Неплохая статья об АКПП
Like Tree3Likes
Старый 01.09.2009, 14:06 #31
kusa, по-английски разбираешься?
если да, то вот точно такая же проблема:
  • [Только для зарегистрированных...].
Gear monitoring and speed monitoring are the same and include the same possible faults as mentioned previously. I'd do the following (in this order):
1. Check fluid level and adjust (see procedure below)
2. If fluid level is correct, do a pan and filter change (this slowly adds new fluid to the system - you're not flushing at this stage). If it starts responding better, then do a pan drain and fill about 3-4 more times after driving for a while (500-1000 miles between changes). This allows for almost a 90-95% fluid change without flushing. Royal Purple MaxATF or Amsoil Universal are good alternatives to the factory fluid and usually much cheaper. The bottom of your pan will have the recommended fluid type - it could be just DexIII, so it's worth checking.
3. If step two is not showing any improvement, add a bottle of RED Lubeguard (don't use the black bottle, it has a friction modifier in it).
4. If none of the above helps, then it's most likely time to change out the tranny.
How to get the maximum fluid level (make sure you follow ALL of the steps):
1. Do all checking at the minimum transmission temperature - ~86 deg F (important step - This can be hard to do during the summer as the ambient temperature can be above this)
2. Lift the car and make sure it's level (jack stands, etc)
3. Start the engine and slowly work through all gears while your foot is on the brake (for obvious reasons, especially if on a lift)
4. Put the car in park and leave the engine running
5. Turn the air conditioning ON (this increases the engine idle speed slightly - important step)
6. Remove the fill plug from the transmission, fluid should just slightly stream out of the fill plug
7. Add fluid if necessary until it slightly streams out of the fill plug
8. Tighten fill plug, shut off engine and lower car
  • + [Только для зарегистрированных...].
Ну и + конечно же: [Только для зарегистрированных...]
Старый 02.09.2009, 10:01 #32
Авто: bmw320
mojna svami pagavarit po skype? moi adres kusa-76. saabshite i svoi adres
kusa вне форума   Ответить с цитированием
Старый 06.09.2009, 00:48 #33
Аватар для Zlot
Сказал спасибо: 32
Авто: Е 39 М 52
Живу в Германии, ездил при покупке Е39 на официальный сервис БМВ проверить масло в АКПП. Там сказали что масло проверяется при температуре не выше 22 градусов цельсия!!! Для этого они оставляют авто на ночь у себя и только утром смотрят уровень!!! Так что не стоит особо доверять вышесказаному по поводу проверки на горячую!!!
Zlot вне форума   Ответить с цитированием
Старый 12.09.2009, 01:35 #34
Авто: BMW 325tds
я сделал вывод, что большинство вообще никогда не проверяли уровень ATF, другое большинство делало это не правильно.
Большинство автосервисов попросту отказываются работать с АКПП! Мне например даже уровень не проверили.
bobuk вне форума   Ответить с цитированием
Старый 12.09.2009, 07:43 #35
Сказал спасибо: 32
Авто: BMW 320
А я не люблю АКПП
Mr-Slim07 вне форума   Ответить с цитированием
Старый 04.10.2010, 13:21 #36
Аватар для Darmidon
Авто: BMW X5
может кто подскажет, в Х5 3.0d, 2003г. до ресталинга. масло в акпп надо LT71141?
И беда случилась: жму на педаль газа, а машина не едет, глушу, завожу, 500м проеду и опять стою!!
Последний раз редактировалось Darmidon; 04.10.2010 в 13:22. Причина: дополнил
Darmidon вне форума   Ответить с цитированием
Старый 04.10.2010, 14:42 #37
Сказал спасибо: 12
Поблагодарили 10 раз(а) в 8 сообщениях
Авто: x5
Talking
Сообщение от cyrix Посмотреть сообщение
У меня тоже есть небольшие толчки...когда в горку трогаешься...
сервис говорит все норм)) в движени все плавно переключается...
Раньше ездил на БМВ только с механикой ..не было проблем)))
А теперь автомат...ЭХ..Беречь нада АКПП!!!
Главное не рвите на автомате с места. Чем плавнее трогаешься, тем дольше она проживёт. Когда машина пошла, можно и притопить.
Kostia1980 вне форума   Ответить с цитированием
Старый 03.11.2010, 17:56 #38
Аватар для Игорь504
Авто: BMW E34
Игорь504 вне форума   Ответить с цитированием
Старый 03.11.2010, 17:59 #39
Аватар для Игорь504
Авто: BMW E34
Всем привет!у меня Е34 92г. проблема в автомате при включении R происходит ощутимый толчек в редукторе. подскажите в чем причина может быть!
Старый 03.11.2010, 18:27 #40
Может холостых оборотов много?
maxfay вне форума   Ответить с цитированием
Неплохая статейка про АКПП БМВ dmitr24 Ремонт и эксплуатация BMW 7 08.05.2013 23:09
Часовой пояс GMT +3, время: 11:57.
