BMW Inpa/Ediabas 5.0 (OBD interface)
Старый 15.10.2008, 11:38 #13
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0434 UNKNOWN CODE
P0435 UNKNOWN CODE
P0436 UNKNOWN CODE
P0437 UNKNOWN CODE
P0438 UNKNOWN CODE
P0439 UNKNOWN CODE
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge [Только для зарегистрированных...] Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0456 EVAP Leak Monitor Small Leak Detected (***(May not be applicable for Honda / Acura)***)
P0457 UNKNOWN CODE
P0458 UNKNOWN CODE
P0459 UNKNOWN CODE
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0486 UNKNOWN CODE
P0487 UNKNOWN CODE
P0488 UNKNOWN CODE
P0489 UNKNOWN CODE
P0490 UNKNOWN CODE
P0491 UNKNOWN CODE
P0492 UNKNOWN CODE
P0493 UNKNOWN CODE
P0494 UNKNOWN CODE
P0495 UNKNOWN CODE
P0496 Evaporative Emission (EVAP) System Flow During Non-Purge
P0497 UNKNOWN CODE
P0498 UNKNOWN CODE
P0499 UNKNOWN CODE
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0508 UNKNOWN CODE
P0509 UNKNOWN CODE
P0510 Closed Throttle Position Switch Malfunction
P0511 UNKNOWN CODE
P0512 Start Switch Circuit
P0513 UNKNOWN CODE
P0514 UNKNOWN CODE
P0515 UNKNOWN CODE
P0516 UNKNOWN CODE
P0517 UNKNOWN CODE
P0518 UNKNOWN CODE
P0519 UNKNOWN CODE
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0524 UNKNOWN CODE
P0525 UNKNOWN CODE
P0526 UNKNOWN CODE
P0527 UNKNOWN CODE
P0528 UNKNOWN CODE
P0529 UNKNOWN CODE
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0535 UNKNOWN CODE
P0536 UNKNOWN CODE
P0537 UNKNOWN CODE
P0538 UNKNOWN CODE
P0539 UNKNOWN CODE
P0540 UNKNOWN CODE
P0541 UNKNOWN CODE
P0542 UNKNOWN CODE
P0543 UNKNOWN CODE
P0544 UNKNOWN CODE
P0545 UNKNOWN CODE
P0546 UNKNOWN CODE
P0547 UNKNOWN CODE
P0548 UNKNOWN CODE
P0549 UNKNOWN CODE
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0555 UNKNOWN CODE
P0556 UNKNOWN CODE
P0557 UNKNOWN CODE
P0558 UNKNOWN CODE
P0559 UNKNOWN CODE
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0564 UNKNOWN CODE
P0565 CRUISE CONTROL ON SIGNAL MALFUNCTION
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0577 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0581 UNKNOWN CODE
P0582 UNKNOWN CODE
P0583 UNKNOWN CODE
P0584 UNKNOWN CODE
P0585 UNKNOWN CODE
P0586 UNKNOWN CODE
P0587 UNKNOWN CODE
P0588 UNKNOWN CODE
P0589 UNKNOWN CODE
P0590 UNKNOWN CODE
P0591 UNKNOWN CODE
P0592 UNKNOWN CODE
P0593 UNKNOWN CODE
P0594 UNKNOWN CODE
P0595 UNKNOWN CODE
P0596 UNKNOWN CODE
P0597 UNKNOWN CODE
P0598 UNKNOWN CODE
P0599 UNKNOWN CODE
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) ErroR
P0606 PCM Processor Fault (Control Module Internal Performance)
P0607 ECU Malfunction
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0610 Control Module Vehicle Options Incorrect
P0611 UNKNOWN CODE
P0612 UNKNOWN CODE
P0613 UNKNOWN CODE
P0614 UNKNOWN CODE
P0615 Starter Relay Control Circuit
P0616 Starter Relay Control Circuit Low Voltage
P0617 Starter Relay Control Circuit High Voltage
P0618 UNKNOWN CODE
Часовой пояс GMT +3, время: 04:22.
