| | #14 |
| Абориген Регистрация: 13.02.2009
Сказал спасибо: 13
ECU: ME7.2, Engine: M62-E38, from 01.09.98 till 28.02.99 PCode BMW-FC PCode text P0100 115 Mass or Volume Air Flow Circuit P0111 124 Intake Air Temperature Sensor 1 Circuit Range/Performance P0116 123 Engine Coolant Temperature Circuit Range/Performance P0120 117 Throttle/Pedal Position Sensor/Switch 'A' Circuit P0120 118 Throttle/Pedal Position Sensor/Switch 'A' Circuit P0120 119 Throttle/Pedal Position Sensor/Switch 'A' Circuit P0130 10 O2 Sensor Circuit (Bank 1 Sensor 1) P0133 15 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) P0135 13 O2 Sensor Heater Circuit (Bank 1 Sensor 1) P0136 12 O2 Sensor Circuit (Bank 1 Sensor 2) P0139 17 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2) P0141 14 O2 Sensor Heater Circuit (Bank 1 Sensor 2) P0150 18 O2 Sensor Circuit (Bank 2 Sensor 1) P0153 21 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1) P0155 5 O2 Sensor Heater Circuit (Bank 2 Sensor 1) P0156 20 O2 Sensor Circuit (Bank 2 Sensor 2) P0159 23 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2) P0161 4 O2 Sensor Heater Circuit (Bank 2 Sensor 2) P0170 24 Fuel Trim (Bank 1) P0170 26 Fuel Trim (Bank 1) P0173 25 Fuel Trim (Bank 2) P0173 27 Fuel Trim (Bank 2) P0201 150 Injector Circuit/Open - Cylinder 1 P0202 154 Injector Circuit/Open - Cylinder 2 P0203 153 Injector Circuit/Open - Cylinder 3 P0204 157 Injector Circuit/Open - Cylinder 4 P0205 155 Injector Circuit/Open - Cylinder 5 P0206 152 Injector Circuit/Open - Cylinder 6 P0207 156 Injector Circuit/Open - Cylinder 7 P0208 151 Injector Circuit/Open - Cylinder 8 P0300 62 Random/Multiple Cylinder Misfire Detected P0301 50 Cylinder 1 Misfire Detected P0302 54 Cylinder 2 Misfire Detected P0303 53 Cylinder 3 Misfire Detected P0304 57 Cylinder 4 Misfire Detected P0305 55 Cylinder 5 Misfire Detected P0306 52 Cylinder 6 Misfire Detected P0307 56 Cylinder 7 Misfire Detected P0308 51 Cylinder 8 Misfire Detected P0325 210 Knock Sensor 1 Circuit (Bank 1 or Single Sensor) P0330 211 Knock Sensor 2 Circuit (Bank 2) P0335 111 Crankshaft Position Sensor 'A' Circuit P0340 113 Camshaft Position Sensor 'A' Circuit (Bank 1 or Single Sensor) P0420 40 Catalyst System Efficiency Below Threshold (Bank 1) P0430 45 Catalyst System Efficiency Below Threshold (Bank 2) P0440 93 Evaporative Emission System P0442 182 Evaporative Emission System Leak Detected (small leak) P0442 183 Evaporative Emission System Leak Detected (small leak) P0443 98 Evaporative Emission System Purge Control Valve Circuit P0500 120 Vehicle Speed Sensor 'A' P0505 32 Idle Air Control System P0600 220 Serial Communication Link P0601 105 Internal Control Module Memory Check Sum Error P0605 101 Internal Control Module Read Only Memory (ROM) Error P0605 103 Internal Control Module Read Only Memory (ROM) Error P0605 107 Internal Control Module Read Only Memory (ROM) Error P0605 108 Internal Control Module Read Only Memory (ROM) Error P1140 163 Mass or Volume Air Flow Circuit Range/Performance Problem P1174 28 Fuel Trim Adaptation Malfunction (Bank 1) P1175 29 Fuel Trim Adaptation Additive Malfunction (Bank 2) P1340 114 Multiple Cylinder Misfire During Start P1384 212 Knock Sensor 3 Circuit P1385 213 Knock Sensor 4 Circuit P1386 214 Control Module Self-Test, Knock Control Circuit Baseline Test (Bank 1) P1386 215 Control Module Self-Test, Knock Control Circuit Baseline Test (Bank 1) P1386 216 Control Module Self-Test, Knock Control Circuit Baseline Test (Bank 1) P1396 112 Crankshaft Position Sensor Segment Timing Plausibility P1420 85 Secondary Air Injection Valve Control Circuit Electrical P1421 81 Secondary Air System (Bank 2) P1423 80 Secondary Air System (Bank 1) P1453 84 Secondary Air Injection Pump Relay Control Circuit Electrical P1470 1 Leakage Diagnostic Pump Control Circuit Electrical P1475 185 Leakage Diagnostic Pump Reed Switch Did not Close P1476 184 Leakage Diagnostic Pump Clamped Tube (M52 MY99/00: Leakage Diagnostic Pump Reed Switch Circuit) P1519 33 Oil-Condition Sensor Temperature Measurement (M62/M52/S52: 'A' Camshaft Position Actuator Bank 1) P1522 34 Oil-Condition Sensor Permeability Measurement (M62: 'A' Camshaft Position Actuator Bank 2; M52: 'A' Camshaft Position Actuator Tight or Jammed) P1525 165 'A' Camshaft Position Actuator Control Open Circuit (Bank 1) P1526 166 'A' Camshaft Position Actuator Control Open Circuit (Bank 2) P1530 130 'B' Camshaft Position Actuator Control Circuit Signal High (Bank 1) (S54 to 09/00: Throttle Valve Position Control, Control Deviation) P1531 131 'B' Camshaft Position Actuator Control Open Circuit (Bank 1) P1532 132 'B' Camshaft Position Actuator Control Open Circuit (Bank 2) (S54 to 09/00: Throttle Valve Control Circuit) P1622 140 Map Cooling Thermostat Control Circuit Electrical |
| Сказал Спасибо zass за это сообщение: | роман79 (07.01.2010) |
| Смешные рассказы | Mik78 | Общение и флуд | 400 | 27.06.2015 12:42 |
| вопросы по е34 и ответы | bavaria2009 | Ремонт и эксплуатация BMW | 7 | 07.06.2011 14:21 |
