BMW Inpa/Ediabas 5.0 (OBD interface)
Старый 15.10.2008, 11:41 #21
P1623 Pedal Position Sensor Potentiometer Supply (***(May not be applicable for Honda / Acura)***)
P1624 Pedal Position Sensor Potentiometer Supply Channel 1 Electrical (***(May not be applicable for Honda / Acura)***)
P1624 Customer Snapshot Requested - Data Available (***(May not be applicable for Honda / Acura)***)
P1625 Pedal Position Sensor Potentiometer Supply Channel 2 Electrical (***(May not be applicable for Honda / Acura)***)
P1626 Theft Deterrent System - Fuel Enable Circuit
P1626 Implausible Signal From Transmission Control Module (***(May not be applicable for Honda / Acura)***)
P1630 Theft Deterrent - PCM in Learn Mode
P1631 Theft Deterrent - Password Incorrect
P1631 Throttle Position Sensor Signal Too High (***(May not be applicable for Honda / Acura)***)
P1632 Theft Deterrent - Fuel Disabled
P1632 Throttle Valve Adaptation; Adaptation Condition Not Met (***(May not be applicable for Honda / Acura)***)
P1632 Traction Control System Malfunction (***(May not be applicable for Honda / Acura)***)
P1632 Throttle Position Sensor Supply Voltage (***(May not be applicable for Honda / Acura)***)
P1633 Ignition Supplement Power Circuit Low Voltage
P1633 Throttle Valve Adaptation; Limp Home Position (***(May not be applicable for Honda / Acura)***)
P1633 Keep Alive Power Voltage Too Low (***(May not be applicable for Honda / Acura)***)
P1634 Ignition 1 Power Circuit Low Voltage
P1634 Throttle Valve Adaptation; Spring Test Failed (***(May not be applicable for Honda / Acura)***)
P1635 Throttle Valve Adaptation; Lower Mechanical Stop Not Adapted (***(May not be applicable for Honda / Acura)***)
P1635 5 Volt Reference Circuit (***(May not be applicable for Honda / Acura)***)
P1635 Tire/Axle Out Of Acceptable Range (***(May not be applicable for Honda / Acura)***)
P1636 Throttle Valve Control Circuit (***(May not be applicable for Honda / Acura)***)
P1636 Inductive Signiture Chip Communication Error (***(May not be applicable for Honda / Acura)***)
P1637 Throttle Valve Position Control; Control Deviation (***(May not be applicable for Honda / Acura)***)
P1638 Throttle Valve Position Control; Throttle Stuck Temporarily (***(May not be applicable for Honda / Acura)***)
P1639 Throttle Valve Position Control; Throttle Stuck Permanently (***(May not be applicable for Honda / Acura)***)
P1639 5 Volt Reference 2 Circuit (***(May not be applicable for Honda / Acura)***)
P1639 Vehicle ID Block Not Programmed Or Corrupt (***(May not be applicable for Honda / Acura)***)
P1639 Throttle Position Sensor Implausible Signal (***(May not be applicable for Honda / Acura)***)
P1640 Internal Control Module (ROM/RAM) Error (***(May not be applicable for Honda / Acura)***)
P1640 DTC's Available In Another Module (***(May not be applicable for Honda / Acura)***)
P1640 Driver 1 - Input High Voltage
P1640 Engine Control Module Inoperative (***(May not be applicable for Honda / Acura)***)
P1641 Malfunction Indicator Lamp (MIL) Control Circuit
P1642 Vehicle Speed Output Circuit
P1644 Delivered Torque Output Circuit
P1645 EVAP Solenoid Output Circuit
P1646 EVAP Vent Valve Output Circuit
P1648 CAN-Bus System Component Failure (***(May not be applicable for Honda / Acura)***)
P1649 Implausible Signal From ABS Control Module (***(May not be applicable for Honda / Acura)***)
P1650 Driver 2 - Input High Voltage
P1650 Power Steering Pressure Switch Malfunction (***(May not be applicable for Honda / Acura)***)
P1650 Power Steering Pressure Switch Out Of Range (***(May not be applicable for Honda / Acura)***)
P1651 Power Steering Pressure Switch Input Malfunction (***(May not be applicable for Honda / Acura)***)
P1651 Power Steering Pressure Switch Signal Malfunction (***(May not be applicable for Honda / Acura)***)
P1652 Lift/Dive Circuit
P1654 Cruise Disable Output Circuit
P1656 Automatic Transaxle
P1660 Cooling Fan Control Circuits
P1660 A/T FI Data Line Failure
P1670 ODM has Detected a Voltage greater than 33 volts (***(May not be applicable for Honda / Acura)***)
P1676 FPTDR Signal Failure
P1678 FPTDR Signal Line Failure
P1680 Clutch Released Switch Circuit (***(May not be applicable for Honda / Acura)***)
P1681 No I/P Cluster CCD/J1850 Messages Received (***(May not be applicable for Honda / Acura)***)
P1681 A/T FI Signal A Low Input
P1682 A/T FI Signal A High Input
P1682 Charging System Voltage Too Low (***(May not be applicable for Honda / Acura)***)
P1683 Speed Control Power Relay or S/C 12V Driver Circuit (***(May not be applicable for Honda / Acura)***)
P1684 Battery Disconnected Within Last 50 Starts (***(May not be applicable for Honda / Acura)***)
P1685 Skim Invalid Key (***(May not be applicable for Honda / Acura)***)
P1686 No SKIM Bus Message Received (***(May not be applicable for Honda / Acura)***)
P1686 A/T FI Signal B Low Input
P1687 A/T FI Signal B High Input
P1687 No Cluster Bus Message (***(May not be applicable for Honda / Acura)***)
P1689 Traction Control Delivered Torque Output Circuit (***(May not be applicable for Honda / Acura)***)
P1690 Malfunction Indicator Lamp (MIL) Electrical (***(May not be applicable for Honda / Acura)***)
P1693 DTC Detected In Companion Mode (***(May not be applicable for Honda / Acura)***)
P1694 Fault In Companion Mode (***(May not be applicable for Honda / Acura)***)
P1695 No CCD/J185O Message From BCM (***(May not be applicable for Honda / Acura)***)
P1696 PCM Failure EEPROM Write Denied (***(May not be applicable for Honda / Acura)***)
P1697 PCM Failure SRI Mile Not Stored (***(May not be applicable for Honda / Acura)***)
P1698 No Bus Message From TCM (***(May not be applicable for Honda / Acura)***)
P1698 Engine Torque Control Cut Signal Circuit Low Input (***(May not be applicable for Honda / Acura)***)
P1699 Engine Torque Control Cut Signal Circuit High Input (***(May not be applicable for Honda / Acura)***)
P1700 TPS Circuit Malfunction For AT (***(May not be applicable for Honda / Acura)***)
P1701 Transmission Solenoid Malfunction (***(May not be applicable for Honda / Acura)***)
P1701 Cruise Control Set Signal Circuit Malfunction For AT (***(May not be applicable for Honda / Acura)***)
P1703 Brake On/Off Switch (***(May not be applicable for Honda / Acura)***)
P1703 Brake On/Off Switch Out Of Range (***(May not be applicable for Honda / Acura)***)
P1703 Low Clutch Timing Control Solenoid Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1705 Automatic Transaxle
P1705 Transmisson Range Sensor Out Of Range (***(May not be applicable for Honda / Acura)***)
P1705 Transmisson Range Sensor (***(May not be applicable for Honda / Acura)***)
P1705 Throttle Position Sensor ((***(May not be applicable for Honda / Acura)***))
P1706 Automatic Transaxle
P1706 Park/Neutral Position (PNP) Switch (***(May not be applicable for Honda / Acura)***)
P1709 Automatic Transaxle
P1709 Park/Neutral Position Switch Out Of Range (***(May not be applicable for Honda / Acura)***)
P1710 Automatic Transaxle
P1711 Transmission Fluid Temperature Sensor (***(May not be applicable for Honda / Acura)***)
P1711 Engine Torque Control Signal 1 Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1712 Engine Torque Control Signal 2 Circuit Malfunction (***(May not be applicable for Honda / Acura)***)
P1713 Automatic Transaxle
P1719 Skip Shift Solenoid Circuit (***(May not be applicable for Honda / Acura)***)
P1729 4x4 Low Switch Malfunction (***(May not be applicable for Honda / Acura)***)
P1734 Pressure Control Solenoid "B" Electrical (***(May not be applicable for Honda / Acura)***)
P1738 Automatic Transaxle
P1738 Pressure Control Solenoid "C" Electrical (***(May not be applicable for Honda / Acura)***)
P1739 Automatic Transaxle
P1740 Automatic Transaxle
P1743 Pressure Control Solenoid "E" Electrical (***(May not be applicable for Honda / Acura)***)
P1744 Pressure Control Solenoid "A" Electrical (***(May not be applicable for Honda / Acura)***)
P1746 EPC Solenoid Failed Low (***(May not be applicable for Honda / Acura)***)
P1746 Transmission Control Module Output Stage (***(May not be applicable for Honda / Acura)***)
P1747 CAN Bus Monitoring (***(May not be applicable for Honda / Acura)***)
P1747 EPC Solenoid Short Circuit (***(May not be applicable for Honda / Acura)***)
P1748 Transmission Control Module Self Test (***(May not be applicable for Honda / Acura)***)
P1749 Secondary Pressure Solenoid Communication Error (***(May not be applicable for Honda / Acura)***)
P1749 EPC Solenoid Open Circuit (***(May not be applicable for Honda / Acura)***)
P1750 Secondary Pressure Solenoid Circuit Range/Performance (***(May not be applicable for Honda / Acura)***)
P1751 Secondary Pressure Solenoid Open Circuit (***(May not be applicable for Honda / Acura)***)
P1751 Shift Solenoid #1 (SS1) (***(May not be applicable for Honda / Acura)***)
P1751 A/T Control Relay Malfunction (***(May not be applicable for Honda / Acura)***)
P1753 Automatic Transaxle
P1754 Coast Clutch Solenoid (***(May not be applicable for Honda / Acura)***)
P1756 GOV Press Not Equal To Target @ 15-20 PSI (***(May not be applicable for Honda / Acura)***)
P1756 Shift Solenoid #2 (SS2) (***(May not be applicable for Honda / Acura)***)
P1757 GOV Press Not Equal To Target @ 15-20 PSI (***(May not be applicable for Honda / Acura)***)
P1758 Automatic Transaxle
P1760 Overrun Clutch Solenoid Valve (***(May not be applicable for Honda / Acura)***)
Часовой пояс GMT +3, время: 00:21.
