BMW Esys - кодирование F и G-серий
Like Tree26Likes
Старый 13.09.2012, 13:08 #3
Немного полезного:
#1. Уменьшение задержки поднятия стекол. This will change the delay between the front & rear windows going up & down when using the key fob or comfort access(door handle)
OPEN
FEM BODY / 3053 PwMaster / KOMFORT_OEFF_HINTEN / "lower Werte to desired amount"
FEM BODY / 3053 PwMaster / KOMFORT_OEFF_SHD / "lower Werte to desired amount"
CLOSE
FEM BODY / 3053 PwMaster / KOMFORT_SCHL_VORNE / "lower Werte to desired amount"
FEM BODY / 3053 PwMaster / KOMFORT_SCHL_SHD / "lower Werte to desired amount"
*** I lowered to 01 which basically makes them go up/down together with very little delay****
#2. Уменьшение задержки открытия багажника (меньше надо держать кнопку на брелоке). This will shorten the time you need to hold the trunk button on the fob for it to open
FEM BODY / 30D0 RemoteControl / RC_TIME_DELAY_BOOTLID / "lower Werte to desired amount"
*** I lowered to 01 for instant open upon button press ***
#3. Включение противотуманок вместе с приветственным светом. Turns on the fog lights with the welcome lights (left & right have separate headings)
LEFT
FEM BODY / 3063 LceLampMapping2 / MAPPING_NEBELSCHW_L_PART_OF_WL / select "soft_on" or "hard_on"
RIGHT
FEM BODY / 3063 LceLampMapping2 / MAPPING_NEBELSCHW_R_PART_OF_WL / select "soft_on" or "hard_on"
- Adds Pressure and Temperature Readings to the TPMS Screen
2011-12
HU_CIC => 3001 EXBOX => RDC_SAFETY => aktiv
2013
HU_NBT => 3001 EXBOX => RDC_SAFETY => aktiv
- Add Sport Displays in the Vehicle Info screen (Power & Torque Meters)
2011-12
HU_CIC => 3000 HMI => EFF_DYN_SPORT_CID => aktiv
HU_CIC => 3000 HMI => EFF_DYN_SPORT_UNIT => aktiv
2013
HU_NBT => 3000 HMI => EFF_DYN_SPORT_CID => aktiv
HU_NBT => 3000 HMI => EFF_DYN_SPORT_UNIT => aktiv
- Automatic High-Beams
2011-12
FRM => 3050 => FLA_AUTO_AKTIV => automatisch
FRM => 3050 => FLA_VERBAUT => aktiv
KAFAS2 => 3050 => FLA_ON_OFF => aktiv
HU_CIC => 3000 => HIGH_BEAM_ASSISTANT => aktiv
2013
HU_NBT => 3000 => HIGH_BEAM_ASSISTANT => aktiv
- Button on key fob and on driver side enabled to close the trunk (takes 20 minutes before effective)
HKFM => 3010 => SCH_FBD => aktiv
HKFM => 3010 => SCH_TOEHKI => aktiv
HKFM => 3010 => TASTER_FBD => aktiv
- Closes mirrors, windows, and moon roof through Key Fob and Comfort Access
CAS => 3003 FH MASTER => KOMFORTSCHLIESSUNG_FB => aktiv
CAS => 3003 FH MASTER => KOMFORTSCHLIESSUNG_PA => aktiv
FRM => 3020 => ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN => aktiv
- Enable GPS sync for clock
KOMBI -> 3000 Anzeige_Konfiguration -> GPS_UHR -> aktiv
- Digital Speed in MPH is a new option in BC
KOMBI => 3000 Anzeige_Konfiguration => BC_DIGITAL_V => aktiv
- Disable seat belt reminder - passenger and driver
ACSM => 3000 Ausstattungsflags => SBR_BF_GWF_SBR_BF => nicht_aktiv
ACSM => 3000 Ausstattungsflags => SBR_FA_GWF_SBR_FA => nicht_aktiv
- Disable DVD Speedlock - Part 2, Disable DVD Speedlock - Part 1, Disable Video just in combination with handbrake.
HU_NBT/CIC=> 3000 HMI => SPEEDLOCK_X_KMH_MIN => value = FF
HU_NBT/CIC=> 3000 HMI => SPEEDLOCK_X_KMH_MAX => value = FF
2011-12
HU_CIC=> 3000 HMI => VIDEO_NUR_MIT_HANDBREMSE => nicht_aktiv
2013
HU_NBT=> 3000 HMI => VIDEO_HANDBRAKE => nicht_aktiv
- Disables iDrive legal disclaimer during iDrive startup.
2011-12
HU_CIC => 3001 => EXBOX => LEGAL_DISCLAIMER_TIME => kein_ld
2013
HU_NBT => 3001 => EXBOX => LEGAL_DISCLAIMER_TIME => kein_ld
- enable Fog Lights with High Beams / Flashers
FRM => 3050 => NSW_AUS_BEI_FL => nicht_aktiv
- Opening doors will not interrupt window roll up (Front and Back)
FRM => 3030 => FH_TUER_AUF_STOP_MAUT => nicht_aktiv
JBBF => 3070 => FH_TUER_AUF_STOP_MAUT => nicht_aktiv
- Sets car's Auto Start/Stop function to start in the last used setting (e.g. Off) when the engine is started
CAS => 3000 TC => TC_MSA_MEMORY => aktiv
- Telephone ringtone is transferred to the Combox
2011-12
CMB_MEDIA => 3001 TELEPHONE_PARAMETER => INBAND_RINGING => aktiv
2013
HU_NBT => 3001 TELEPHONE_PARAMETER => INBAND_RINGING => aktiv
- Unlocks doors when engine is stopped (start/stop button is pushed)
CAS => 3002 CLM ER => KEYOUT_AUTOVR => aktiv
Эти 6 пользователя(ей) сказали Спасибо Tyler за сообщение:
alex140288 (29.09.2014), dggore (22.07.2014), kostreame (04.02.2013), mixks (18.04.2020), Nor_Who (06.10.2013), tyrystor (29.01.2021)
Метки
bmw esys, кодирование bmw f-серий
Часовой пояс GMT +3, время: 03:32.
