замена лампочек освещения салона
Старый 15.10.2012, 18:12 #1
По умолчанию замена лампочек освещения салона
Замена лампочек освещения салона BMW F10
Door light, Glove Compartment, Trunk: very simple, just use a flathead to pop it out
Foot light: just pop the left side of the light
It should look like this
Just twist the cover and will be able to replace the lights
Rear dome light: Just have to pop out the clips that surround the doom light. The 2 reading bulbs are harder to get out so I used double sided tape and just tape it to the bulbs and pull them out.
Mirror Light: Just pull out the cover and unplug the wire and remove the metal clip.
Front Dome Light: You have to remove the black cover and you should see 4 holes. You need to use a small flathead and push the clips that's in the L shape holes. (might require a bit of force) And then you just have to pull the surrounding clips around the dome light.
Enjoy your new LED lights
Tyler на форуме
BMW e32 Снятие панели приборов. Замена лампочек в приборке и устранение неисправностей. Tyler Сделай сам 28 07.01.2014 19:30
BMW e70 замена лампочки освещения салона Tyler Сделай сам 1 17.10.2013 22:36
BMW e46 Замена лампочек освещения салона BMW e46 [видео] Tyler Сделай сам 1 21.01.2010 20:13
Часовой пояс GMT +3, время: 22:52.
