNG_KONZEPT
STANDLICHT_VORNE :
STANDLUEFTUNG : park heating
STANDRUECKSCHALTUNG : Condition Resetting at standing
STATUS_LESEN :
ST3_SCHWEL
TAGFAHRLICHT_ECE : Daylight Headlights
TAGFAHRLICHT_DAN :
TAKTUNG_HHS :
TAKTEN HIGH LOW ANZEIGE : Clocks High Low Announcement
TAKTUNG_IB :
TAKTUNG_VERBRAUCHERABSCHA :
TASTE_UEBER_CAN :
TASTER_NSL : rear foglight sensor
TASTER_NSW : front " "
TASTER_NSW_NSL : front & rear foglights sensor
TELEMATIK :
TELEGRAMM_ZEIT_ZYKLUS :
TEMPCFLUSEOUTER :
TEMPCFLUSESENSOR :
TEMPERATUR_EINHEIT : Temperature Unit (C/F)
TEMP_FOND :
TEMPTMONUSEOUTER :
TEMPTMONUSESENSOR :
TESTBETRIEB :
TEST_OD_ST2_OHNE_NSW
TNK_DECKEL_WARNUNG :
TP_FUNKTION :
TRAKTIONDIFFERENZREGELUNG :
TREIBER_BEWERTEN :
TREIBER_F_EINTRAG :
TREIBER_STOP_OD_ALC_RE_OK :
TRIGGERSCHALTER_1 :
UEBERLAUFSCHRITTE_BEI_0 :
UEBERLAUFSTEPS_BEI_100% :
UEBER_ROLLSENSOR_1 :
UEBERSPANNUNGSSCHUTZ :
UEBERSPG_ABSCHALT_58G ;
UEBERSPG_ABSCHALT_BL :
UEBERSPG_ABSCHALT_NSL :
UEBERSPG_ABSCHALT_RFS :
UEBERSPG_ABSCHALT_SL :
UEBERSPG_ABSCHALT_SL_H :
UEBERSPG_ABSCHALT_SL_HI :
UEBERWACH_FENSTER_BF_HI :
UEBERWACH_FENSTER_F_VO :
UEBERWACH_HECKSCHEIBE :
ULF_EIN_AUS :hands free & charger
UMLUFT MEMORY : Circulating Air Flap Memory (remembers if re-circ is on after shutdown)
UNTERSTEUERUNGSALGORYTHM :
US_CALL_SERVICE_CENTER :
USE_SOS :
VA1_SPERRE_BEI_FEHLER :
VA_2 :
V_ABHAENGIG :
VERBRAUCH D1 : Consumption units
VERDECKKLAPPE_VORHANDEN :
VERL_ALARMZEI_WAEHR_ALARM :
VERRIEGELN_AUT_AB_X_KMH : automatic central locking after X KMH
VERRIEGELN_AUT_NACH_2_MIN : automatic central locking is re -locked after 2 MIN if you dont open a door
VERRIEGELN_SITZLEHNE_FA_1 :locking seat back?
VERRIEGELUNGSSCHWELLE : locking Device-swells (threshold) (speed of X above)
VERZUG_ENTR_HECKKLAPPE :
VOLUMENDURCHFLUSSPARA_2 :
VORGLUEHEN/KAT_HEIZEN_CAN : pre heat?
VKBODEN_ERKENNUNG :
WARMUEBERWACHUNG_AL : warm testing bulbs in low beams
WARMUEBERWACHUNG_AL_L : " " " " low beams
WARMUEBERWACHUNG_BL_MI : " " " " brakes
WARMUEBERWACHUNG_BLK_HI : " " " " rear turn signals
WARMUEBERWACHUNG_BLK_VO : " " " " front " "
WARMUEBERWACHUNG_FL : " " " " high beams
WARMUEBERWACHUNG_KZL_LI : " " " " number plate light bulb
WARMUEBERWACH_low beams_BLK :
WARNUNG_GESCHW_LIMIT :
WARNUNG_MOTOR_OELSTAND :
WARTEN_SCHEIBEN_ABGESENK :
WAKEUP_GENERELL ;
WASSERPUMPE :water pump?
WASSERSTOFF_FZG :
WEG_EINHEIT : Distance unit (distance, miles or km)
WEGFAHRSICHERUNG_AUTOM :immobilise ?
WEGSIGNAL_SERVO_ABS :
WE_MODE :
WISCHER_RUECK_GESCHW :
WISCHERINTERVALL: wiper interval
WISCHERPOTI : wiper timing
WISCHER_VOLLEND_KLR_AUS ;
WINDSCHOTT :
WINDSCHOTT_OPT :
XDT :
XENONLICHT_ZUEND_OPTION :
ZEIT_EINHEIT : Time unit (12H or 24H)
ZEIT_BIS_AUTOM_SPERREN ;
ZKE : central body electronics
ZUHEIZUNG : heating for diesel engine
ZUENDSCHL_GONG_R_EIN :
ZUENDSCHLUESSEL_KBUS :
ZUENDSCHLUESSEL_WARNUNG : beep & display when door opened to warn key left in Ignition
ZUSATZWASSERPUMPE :
ZV_AGGREGATE_TYP : central locking system
ZV_BEDIENST_BT_DISABLE :
ZV_ENTR_SCHL_BEI_DWA_AKT :
ZV_SELEKTIV : unlock drivers door only if [aktive] or all doors if [nicht aktive] key selective
ZV_VR_BEDIENSTELLE_HECK :
Zeke вне форума
Эти 3 пользователя(ей) сказали Спасибо Zeke за сообщение:
Alex B-M (20.04.2016), inspektor (19.01.2011), Ural (08.07.2010)
INPA (NCS Expert) - кодирование - часть 2 Tyler Диагностика BMW | кодирование | программирование 6000 10.05.2025 20:21
Просветите чайника по INPA ///Man Диагностика BMW | кодирование | программирование 16 28.12.2014 02:09
Inpa ncs expert x5 e70 Artem777157 Диагностика BMW | кодирование | программирование 10 13.11.2013 23:36
Часовой пояс GMT +3, время: 16:18.
