| Общение и флуд Общение на любые темы, выходящие за рамки других разделов форума. Описание темы: Наш привет с тёплого берега Каспия |
| | #1 | |
| Новичок Регистрация: 22.01.2013
Automotive Japanese Radios - some Secrets Unveiled This page is dedicated to recording information on how to re-program radios in cars that came from the Japan market and are now being used outside Japan. Eg: a vehicle is imported into New Zealand from Japan. The radio doesn't work properly in NZ because the NZ FM radio band is 88-108 (same as Europe) but Japan is 76-90 MHz. Some vehicles, especially European brands, can be changed from Japan mode to Euro mode easily. This web page tells you how. BMW From September 2001, BMW started fitting the same radio for all worldwide markets. The radio can be changed from one market are to another by accessing the radio's Service Mode. The means of accessing the Service Mode varies from radio to radio. Accessing Service Mode for radio type C53/CD53 (without Multi-Info Display "MID", or TV screen) as fitted to E39 (5 Series), E46 (3 Series), E53 (X5), E83 (X3) or E85 (Z4) Turn the radio on. Straight away, press and hold the 'M' button for at least 8 seconds. Scroll through functions using the '+' and '-' keys or the "< >" buttons. Change settings using the 1...6 buttons. Turn the radio off to exit the service mode and store the settings. Accessing Service Mode for radio type C53/CD53 (with Central Information Display "CID", or TV screen) E83 (X3) or E85 (Z4) Turn the radio on. Straight away, press and hold the 'SEL' button for at least 8 seconds. Scroll through functions using the '+' and '-' keys or the "< >" buttons. Change settings using the 1...6 buttons. Accessing Service Mode for radio type C53/CD53 (with MIR Multi-Information Radio) E52 (Z8) Turn the radio on. Straight away, press and hold the 'SEL' button for at least 8 seconds. Scroll through functions using the '+' and '-' keys or the "< >" buttons. Change settings using the 1...6 buttons. Accessing Service Mode for small-screen (4:3) on-board monitor with radio type BM53/BM54 as fitted to E38 (7 Series), E39 (5 Series), E46 (3 Series), E53 (X5) Turn the radio on. Straight away, press and hold the 'RDS' button for at least 8 seconds. Scroll through functions using the "< >" buttons. Change settings using the 1...6 buttons. Turn the radio off to exit the service mode and store the settings. Accessing Service Mode for wide-screen (16:9) on-board monitor with radio type BM53/BM54 prior to Sept 2001 as fitted to E38 (7 Series), E39 (5 Series), E46 (3 Series), E53 (X5) Turn the radio on. Straight away, press the 'INFO' button. Select RDS or PTY (displayed option depends on market). Press and hold the 'On-Board Monitor rotary control knob for at least 8 seconds. Scroll through functions using the "< >" buttons. Change settings using the 1...6 buttons. Turn the radio off to exit the service mode and store the settings. Accessing Service Mode for wide-screen (16:9) on-board monitor with radio type BM53/BM54 after Sept 2001 as fitted to E38 (7 Series), E39 (5 Series), E46 (3 Series), E53 (X5) Turn the radio on. Straight away, press and hold the 'SELECT' button for at least 8 seconds. Scroll through functions using the "< >" buttons. Change settings using the 1...6 buttons. Turn the radio off to exit the service mode and store the settings. The Service Mode settings are: Software version: radio software yersion (week/year/version) GAL: speed sensitive volume, 1=min effect, 6=max effect. No effect if DSP fitted. F/Q: Field strenght and Quality. F1=min, F15=max. Q1=min, Q15=max. DSP: shows 1 if DSP detected and working, otherwise 0. TP Volume: Traffic Announcement volume level. AF: Alternative Frequency (part of RDS service). Best set to Auto. Index: Revision index. Area: Market area. This is the setting to change when changing from Japanese to any other area. Последний раз редактировалось Brio; 24.01.2013 в 10:59. | |
| | #3 |
Откуда: Baku Авто: BMW 523i | O boyda copy paste elemishem bro )) Oxumadin?)) Accessing Service Mode for small-screen (4:3) on-board monitor with radio type BM53/BM54 as fitted to E38 (7 Series), E39 (5 Series), E46 (3 Series), E53 (X5) Turn the radio on. Straight away, press and hold the 'RDS' button for at least 8 seconds. Scroll through functions using the "< >" buttons. Change settings using the 1...6 buttons. Turn the radio off to exit the service mode and store the settings. |
| | #4 | |
| Новичок Регистрация: 20.07.2011
Откуда: Baku ,Azerbaijan Авто: BMW E39 528i M technic | Цитата:
Brio comp nese gatignan isleyir ,bayag o elediyin copy -paste gostermirdi indi gosterdi ))) Eziyyetine gore sag ol amma immeno bunu tapmisdim, mesele ondadi ki nedense menim monitorumda bu RDS yoxdu ((( fotoya bax cox geribe monitordu kakoyto Traffic meselesi var vmesto RDS | |
| | #5 | |
| | #6 | |
Deyesen senin mashininda olan radio kohne versiya sayilir.Onda service mode yoxdu(yaponiya uchun kohne:)) buna bax isteyirsen .. Последний раз редактировалось Brio; 24.01.2013 в 11:31. | |
| | #8 | |
Поблагодарили 4 раз(а) в 2 сообщениях
только все сам точно посматри плиз...и точные фотки
__________________ BMW Club Azerbaijan | |
| | #9 | |
--- Proq kocurmushem.. qalib New Genuine BMW INPA/Ediabas K+D CAN USB Interface BMW OBD2 EOBD DCAN Scanner sifarish elemek )).. | |
| | #10 | |
shekillerini qoyaram baxarsan
| е39 вибрация при торможении, может у кого было ? | raibik | Ремонт и эксплуатация BMW | 34 | 25.02.2015 20:32 |
| Народ подскажите кто чем может | Переводчик | Ремонт и эксплуатация BMW | 15 | 10.10.2014 23:32 |
| Может кто знает, что за беда? | Verão | Ремонт и эксплуатация BMW | 21 | 30.11.2010 17:11 |
| акпп,включаешь D или R может заглохнуть??? | dmc | Ремонт и эксплуатация BMW | 1 | 30.11.2009 13:10 |
| Кто может помочь? | Серега 525 | Ремонт и эксплуатация BMW | 10 | 26.11.2009 20:47 |
