| | #1 |
| Абориген Регистрация: 09.12.2009
Сказал спасибо: 136
Подскажите пож. методы лечения ![]() F E H L E R S P E I C H E R L E S E N --------------------------------------- Datum: 03.02.2011 13:06:15 ECU: VGSG83 JobStatus: OKAY Variante: VGSG83 ------------------------------------------------------------- ERGEBNIS: 2 Fehler im Fehlerspeicher ! ------------------------------------------------------------- 5462 5462 Ошибка привода или увеличение потребляемой мощности fpr сцепления Fehlerhдufigkeit: 2 Logistikzдhler : 36 1. Umweltsatz Kilometerstand 90664 km Input voltage KL30 12.13 Volt KL15 State CAN CAN Signal OK -- KL15 off 0-n KL15 internal KL15 off 0-n Engine speed CAN Signal OK -- VKM off 0-n Reset-Source NO RESET 0-n iSM -40.00 Ampere BarrierActPosLim 1288.00 Nm error counter calibration try 0.00 1 BarrierError 0.00 1 BarrierMainState 57.00 1 error counter timeout 0.00 1 2. Umweltsatz Kilometerstand 90664 km Input voltage KL30 12.13 Volt KL15 State CAN CAN Signal OK -- KL15 off 0-n KL15 internal KL15 off 0-n Engine speed CAN Signal OK -- VKM off 0-n Reset-Source NO RESET 0-n iSM -39.50 Ampere BarrierActPosLim 1488.00 Nm error counter calibration try 0.00 1 BarrierError 0.00 1 BarrierMainState 57.00 1 error counter timeout 0.00 1 Implausible signal or value Test conditions not yet fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Fehlercode: 54 62 38 02 24 2C 45 61 E0 B0 A1 00 00 39 00 2C 45 61 E0 B1 BA 00 00 39 00 ------------------------------------------------------------- 54C4 54C4 первичная калибровка дефективна Fehlerhдufigkeit: 5 Logistikzдhler : 39 1. Umweltsatz Kilometerstand 90664 km Input voltage KL30 12.38 Volt KL15 State CAN CAN Signal OK -- KL15 on 0-n KL15 internal KL15 on 0-n Engine speed CAN Signal OK -- VKM off 0-n Reset-Source NO RESET 0-n iSM -2.50 Ampere BarrierActPosLim 0.00 Nm error counter calibration try 0.00 1 BarrierError 11.00 1 BarrierMainState 116.00 1 error counter timeout 0.00 1 2. Umweltsatz Kilometerstand 90664 km Input voltage KL30 11.75 Volt KL15 State CAN CAN Signal OK -- KL15 on 0-n KL15 internal KL15 on 0-n Engine speed CAN Signal OK -- VKM off 0-n Reset-Source NO RESET 0-n iSM -1.00 Ampere BarrierActPosLim 0.00 Nm error counter calibration try 0.00 1 BarrierError 11.00 1 BarrierMainState 116.00 1 error counter timeout 0.00 1 Implausible signal or value Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up Fehlercode: 54 C4 28 05 27 2C 45 63 E5 FB 00 00 0B 74 00 2C 45 5E E5 FE 00 00 0B 74 00 ================================================== ===========
__________________ На все вопросы имею ответ, у меня есть"максим". а у вас его нет.
| | #2 |
ДИСом прогони тест-блок - скорее всего, раздатка в сборе...
__________________ Не хочешь думать - не спрашивай меня ни о чём ![]() АЗБУКУ КАЖДЫЙ УЧИТ САМОСТОЯТЕЛЬНО |
| Сказал Спасибо NUFLIN за это сообщение: | Tyler (14.02.2011) |
| | #3 |
Сказал спасибо: 136
Откуда: г череповец Авто: bmw | Увы тесты не проходят, вернее проходят, но на первичную калибровку ругань![]() Сегодня заменю и посмотрю
| | #4 | |
__________________ Не хочешь думать - не спрашивай меня ни о чём ![]() АЗБУКУ КАЖДЫЙ УЧИТ САМОСТОЯТЕЛЬНО | |
| Сказал Спасибо NUFLIN за это сообщение: | вова 1951 (03.02.2011) |
| | #5 |
Сказал спасибо: 136
| | #6 |
Сказал спасибо: 136
Сервопривод , гад подклинивал Заменили и все ок
| Сказал Спасибо вова 1951 за это сообщение: | Tyler (16.02.2011) |
