| | #1 |
| Участник тусовки Регистрация: 19.01.2010
Сказал спасибо: 158
Поблагодарили 12 раз(а) в 7 сообщениях
Вот чего сегодня мне дали,может кому пригодится **** FSW-PSW :action caused by aktiv/nicht aktiv selection **** ABKLAPPSTELLUNG : wiper arm parked position changes from horizontal to verticle when active ABSCHALT_KL50 : turn off starter switch when active ABSCHALTKRITERIUM : enable safety pinch switch for power windows when active ABSCHALTMELDUNG : shutdown signal? ABSCHALTUNG_VERBRAUCHER : switch off user? ABSTAND_KALTPULSE : ABSTELLPOS_CUSTOM : shut down? ABSTELLPOS_SMC : ACC_FLAG : active cruise control indicator ADRESSE_AUSWERTEN : analyse, evaluate AIRBAG_BEIFAHRER_1 : passenger airbag AIRBAG_FAHRER_1 : driver airbag AIRBAG_TRIGGERED_E-CALL : deployed airbag sends cellular emergency call when active AKUSTIK_ABBLENDLICHT :low beam alarm AKUSTIK_BREMSLICHT : brake light alarm AKUSTIK_DSC_ASC : dsc engaged alarm AKUSTIK_HECKKLAPPE : trunk open alarm AKUSTIK_KONZEPT : alarm concept AKUSTIK_PARKBREMSE : parking brake engaged alarm AKUSTIK_RDKS : low tire pressure alarm AKUSTIK_RUECKLICHT : tail light alarm AKUSTIK_TUEREN : door open alarm AKUSTIK_WASCHWASSER : low washer fluid level alarm AL_ALS_DRL : low beam as daytime driving light ALARM_AKUSTISCH_LANG : long alarm sound ALARMSCHALTER_SI_FZG : alarm switch ? ALARMSCHALTER_TAXI : ALARM_OPT_ABBLENDLICHT : alarm flashes low beam when tripped ALARM_OPT_WARNBLINKER : " " emergency flashers when tripped ALARM_OPT_FERNLICHT : " " high beam when tripped ALC : adaptive headlights ALC_AUSWERT_GRADIENT : ALC_AUSWERT_PROP_ABWEICH : ALC_FAILSAFE_FCT_EIN : ALC_FAILSAFE_NSW_AUS_OPT1 : ALC_FAILSAFE_NSW_AUS_OPT2 : ALC_FAILSAFE_NSW_EIN : ALC_FAILSAVE_NSW_LOCK : ALC_FAILSAVE_NSW_NEU : ALC_GRADIENT_SCHLECHTWEG : ALC_KLS_ENABLE : ALC_KLS_DISABLE : ALC_LED_DEF : ALC_LWR_VORZEICHEN : ALC_SAETT_TIMER_SCHLECHTW : ALC_SCHWENK_LATCH : ALC_VERBAUT : ANKUNFTSZEIT_VON_NAVI : time of arrival using navigation ANHAENGERKUPPLUNG : when trailer attached to wire harness reverse pdc turned off ANLAUFSTROMBEGRENZ_MEMO : ANPRESSDRUCKVERSTELLUNG : downforce adjustment? ANTI_DROEHN_STELLUNG : ANZEIGE_EML : display electronic motor load ANZEIGE_ANKUNFTSZEIT : display e.t.a. ANZEIGE_UHR_IM_DISPLAY : ASC : automatic stability control ASC3_AUSWERTUNG : analysis? ASC_PREDRIVE_UEBER_SG : ASL : ASL_DSC_5_7 : ATEMP_WARNUNG_KALTLAND : AUFHEIZAUTOMATIK : automatic heater control? AUSSENGEFUEHRTE_SHDUSSENTEMP_ABH_GEBL_ANH_1 AUSSENTEMPERATUR_KORR : AUSSENTEMP_WARN_AKUSTIK : AUSSENTEMP_WARNUNG_GONG : External Low Temp Warning Gong AUSSTATTUNG_RPA : AUSSTELLFENSTER :vent window? AUSTAUSCHPUNKT :replaceable part? AUSWERT_GRADIENT : AUSWERT_PROP_ABWEICHUNG : AUT_SPIEGELVERSTELLUNG : automatic mirror adjustment linked to specific key AUT_SITZVERSTELLUNG :choose between automatic seat adjustment [nach_fb_entriegeln] when remote signals door open or[nach_entr_u_tuer_oeffnen] when door opened AUTO_LED_GEBL_MANUELL : AUTO_LED/SCHRIFTZUG : AUTO_LWR_ENABLE :automatic headlight leveling system AUTOMATISCHER_NOTRUF : automatic emergency call AUTOM_FAHRL_STEUERG :automatic head light control unit [ALS on/off] AUTO_ZV_DISABLE : disable automatic central locking BACKUP_ANTENNA : BACKUP_BATTERY : BACKUP_BATTERY_ENABLED : BAUREIHE_A : series BC_ANFORD_WEGFAHRSICH :immobiliser demand with alarm? BC_CODE_AKTIV :enables board computer BC_KL_R : In R position, the BC shows the last function chosen. BC_V_KORREKTUR : BEDIENSTELLE_BFT :control section passenger side door BEIFAHRERBAG_STUFE2_1 :passenger BEIKLAPPEN_B_KOMFORTSCHL : when active 2 open signals on remote opens door & drivers window BELUEFTUNGSKLAPPE_OEFF_1 : Ventilation Flap opening BEWERTUNG_FEHLER :defect evaluation? BETRMODI_DEAKT_KL15_EIN : BETR_STD_AUTO_LOESCH :B_SATELLIT_1 BETR_STD_NICHT_LOESCHEN : BFD_ABS_STUFE3 : BFD_ASC_REG : BFD_AX_REF : BFD_ON :brake force display on BFD_OPTION : BFD_SCHWELLE : BFD_ST3_ON : BFD_SW1_STUFE : BFD3_ASC_AKTIV : BF_UEBERWACHUNG :passenger control BI_XENON : BIXENON_EIN_BEI_LICHTHUPE : BL_ALS_SL_DIMMEN : brake light as parking lights dimmed? BL_DIMMEN : brake light variable? BL_DIMMUNGS_OPT_1 : BLEND_CHECK_IST_WINKEL : BLEND_CHECK_SOLL_WINKEL : BL_GEDIMMT_ALS_ERSATZ :brake light & BL_GED_ALS_ERSATZ_MIT_AH :brake light & BLK_DIMMUNGS_OPT_1 :turn signal BLK_H_L_PICT :left rear turn signal in dashboard BLK-H-R-PICT :right " " " " " BLK_V_GED_ALS_PARKLICHT : front turn lights & together as parklight BLK_V_GED_ALS_SIDEMARK : front turn light & together as sidemarker? BLK_V_GEDIMMT_ALS_ERSATZ :front turn light & together as BLK_V_L_PICT :left front turn signal in dashboard BLK_V_R_PICT :right " " " " " BLS_PRUEFEN :brake light switch BLST1_BLST3 : BL_UND_BLK_H_GEM_BLK : brake light & blinking rear turn light together when braking BL_UND_BLK_H_GEMEINSAM : brake & rear turn light together BL_UND_BLK_H_GEM_WBL :brake & rear turn light together as hazards BPLUS_TRENNUNG1_1 : safety battery terminal BRAKE_FORCE : BREMSFLUESSIGK_INV : brake fluid ? BREMSLICHTSCHALTER : brake light switch BREMSWARNLEUCHTE : brake warning light B_SATELLIT_1 : CAN_11H : CAN_AUSFALL_BEWERTUNG : CAN_EBV : CAN_INSTR2_SENDEN : CAN_OELDRUCK : oil pressure on can bus CAN_S_GSU : light sensor on can bus CC_ABBLENDLICHT : low beam CC_BREMSLICHT_MITTE : stop light CC_BLINKER_VORN : front turn signal CC_FERNLICHT : high beam CC_HECKKLAPPE : tail gate CC_KENNZEICHENLEUCHTE_LI : number plate light CC_LAMPEN : CC_MELDUNG_AL_L : message low beam CC_NSL_LINKS : rear left fog light CC_RUECKLICHT : CC_TUEREN : CC_WASCHWASSER : CC_ZUSATZBLINKER : CENT_LOCK_MGL_VO_TUER_AUF : COD_IFL : COD_IFL_AN_PIN48 : COD_IFL_ASYNC : CHECK_IGNITIONA : CHECK_IGNITIONC : CHECK_IGNITIONK : CHECK_SMC_ERROR : CLT_AKTIV_IM_CRASH_MODE : CORNERING_BREAK_CONTROL : CRASH_DISABLE_BEWERTUNG_10S : CRASH_DISABLE_HECKKL_10S : CRASH_KLEMME_58G_EIN : CRASH_WARNBLINKEN : turn on hazard lights when car crashed CUSTOMER_CALLS_OVER_GMIN CHECK_FGN_SMC_ALC_OFF : DATENSATZ_1 DAUERFAHRLICHT_EU : enables light control sensor for auto. headlights DBC_DBS : dynamic brake control-dynamic brake support DBC_MSB : DEB_TIME_CS_0 : DEBUG_SIGNAL : DEF_PIN_20_DEFEKTBLINKEN : DEF_PIN_20_VOR : DEF_PIN_37_DEFEKTBLINKEN : DEF_PIN_37_VOR : DELTA_LIMIT_GESETZ : DIAGNOSE_DELAY_ZEIT : DIAGNOSE_SCHRITTMOTOR : step motor DIAGNOSE_ZWP : DIFFERENZ_ANLAUF_BLOCK : DISPLAYANZEIGE_HIGH : DISPLAYANZEIGE_LOW : DISPLAY_GEBLAESRAHMEN : DOPPELKLICK_AUF : DOPPELKLICK_HEBEN : DOPPELKLICK_ZU : DRL_BLK_VORN_GEDIMMT : DROSSEL : restrictor DSC_DEF_GONG : warning gong when dsc activated DTC_LAMPE : DWAH_PIN_C17 : alarm system horn DWA_BLK_ABSCHALTEN : power to windows shutdown with alarm DWA :activates alarm when remote used to open or close car doors DWA-QUITTIERUNG : anti theft system acknowledgement DWA_NOTENTSCHAERFEN :alarm will not de-activate DYNAM_LWR_ENABLE : DYN_BREMS_UNTERSTUETZUNG : E52_LINKS_LENKER : E52_RECHTS_LENKER : E53_FAHRZEUG : E9X_HIMMEL : EBV_LAMPE : electronic brake force light E-CALL_HARDKEY_FITTED : emergency call EC_LUEFTER : EEPROM_SHD : EHC : electronic height control EINGANG_2 : entry EINGANG_2_KONTAKT_GESCHL : EINKLEMMSCH_HINTEN : rear window pinch sensor EINKLEMMSCH_VORNE : front window pinch sensor EINSCHALTMELDUNG_BEI_1MA :start? EINSCHALTMELDUNG_IMMER :power up message always EINSCHALTVERZOEGERUNG : start delay EINSPRITZANLAGE_CAN : fuel injection information to can bus EINSTIEGSHILFE : steering wheel movement with key in 1st position EINSTIEGSHILFE_HOEHE : steering wheel up & down [height] EINSTIEGSHILFE_LAENGE : steering wheel in & out [length] EIS_AUSBLENDEN : E_LUEFTER : ENABLE_EURO_NCAP : ENABLE_US_SBR : ENTSICHERN_CENTERLOCK :central locking button works when doors locked & key not in ignition when active ENTFALL_ZV_BEDIENST_HECK : ENTR_HKL_MGL_WENN_VER : ENTR_HS_MGL_WENN_VER : ENTR_KL.R_30S_NACH_SICH : ERKENNUNG_BREMSLICHT : recognise brake light? ERKENNUNG_SITZBELEGUNG_1 : Recognition seat allocation (don't switch this off otherwise the airbag system gets up-set) ERR_LWR_L_IGNORIEREN : ERR_LWR_R_IGNORIEREN : ERR_SCHWENK_L_IGNORIEREN : ERR_SCHWENK_R_IGNORIEREN : EWS_3_SCHNITTSTELLE : electronic immobiliser interface FAHRERBAG_STUFE2_1 : driver FEHLER_ABTAKTEN : fault scanned? FEHLER_HECKSCHEIBE :rear window fault? FERNBEDIENUNG : remote control FERNWIRKEN_GENERELL : telecontrol FERNWIRKEN_NAVZIELE : FERNWIRKEN_POSITION : FERNWIRKEN_STANDHEIZUNG : FERNWIRKEN_TELEFONLISTEN : FENSTERHEBER_HINTEN : rear window FENSTERHEBER_VORNE : front window FH_ABSENKUNG_SPERREN : window lowering when obstucted FH_ABSENKEN_VERDECK_VERDECK_OEFF :" " " convertible top FH_AUF_STUFE2_KLR_AUS : FH_BEIFAHRERTUER_TIPP_AUF : Passenger Window power down one touch FH_BEIFAHRERTUER_TIPP_ZU : Passenger Window power up one touch FH_FAHRERTUER_TIPP_AUF : Driver Window power down one touch FH_FAHRERTUER_TIPP_ZU : Driver Window power up one touch FH_INIT_TRANSPORTMODE : FH_NACH_TUERE_AUF : FH_TIPP_DISABLE_TUER_AUF : FH_TUEREN_HINTEN_TIPP_AUF :rear window power down one touch FH_TUEREN_HINTEN_TIPP_ZU : rear window power up one touch FH_ZTR_SCHALTER_TIPP_AUF : window switch down one touch FH_ZTR_SCHALTER_TIPP_ZU : " " up " " FILTER_DETEKTION_WEIT : FL_AL_AUS : high beam as low beam FLC_DIMMER_OPTION : FLC_LED_EIN ; FL_KL_50 : high beam when starting FL_UND_NSW_NICHT_GLEICHZ : high beam & fog lights not used together when active FONDGEBLAESE : air conditioning to rear seats FOND_MODUL_1 : rear module FS_UNLOCK_300MS_P_BUS : crash sensor unlock Fußraumklappen: floor flaps (IHKA) FUNK_INNENRAUMSCHUTZ :radio interior space monitoring FUNKINNENRAUMSCHUTZ_HI : FUNKTION_DSC : FUNKTION_DTC : FUNKTION_RPA : FUNKTIONTUERSCHLOSS :function Door Lock FUNKUHR : FUSSRAUMKLAPPE SCHLIES : floor air Flaps close GEBL_OFF_MODE : GEBLAESE_BALKEN : blower bar automatic mode GEBL AUT B ZUEND EIN : blower automatic at ignition on GEBLAESEKORREKTUR : blower speed correction GEBLAESEBALKEN_AUT_MOD_1 : GED_FL_ALS_DRL : dimmed high beam as daytime running light GESCHW_PRUEFUNG : speed GLASDACH : glass sliding sunroof GRADIENT_SCHLECHTWEG : GURTSCHLOSS_FAHRER_1 :driver seat belt buckle? GURTSCHLOSS_SPANNUNGSS_1 : GURTSCHLOSS_STROMSS_1 : GURTSTRAFFER_BEIFAHRER_1 :passenger seat belt tensioner GURTSTRAFFER_FAHRER_1 :driver seat belt tensioner GURTWARNUNG_EURO_NCAP :seat belt warning GURTWARNUNG_GONG :seat belt warning gong GURTWARNUNG_TEXT :seat belt warning optical GPS_UHR :get time from gps for radio clock to function you need the LW-receiver in Germany and UK, HALLSENSOR_VSW72 : HALLSENSOR_VSW8 : HBA_DSC_5_7 : HEBEN_AUS_GEOEFFNET : HECKKLAPPE_ENTSICHERN : open trunk lid with remote control HECKSCHEIBE_ENTRI_INNEN :heated rear window? HEIMLEUCHTEN : home lights activated by flashing high beam with key off HEIMLEUCHTEN_ABBRUCH : home light stop HEIMLEUCHTEN_AL :home lights are low beam HEIMLEUCHTEN_BL : " " " turn signals HEIMLEUCHTEN_FL : " " " high beam HEIMLEUCHTEN_FUNKSCHL :lights on on closing car with remote HEIMLEUCHTEN_KL58G : home lights are interior backlighting, cluster, ashtray etc. HEIMLEUCHTEN_KZL : " " " license plate HEIMLEUCHTEN_NSL : " " " rear foglight HEIMLEUCHTEN_NSW : " " " front foglight HEIMLEUCHTEN_RFS : " " " reverse light HEIMLEUCHTEN_SL_H :" " " rear parking lights HEIMLEUCHTEN_SL_V :" " " forward parking lights HEULTON : HHS_AUTOMATIK : enable automatic rear window defogger HILLDESC_DSC_5_7 : HILLDESC_DXC_8 : HIMMEL_AUTO_AUF : HIMMEL_AUTO_ZU : HKL_SPERREN_BEI_ZS :tailgate lift barriers with ZS HUB_VERZOEGERUNG_FH_VORN : HWL_1 : HYDRAUL_HECKKLAPPE : hydraulic trunk opener HYD_HECKKLAPPE_OHNE_PDC : IB_EIN_16MIN_WENN_STANDLI :interior lighting control signal IB_EIN_BEI_HKK/HSK : IB_BEI_KL.R_AUS :interior light turns on when ignition turned off after driving with headlights IB_CRASH_ON_0_KMH : IB_EIN_HK_AUF : IB_EIN_SCHLOSS_ENTRIEGELN :interior lights on when unlocked by key IB_POWER_CONF_0 : IB_SPERRE_BEI_FEHLER : IK_BUS_TEILNEMER : IR_FERNBEDIENUNG :infrared remote control IR_FERNBEDIENUNG_BF : ITS_FRONTCRASH_1 :inflatable tubular support ITS_LINKS_1 : ITS_RECHTS_1 : INNENLICHT_AN_MEHRFACH_ZV : pressing remote lock button twice turns on Interior Lights INTERVALLZEIT_GESCHWABH : KALTUEBERWACHUNG_AL : cold testing bulbs in low beam KALTUEBERWACHUNG_BLK_HI :" " " " turn signal rear KALTUEBERWACHUNG_BLK_VO :" " " " turn signal KALTUEBERWACHUNG_BL_MI : " " " " brake light KALTUEBERWACHUNG_FL : " " " " high beam KALTUEBERWACHUNG_KZL : " " " " number plate KALTUEBERWACHUNG_KZL_LI :" " " " KALTUEBERWACHUNG_NSW : " " " " foglights KALTUEBERWACHUNG_RL : " " " " reversing light K_BUS_FB_SPERREN : KBUS_FUNKTION : K_BUS_FREI_OHNE : K_BUS_FS_UNLOCK_300MS : KEINE_L_R_SYNCHRONISATION : KEINE_PARKLICHT_FUNKT : KENNLINIENFELD2_AKTIV : KENNLINIE_WAERMETAUSCHER : KENNFELDKUEHLUNG : KEY_MEMORY : KEY_MEMORY_IHK : temperature set point stored from last time car used KEY_MEMORY_RADIO : stereo/cd/ipod-channel & volume stored from last time car used KISI_N_DEAKT_IM_CRASH : KL50_ABSCHALT_AL : when key in start position stop low beams KL50_ABSCHALT_FL : " " " " " " high beams KL50_ABSCHALT_NSW : " " " " " " fog lights KL_50_CAN : key in start position signal on can bus KL_50_FUNK_AKT : pressing remote lock twice turns on interior lights KLEMME_15_LIEGT_AM_SG_AN : when ignition switch tuned on KLEMME_15_NOTWENDIG : KLEMMENSTATUS : KLEMME_50_UEBER_CAN : KLIMABETR BEI ZUEND EIN : airconditioning on when ignition tuned on KLIMATASTE_SPERREN : KLAPPEN OEFFNEN : Flaps Opening KLASSIF_DRIFT_ENA : KLASSIF_LENKM_ENA : KLASSIF_UEBERST_ENA : KLS_BEI_AL_AKTIV : KOPFBAG_FOND_LINKS_1 : KOPFBAG_FOND_RECHTS_1 : KOMFOEFFNEN_SPERRE_KEY_IN :open convertible soft-top by holding key in unlock position in drivers door lock KOMFORTFUNK_BEREICH_HEB : KOMFORTOEFFNEN_FB_O_FH_HI :remote opens rear window KOMFORTOEFFNEN_FB_O_SHD : holding open button on remote opens windows without sun roof KOMFORTOEFFNUNG : remote Opens doorlocks KOMFORTOEFFNUNG_FB : convertible top opens by holding the open button on remote..Or opens all windows & sun roof on non convertible KOMFORTOEFFNUNG_BEREICH : KOMFORTSCHLIESSEN_VERDECK : KOMFORT_POS_AUF : KOMFORT_POS_ZU : KOMFORTSCHLIE_FB_O_FH_HI : remote closes rear window KOMFORTSCHLIE_FB_OHNE_SHD : holding close button on remote closes windows without sun roof KOMFORTSCHLIESSUNG : remote locks doorlocks KOMFORTSCHLIESSUNG_FB : convertible top closes by holding the close button on remote..Or closes all windows &sun roof on non convertible KOMPRESSOR_GEREGELT : KOMPRESSOR_TRANSPORT_SICH : KUEHLMITTELUEBERTEMP_CAN : LAMPENCHECK_GESICHERT : LATENTWAERMESPEICHER :Latent-heat storer LAUTSTAERKE_HINTEN : Volume in the Back LDA_BEI_UNTERSPANNUNG : increase idle rpm LDA_BEI_VERBRAUCHER : LED_RUECKLICHT_OPTION : LENKSAEULENMEMORY : steering column position memory LENKSTOCKSCHALTER_ANALOG : LEUCHTDICHTE_EXPO : LEUCHTWEITENREG_AUTOM : LEUCHTWEITENREG_DYNAM : LEUCHTWEITENREGELUNG : front light aiming control LICHTBEDIENEINHEIT : LICHTWARNUNG : warning light LINKSVERKEHR : LOAD_DUMP : LOGIK_HA_SPERRE : LOGIK_SWBUNT : LUFTFEDERUNG : LWR_AUT_EXTERN :automatic verticle headlight aim control LWR_TREIBER_BEW : LWR_TREIBER_ERR : LWR_VORZEICHEN : MANUELLE_LWR : MAX_BREMS_UNTERSTUETZUNG : MAUT_N_ABBRECH_N_TUER_AUF : MAUT_ZU_STOP_N_TUER_AUF : MEMORY_SP_ABKLAPPEN_GM : MEMORY_SPIEGELABKLAPPEN : folding mirror position memory MEMORY_TIPP_BETRIEB : MELDUNG_TASTER : signal sensor MELDUNG_KATALYSATOR : signal catyltic convertor MIN_WT_SOLLWERT : MIT_LIN_SCHALTER : MIT_SRA_EIN_LENKSTOCK : MIT_WISCHER_SERVICEPOS : wiper in service position -verticle MOTORDIAGNOSE : MOTOR_NOTPROGRAMM_CAN : MOTOR_OELSTAND_PREDRIVE : M_TELEGRAM : NACHREG_DYN_SLOW : NEIGUGSGEBER : tilt sensor for alarm NLR_AKTIV : NON-TELEMATIC_E-CALL : NOTENTRIEGELN_HKL : NOTFUNKTION : NOTLAUF_IMMER : NOTSTROMSIRENE : Emergency Power Siren NUR_EIN_TONGEBER : NUR_KL15_BETRIEB : pdc operation on when key in run position when active NSL_AH_US_OPTION : rear fog light NSL_R_NICHT_ANSTEUERN : rear fog light NSW_KEIN_TASTER : front fog light NSW_KL_50 : front fog light when starting N_VER_B_ERN_GESCHW_SCHWEL : OFFENE_FENSTER : OEFFNEN_AUS_GEHOBEN : OEH_POWER_CONF_0 : OELST_SENS_DEF_WARNUNG : OELSTAND_MOTOR_CAN : OHNE_CENTERLOCK_0 : OHNE_FERNBEDIENUNG_1 OHNE_FERTIGUNGSMODE : OHNE_FH_BF_HINTEN_0 : OHNE_FH_BF_VORNE_0 : OHNE_FH_FA_HINTEN_0 : OHNE_GIERRATE : OHNE_IB_0 : OHNE_INTERVALLBETRIEB : OHNE_POWERDOWNMODE : OHNE_SERVICEMODE : OHNE_SRA_0 : OHNE_TRANSPORTMODE : OHNE_VA_ZEITEN_0 : OHNE_WISCH_BEI_WASCH OPT_ENTRY_HELP : OPTIMIERTE_SCHLIESSFKT PANIC_CLOSE : PANIC_FREIGABE_CAS : PANIC_FREIGABE_KL15 : PANIK_MODUS : PARK/NEUTRAL_EINGANG : PASSIVES_DWA_HORN : PDC_EIN_BEI_KL15 : PDC_SCHALTER : park distance control switch PHASE_AUS_GEDIM_LICHT_AUS : PHYSIOLOGIEANPASSUNG_1 : PIKTOGRAMM_ERWEITERT : signalling e.g. the status of lights (bulbs) PIN_5_10_AHM_ERS_FU_GESP : PIN5_10_BFD : PIN_20_ALS_FRA_LI_VO_2 PIN_29_30_AHM_ERS_FU_GESP : PIN29_30_BL_NSL : PIN_37_ALS_FRA_RE_VO_2 : PM_SCHALTERBLOCK_FOND : PM_SCHIEBEHEBEDACH : PM_SITZMEMORY : driver seat memory PM_SITZMEMORY_BEIFAHRER : passenger seat memory PORTABLE_BT : POTI_DIMMER_INVERS : POTI_LWR_INVERS : PREFIT_SIM_ENABLED : PREDRIVE_RPA : PRE_MSR : PRE_VLABS : PULS_TIME_OPTION QUIT_AKUST_DAUER_10_MS : QUIT_AKUST_ENTSCH : alarm beep on unlock (two beeps) QUIT_AKUST_SCHAERF : alarm beep on lock (one beep) QUIT_AKUST_SCHAERF_KLAPPE : QUIT_OPT_ENTSCH : optical Acknowledge remote un-locking (two flashes) QUIT_OPT_SCHAERF : optical Acknowledge remote locking (one flash) QUIT_OPT_SCHAERF_KLAPPE : RCC_UHR : RCC_WECKZEIT : waking time? RDC_ALARM_VIA_HFK : tire pressure control alarm RDC_ALARM_VIA_KBUS : RDKS : tire pressure monitor system RECHTSVERKEHR : REFERENZLAUF_LWR_KL15 : REGENSCHLIESSEN :rain REGENSCHLIESSENTILT : REIFENDRUCKWARNSYSTEM : tire pressure warning REIFENTOL_ABGLEICH_ASC : REIFENTOLERANZABGLEICH : RFS_AH_OPTION : reversing light RL_INNEN_BLINKT : tail light RR_SCHALTER : RUECKFAHRGONG : reverse alarm sound RUECKLICHT_INNEN_FEHLT : SAETT_TIMER_SCHLECHTWEG : SB_ANHEBEN : SBE1_STATUS_VERZ_1 : SBR_US : seat belt reminder SCA_HECKKLAPPE : soft close tail gate SCHAERFEN/ENTSCHAERFEN : choose between [schloss_und_fernbedienung]key&remote &[nur_mit_fernbedienung]key only SCHALTER2_BL : switch #2 brake light SCHALTER_R_GANG : SCHEIBENABSENK_OHNE_EKS : SCHEIBENINTENSIVREINIGUNG : SCHIEBEHEBEDACH_TIPP_AUF : One touch sun-roof open SCHIEBEHEBEDACH_TIPP_HEB : " " " " raise SCHIEBEHEBEDACH_TIPP_SENK : " " " " lower SCHIEBEHEBEDACH_TIPP_ZU : " " " " close SCHEINWERFERREINIGUNG : wash headlights every 5th time the windscreen gets washed when active SCHRITTMOTOR_UEBERLAUF : step motor overflow? SECOND_HARDKEY : SEL_ZV_SENDER_1 : SENSOR_REGEN : SEQ_M_GETRIEBE : SERVOTRONIK : SHD_ACTU_ALLOWED : sunroof module SHD_CFL_ALLOWED : SHD_CLOUD_ALLOWED : SHD_RESTARTALLOWED : SHD_RRD_ALLOWED : SHD_SKB_OHNE_KL_OE : SHD_SKB_OHNE_KL_SCH : SHD_TMON_ALLOWED : SIA_RESET_KI_TASTE : Coding maintenance interval SICHERHEITSFAHRZEUG : security vehicle SICHERHEITS_FZG : SIDEBAG_FOND_LINKS_1 : SIDEBAG_FOND_RECHTS_1 : SIM_IN_TELEMATIK_READER : SITZMEMORY_VERBAUT : seat memory obstructed SL_INNEN_ALS_TWL : parking light SL_VORNE_ALS_ZUSATZ_BLK : front parking light as aditional turn light SMG_S_ANZEIGE : SOFT ON/OFF : gradual fade out of the interior lights SOLLWERT_KORREKTUR_1 : SONDERFHZG_MIT_WSA : SOS_ACTU_ALLOWED : SOS_CFL_ALLOWED : SOS_CLOUD_ALLOWED : SOS_RESTARTALLOWED : SOS_RRD_ALLOWED : SOS_SKB_OHNE_KL_OE : SOS_SKB_OHNE_KL_SCH : SOS_TMON_ALLOWED : SP_BEWERT_OD_ALC_NSW_AUS : SPERRDIFFERENZREGELUNG : SPERR_VENT_TEST : SPERR_WLM_TEST : SPERRZEIT_KL_R_AUS_0.2_S : SPIEGELEINKLAPPEN : SPIEGELABKLAPPEN : folding mirrors SPIEGELHEIZUNG : heated mirror SPIEGELHEIZUNG_VERBAUT : heated mirror obstructed SPIEGELMEMORY : mirror position memory SP_MOTOR_BEWERTEN : SP_MOTOR_F_EINTRAG : SP_MOTOR_STOP : SPG_NACHREGELUNG : SPG_NACHREGELUNG_LANGSAM : SPG_NACHREGELUNG_ZUSATZ : SPRACHE : Language selection SPZ_PROG : SRA_L322_RELAY : SRA_MIT_WASCH_WISCH_SW STANDHEIZUNG : stationary heating[webasto deisel] STANDHEIZUNG_KONZEPT STANDLICHT_VORNE : STANDLUEFTUNG : park heating STANDRUECKSCHALTUNG : Condition Resetting at standing STATUS_LESEN : ST3_SCHWEL TAGFAHRLICHT_ECE : Daylight Headlights TAGFAHRLICHT_DAN : TAKTUNG_HHS : TAKTEN HIGH LOW ANZEIGE : Clocks High Low Announcement TAKTUNG_IB : TAKTUNG_VERBRAUCHERABSCHA : TASTE_UEBER_CAN : TASTER_NSL : rear foglight sensor TASTER_NSW : front " " TASTER_NSW_NSL : front & rear foglights sensor TELEMATIK : TELEGRAMM_ZEIT_ZYKLUS : TEMPCFLUSEOUTER : TEMPCFLUSESENSOR : TEMPERATUR_EINHEIT : Temperature Unit (C/F) TEMP_FOND : TEMPTMONUSEOUTER : TEMPTMONUSESENSOR : TESTBETRIEB : TEST_OD_ST2_OHNE_NSW TNK_DECKEL_WARNUNG : TP_FUNKTION : TRAKTIONDIFFERENZREGELUNG : TREIBER_BEWERTEN : TREIBER_F_EINTRAG : TREIBER_STOP_OD_ALC_RE_OK : TRIGGERSCHALTER_1 : UEBERLAUFSCHRITTE_BEI_0 : UEBERLAUFSTEPS_BEI_100% : UEBER_ROLLSENSOR_1 : UEBERSPANNUNGSSCHUTZ : UEBERSPG_ABSCHALT_58G ; UEBERSPG_ABSCHALT_BL : UEBERSPG_ABSCHALT_NSL : UEBERSPG_ABSCHALT_RFS : UEBERSPG_ABSCHALT_SL : UEBERSPG_ABSCHALT_SL_H : UEBERSPG_ABSCHALT_SL_HI : UEBERWACH_FENSTER_BF_HI : UEBERWACH_FENSTER_F_VO : UEBERWACH_HECKSCHEIBE : ULF_EIN_AUS :hands free & charger UMLUFT MEMORY : Circulating Air Flap Memory (remembers if re-circ is on after shutdown) UNTERSTEUERUNGSALGORYTHM : US_CALL_SERVICE_CENTER : USE_SOS : VA1_SPERRE_BEI_FEHLER : VA_2 : V_ABHAENGIG : VERBRAUCH D1 : Consumption units VERDECKKLAPPE_VORHANDEN : VERL_ALARMZEI_WAEHR_ALARM : VERRIEGELN_AUT_AB_X_KMH : automatic central locking after X KMH VERRIEGELN_AUT_NACH_2_MIN : automatic central locking is re -locked after 2 MIN if you dont open a door VERRIEGELN_SITZLEHNE_FA_1 :locking seat back? VERRIEGELUNGSSCHWELLE : locking Device-swells (threshold) (speed of X above) VERZUG_ENTR_HECKKLAPPE : VOLUMENDURCHFLUSSPARA_2 : VORGLUEHEN/KAT_HEIZEN_CAN : pre heat? VKBODEN_ERKENNUNG : WARMUEBERWACHUNG_AL : warm testing bulbs in low beams WARMUEBERWACHUNG_AL_L : " " " " low beams WARMUEBERWACHUNG_BL_MI : " " " " brakes WARMUEBERWACHUNG_BLK_HI : " " " " rear turn signals WARMUEBERWACHUNG_BLK_VO : " " " " front " " WARMUEBERWACHUNG_FL : " " " " high beams WARMUEBERWACHUNG_KZL_LI : " " " " number plate light bulb WARMUEBERWACH_low beams_BLK : WARNUNG_GESCHW_LIMIT : WARNUNG_MOTOR_OELSTAND : WARTEN_SCHEIBEN_ABGESENK : WAKEUP_GENERELL ; WASSERPUMPE :water pump? WASSERSTOFF_FZG : WEG_EINHEIT : Distance unit (distance, miles or km) WEGFAHRSICHERUNG_AUTOM :immobilise ? WEGSIGNAL_SERVO_ABS : WE_MODE : WISCHER_RUECK_GESCHW : WISCHERINTERVALL: wiper interval WISCHERPOTI : wiper timing WISCHER_VOLLEND_KLR_AUS ; WINDSCHOTT : WINDSCHOTT_OPT : XDT : XENONLICHT_ZUEND_OPTION : ZEIT_EINHEIT : Time unit (12H or 24H) ZEIT_BIS_AUTOM_SPERREN ; ZKE : central body electronics ZUHEIZUNG : heating for diesel engine ZUENDSCHL_GONG_R_EIN : ZUENDSCHLUESSEL_KBUS : ZUENDSCHLUESSEL_WARNUNG : beep & display when door opened to warn key left in Ignition ZUSATZWASSERPUMPE : ZV_AGGREGATE_TYP : central locking system ZV_BEDIENST_BT_DISABLE : ZV_ENTR_SCHL_BEI_DWA_AKT : ZV_SELEKTIV : unlock drivers door only if [aktive] or all doors if [nicht aktive] key selective ZV_VR_BEDIENSTELLE_HECK : |
| | #2 | |
![]() 2% полезной информации - не слишком ли много нам будет?
__________________ Не хочешь думать - не спрашивай меня ни о чём ![]() АЗБУКУ КАЖДЫЙ УЧИТ САМОСТОЯТЕЛЬНО | |
| Опции темы | |
| Опции просмотра | |
| INPA (NCS Expert) - кодирование - часть 2 | Tyler | Диагностика BMW | кодирование | программирование | 6000 | 10.05.2025 20:21 |
| BMW Inpa/Ediabas | Tyler | Диагностика BMW | кодирование | программирование | 3216 | 02.03.2025 12:43 |
| Просветите чайника по INPA | ///Man | Диагностика BMW | кодирование | программирование | 16 | 28.12.2014 02:09 |
| Inpa ncs expert x5 e70 | Artem777157 | Диагностика BMW | кодирование | программирование | 10 | 13.11.2013 23:36 |
