КАКАЯ программа? версия? :bad: Цитата:
NUFLIN, ...не ругайсо:biggrin: ...походу надо видео FAQ по установке и настройки INPA делать...так всё равно смотреть не будут:facepalm: |
Solo606, SYS-0002: ECU OBJECT FILE NOT FOUND EDIABAS_SYS_0002 Meaning: The ECU variant description file couldn't be found. Causes: Either the description file does not exist in the EDIABS search path or the search path is wrong. EDIABAS search path: The EDIABAS configuration element EcuPath describes the EDIABAS search path. When the configuration setting does not exist, the current directory is used by EDIABAS as the search path. Error correction: Description file does not exist: Copy the requested description file in the EDIABAS search path. Search path is wrong: Terminate the application program, and assign the correct path to configuration element EcuPath. In case the configuration changes, terminate EDIABAS, and re-start.: WIN32: EDIABAS is automatically closed with the application (automatic restart) WIN16: Close EDIABASW.EXE via system menu (automatic re-start) SCO: Call shell script apiclose Call shell script apiboot QNX: Call shell script apiclose Call shell script apiboot Re-start the application program. Target system: WIN SCO QNX |
Solo606, SYS - 0002:ECU Object File Not Found -так написано же всё. И расшифровка в самом начале темы специально: [Ссылки могут видеть только зарегистрированные пользователи. Зарегистрироваться...] 3.6 SYS-0002: ECU OBJECT FILE NOT FOUND Reason 1: If the external table T_GRTB.prg doesn’t exist in the directory C:\EDIABAS\ECU\ the error message will be displayed when You execute the job IDENT_FUNKTIONAL of a functional SGBD. Solution 1: You have to download the external table using the ECCO Web Export and copy it in the directory C:\EDIABAS\ECU\. Reason 2: The SGBD, which You want to start doesn’t exist in the directory C:\EDIABAS\ECU or is an old one. Solution 2: You have to download the SGBD using the ECCO Web Client and copy it in the directory C:\EDIABAS\ECU\. Скорее всего, "Reason 2". Почему ничего не читаете? |
Здарова пацаны! Недавно приобрел BMW INPA кабель, и не могу понять как прочитать ошибки, когда захожу в разделы появляется какаята ошибка и вместо Running появляется Stopped,помогите пожалуйста! |
Nurlan26, здарова. Цитата:
bmw inpa :biggrin1:базара нет, тупанул. Скрин шот ошибки скину. |
ЧОткие пОцаны пошли в диагностику... :eek1: |
подскажите пожалуйста!!! такая проблема при попытке прошиться win kfpt ,вот такая ошибка: [IMG][url=http://postimage.org/][/IMG] [IMG][url=http://postimage.org/][/IMG] |
шнурок кетай,инпой ошибки читает,но пишет иногда про не совпадение версий |
| Часовой пояс GMT +3, время: 23:13. |
