| | #22 |
Откуда: Москва Авто: BMW e39 528 Есть клубные рамки |
P1761 Shift Solenoid Malfunction (***(May not be applicable for Honda / Acura)***) P1761 Shift Solenoid #3 (SS3) (***(May not be applicable for Honda / Acura)***) P1762 Gov Press Sen Offset Volts Too Low or high(***(May not be applicable for Honda / Acura)***)P1763 Governor Pressure Sensor Volts Too High (***(May not be applicable for Honda / Acura)***) P1764 Governor Pressure Sensor Volts Too Low (***(May not be applicable for Honda / Acura)***) P1765 CAN Throttle Valve (***(May not be applicable for Honda / Acura)***) P1765 Trans 12 Volt Supply Relay CTRL Circuit (***(May not be applicable for Honda / Acura)***) P1768 Automatic Transaxle P1770 CAN Torque Interface (***(May not be applicable for Honda / Acura)***) P1773 Automatic Transaxle P1778 Automatic Transaxle P1780 CAN Torque Reduction (***(May not be applicable for Honda / Acura)***) P1780 Transmission Control Switch (***(May not be applicable for Honda / Acura)***) P1780 Transmission Control Switch Out Of Range(***(May not be applicable for Honda / Acura)***) P1780 Park/Neutral Position Switch Malfunction (Only For A/T) (***(May not be applicable for Honda / Acura)***) P1781 4x4 Switch Out Of Range (***(May not be applicable for Honda / Acura)***) P1783 Transmission Over Temperature Condition (***(May not be applicable for Honda / Acura)***) P1786 Automatic Transaxle P1790 Automatic Transaxle P1791 Automatic Transaxle P1792 Automatic Transaxle P1794 Automatic Transaxle P1810 TFP Valve Position Switch Circuit (***(May not be applicable for Honda / Acura)***) P1811 Maximum Adapt and Long Shift (***(May not be applicable for Honda / Acura)***) P1819 Internal Mode Switch - No Start/Wrong Range (***(May not be applicable for Honda / Acura)***) P1820 Internal Mode Switch Circuit A Low (***(May not be applicable for Honda / Acura)***) P1822 Internal Mode Switch Circuit B High (***(May not be applicable for Honda / Acura)***) P1823 Internal Mode Switch Circuit P Low (***(May not be applicable for Honda / Acura)***) P1825 Internal Mode Switch - Invalid Range (***(May not be applicable for Honda / Acura)***) P1826 Internal Mode Switch Circuit C High (***(May not be applicable for Honda / Acura)***) P1851 Implausible Signal From ABS Control Module (***(May not be applicable for Honda / Acura)***) P1854 Drive Train CAN-Bus Inoperative (***(May not be applicable for Honda / Acura)***) P1860 TCC PWM Solenoid Circuit Electrical (***(May not be applicable for Honda / Acura)***) P1887 TCC Release Switch Circuit (***(May not be applicable for Honda / Acura)***) P1899 Park/Neutral Position Switch Stuck In Park or In Gear (***(May not be applicable for Honda / Acura)***) P1900 Output Shaft Speed Sensor Circuit Failure (***(May not be applicable for Honda / Acura)***) P2008 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit P2009 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit Low Voltage P2010 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit High Voltage P2066 Fuel Level Sensor 2 Performance P2067 Fuel Level Sensor 2 Circuit Low Voltage P2068 Fuel Level Sensor 2 Circuit High Voltage P2096 or P2098 Post Catalyst Fuel Trim System Low Limit P2097 or P2099 Post Catalyst Fuel Trim System High Limit P2100 Throttle Actuator Control (TAC) Motor Control Circuit P2101 Control Module Throttle Actuator Position Performance P2105 Throttle Actuator Control (TAC) System - Forced Engine Shutdown P2107 Throttle Actuator Control (TAC) Module Internal Circuit P2119 Throttle Closed Position Performance P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage P2135 Throttle Position (TP) Sensor 1-2 Correlation P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation P2176 Minimum Throttle Position Not Learned P2500 Generator L-Terminal Circuit Low Voltage P2501 Generator L-Terminal Circuit High Voltage ВСЁ!!!!!!!!! |
| Ликвидация новых запчастей по закупке | АндрейСергеевич | Продажа запчастей BMW | 2 | 02.07.2024 16:26 |
| Все опции БМВ на русском языке | Tyler | Выбираем БМВ | 21 | 19.06.2014 12:09 |
| Модельный ряд BMW пополнил автомобиль BMW 740d | Tyler | Новости BMW | 3 | 30.07.2009 19:24 |
| BMW 5 серии Gran Turismo на Женевском автосалоне 2009 | Tyler | Новости BMW | 0 | 26.02.2009 18:00 |
