INPA (NCS Expert) - кодирование - часть 2
Like Tree55Likes
Старый 19.02.2015, 00:18 #4691
Авто: E90
Update: поковырялся еще, обнаружил что такая же ошибка вылазит в INPA и NCS если вообще не подключать интерфейс.
Последний раз редактировалось AirArt; 19.02.2015 в 00:51.
AirArt вне форума   Ответить с цитированием
Старый 19.02.2015, 09:45 #4692
Аватар для Busyman
Сказал спасибо: 33
Копать в сторону режимов работы шнурка
Старый 19.02.2015, 12:08 #4693
Сказал спасибо: 15
Поблагодарили 13 раз(а) в 13 сообщениях
Сообщение от AirArt Посмотреть сообщение
IFH-0003: Data transmission HOST/Interface failed
Reason 1: In the Ediabas.ini file, the interface is set to STD:OBD. However, you have
connected an ADS connector.
Solution 1: Modify the interface setting.
Reason 2: The data transmission failed when sending (e.g. short circuit in the line).
Solution 2: Get rid of the short circuit, for example.
Reason 3: Connector not connected or no power supplied.
Solution 3: Check whether the connector is connected and is supplied with power.
Reason 4: The device manager has been used to disable the FIFO buffer for COM1.
Solution 4: In the device manager (Windows XP: Enter “Start” à “Control Panel” à
“System” à “Hardware” à “Device Manager” à Ports (COM & LPT)), and then
select COM1 from the ports. Then under the “Port Settings” tab, select
“Advanced”. There must be a check-mark by “Use FIFO buffers” and “8” must be
selected for the receive buffer and transmit puffer.
IFH-0009: ECU isn’t connected or doesn’t respond
Reason 1: In the Ediabas.ini file, the interface is set to STD:ADS. However, you have
connected an OBD connector.
Reason 2: The ignition is switched off.
Solution 2: Switch the ignition on.
Reason 3: The device manager has been used to disable the FIFO buffer for COM1.
Solution 3: In the device manager (Windows XP: Enter “Start” à “Control Panel” à
“System” à “Hardware” à “Device Manager” à Ports (COM & LPT)), and select
COM1 from the ports and under the “Port Settings” tab, select “Advanced”. There
must be a check-mark by “Use FIFO buffers” and the highest possible setting
must be selected for the receive buffer.
вадуха вне форума   Ответить с цитированием
Старый 19.02.2015, 18:38 #4694
Авто: E90
Спасибо, конечно, за расшифровку ошибок, только я их и сам нашел.
Пытался сменить режим шнурка на DCAN с помощью dcan_tools, и через виндовое приложение, и через ДОСовское. Ругается на echo timeout. Может шнурок капут?
Старый 19.02.2015, 18:42 #4695
Сказал спасибо: 15
Все может быть
Старый 19.02.2015, 23:07 #4696
Аватар для Tourist69
Авто: Диагност
Устройство определяется в системе? как определяется? Попробуй дрова смени
Tourist69 вне форума   Ответить с цитированием
Старый 20.02.2015, 16:36 #4697
Авто: E90
Спасибо всем отозвавшимся, все вылечилось сменой шнурка на модель подороже.
Старый 20.02.2015, 23:41 #4698
Сказал спасибо: 119
шнурка
в ботинки вставьте его!
AAM вне форума   Ответить с цитированием
Старый 21.02.2015, 23:42 #4699
Лучше на нём повеситься всем "диагностам", не знающим слова "адаптер"
Старый 23.02.2015, 14:36 #4700
Сказал спасибо: 31
Авто: bmw x5 E70 2007 трактор
Кто может подсказать,кодил сегодня себе некоторые вещи,заметил,что NCS неверно определяет VIN,точнее последнюю его цифру,вместо 0 пишет 3,кодирнулось все нормально,это глюк какой то или что?
Boroddach вне форума   Ответить с цитированием
Сказал Спасибо Boroddach за это сообщение:
тугарин (24.02.2015)
Часовой пояс GMT +3, время: 10:53.
